#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2011 - 2017 Ford Explorer 5th Generation Explorer > Stock 2011 - 2016 Ford Explorer Discussion
Notices
Stock 2011 - 2016 Ford Explorer Discussion 2011 - 2016 Ford Explorer reviews, problem solving, maintenance, TSB, service bulletins, owner reviews, specifications, Ecoboost.
2013 Explorer Sport Towing capabilities
Reply
Thread Tools
Old 12-29-2012, 12:13 AM   #1
13Xworldchamps
Washington County, MD
2013 Explorer Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I recently ordered a 13 Sport with the towing package. I'm coming from an 06 Limited V8 Explorer and this towed my 2 Sea Doo watercraft on a double trailer like a dream. Never knew the trailer was behind me.
Obviously, I hope the 13 Sport is up to the task. I'm not worried about the towing capacity, but rather how it controls, stops and the overall performance.
Does anyone have any input to the towing performance of the Sport or 2011 - 13 explorers? Maybe the differences noticed between a truck platform vs. the uni-body platform of the current generation.
Ed
13Xworldchamps is offline   Reply With Quote
( Join the Elite Explorers )
Old 12-29-2012, 12:18 AM   #2
colintrax
Georgia
colintrax's Avatar
97 XLT and 91 Ranger
Vehicle Specs
Quoted: 314 Post(s)
2 jet skis aren't real heavy, I'd tow that with a prius
__________________
Hulk-1997 Explorer. Some mods and many more to come. My first car, and it's never let me down.
Cammi-2014 Chevy Spark, no options and gets 44mpg. In the process of lemon lawing this turd.
colintrax is online now   Reply With Quote
Old 12-29-2012, 12:23 AM   #3
13Xworldchamps
2013 Explorer Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Quote:
These skis are the newer 4 stroke sit down models. Fueled up and with trailer is over 2,500 pounds. Like I said, not worried about the towing capacity, just someones overall thoughts of the 13's vs the 06 - 10 generation V8 explorers.
Also can you turn off Overdrive on the 13 models with towing package?
Ed
Old 12-29-2012, 12:29 AM   #4
QwikEVO
Clovis, NM
2013 Ford Explorer Sport
Vehicle Specs
Quoted: 13 Post(s)
I towed a 5x8 trailer loaded to the gills (think it was 1800lbs) and it doesn't even act like there's a trailer back there. No noticeable difference.
QwikEVO is offline   Reply With Quote
Old 12-29-2012, 12:35 AM   #5
13Xworldchamps
2013 Explorer Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Quote:
Thanks!
Can you turn off overdrive on yours?
Ed
Old 12-29-2012, 12:40 AM   #6
QwikEVO
Clovis, NM
Vehicle Specs
Quoted: 13 Post(s)
Quote:
Originally Posted by 13Xworldchamps View Post
Thanks!
Ed
It has a tow/haul button, which IIRC turns on the tranny cooler and allows longer RPM's...so essentially I would guess is like turning off OD?
Old 12-29-2012, 12:59 AM   #7
colintrax
Georgia
colintrax's Avatar
Vehicle Specs
Quoted: 314 Post(s)
Tow/haul is the modern O/D off, it's better.
2,500lbs isn't all that heavy, more than I thought but I still wouldn't worry about. Isn't the new explorer rated for 6,500 or 7,000? And considering it sits lower/more aerodynamic than your old explorer, it should be more stabile at speed.
Considering the sport has larger brakes, and seeing the 0-60 times I don't think it'll have any problems. Might pull better than your old x
__________________
Old 12-29-2012, 01:39 AM   #8
13Xworldchamps
2013 Explorer Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thanks for the reply!
Capacity for the 13 Sport is 5,000 pounds. The V8 2006 - 10s were 7,300.
The change in tow ratings is truck frame on the older models vs. a car platform on the newer models.
Ed
Old 12-29-2012, 01:54 AM   #9
colintrax
Georgia
colintrax's Avatar
Vehicle Specs
Quoted: 314 Post(s)
Huh, I coulda swore the new generations were rated for more. Maybe the transmission/drive train is not as robust, I doubt it has to do with being unibody. The Jeep is unibody and can tow 8,000 right?
__________________
Old 12-29-2012, 01:56 AM   #10
colintrax
Georgia
colintrax's Avatar
Vehicle Specs
Quoted: 314 Post(s)
Checked, 7,400 lbs.
__________________
Old 12-29-2012, 02:09 AM   #11
13Xworldchamps
2013 Explorer Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Checked, 7,400 lbs.
http://media.ford.com/images/10031/2...port_Specs.pdf
Fords PDF says 5,000 lbs towing capacity with tow package (properly equipped).
Ed
Old 12-29-2012, 02:24 AM   #12
13Xworldchamps
2013 Explorer Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Ed
Old 12-29-2012, 08:58 AM   #13
JDraper
Somewhat Functional
McVeytown, PA
JDraper's Avatar
'11 XLT
Vehicle Specs
Quoted: 30 Post(s)
You'll be fine towing the jetski's. I use my Explorer to tow a Mustang on a steel trailer, and outside of the acceleration off the line, it tows as well as my '05 SuperCrew did.
__________________
Moderator..Home Improvement/Explorer 911/2011 Explorer Forum
You took my breath away....and now I want it back....
'66 Mustang Coupe, '04 Mustang Mach 1, '08 Focus, '11 Explorer XLT
"Ex"plorer's: '92 Sport, '94 Sport, '01 XLS
Our Crappy Website
JDraper is offline   Reply With Quote
Old 12-29-2012, 06:41 PM   #14
exilepa
2013 Ruby Red Sport
Vehicle Specs
Quoted: 0 Post(s)
You'll be fine, I towed a 5'X8' utility trailer with my 2011 Explorer Limited quite a bit with about 2200lbs on it and aside from the off the line acceleration and braking I never knew it was there. On top of that I was getting 17 MPG on the highway if I was kind on the accelerator. I've had my Sport for about a month now and haven't had a chance to tow with it yet but I'm expecting even better results!
exilepa is offline   Reply With Quote
Old 12-29-2012, 06:52 PM   #15
Javelin62
RI
2013 Ford Explorer
Vehicle Specs
Quoted: 0 Post(s)
I have a 18" Bassboat and the EX pulls it effortlessly. The trailer sway controls work great, feels more stable than my 06 Tundra did towing it!
Javelin62 is offline   Reply With Quote
Old 12-29-2012, 08:25 PM   #16
13Xworldchamps
2013 Explorer Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thanks for all the replies.
Sounds like I won't regret trading in the 2006 V8 then!
Ed
Old 12-30-2012, 12:17 AM   #17
colintrax
Georgia
colintrax's Avatar
Vehicle Specs
Quoted: 314 Post(s)
Ed
Hahah I was saying that in regards to the Jeep.
__________________
Old 12-30-2012, 06:19 PM   #18
Edgieguy
New Jersey
2011 XLT / 11 Edge Sport
Vehicle Specs
Quoted: 0 Post(s)
We tow a Polaris ARE WHICH IS 1100lbs on a 750lb snowmobile trailer. Sway control and towing switched on gives me the nicest towing experience I've ever had. We still manage a very respectable 20mpg on the highway which I attribute to the air being able to pass thru the Rzr' s roll cage up top not blocking any wind.
Edgieguy is offline   Reply With Quote
Old 01-02-2013, 04:28 PM   #19
LakeJunkie
Indy
2013 Explorer
Vehicle Specs
Quoted: 0 Post(s)
No problems on stopping. I pulled my 20' boat with my 13 with tow package this summer no issues. Dealer let me hook the boat up for the test drive but I think he was a little surprised slammed the pedal at 60 mph. I came from a Suburban so I felt it back there, but not once did I have a feeling that it couldn't handle it.
LakeJunkie is offline   Reply With Quote
Old 02-07-2013, 12:40 PM   #20
sammy77
'07 Ironman
Vehicle Specs
Quoted: 1 Post(s)
Towing with the '13 Explorer Sport
Hi guys, great site here.
Is anyone here towing long distances with their Explorer Sport yet? We have about 3k miles on ours and I've towed our snowmobile trailer with it locally a few times with mixed feelings. The trailer weighs in between 4k-4.5k lbs when it's loaded. It handles the weight just fine and stops on a dime with my P3 controller. The thing I don't like about the Eco Boost is the amount of heat it puts out towing. This thing gets real hot just towing locally. As much as I love the comfort of it, I just don't feel too comfortable towing with it for 6+ hrs. My other vehicle is a F350 6.0, but I'd like to use the Explorer sometimes.
Thanks in advance
sammy77 is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
My 2013 Ford Explorer Sport was ordered today NY1PR2012 2016 -2017 Ford Explorer Order Status Threads 34 02-01-2013 12:20 PM
Read my (2013 Explorer Sport) mind zackcrazy Stock 2011 - 2016 Ford Explorer Discussion 6 10-23-2012 12:13 AM
2007 Explorer Sport Trac Press Kit Rick Auto Industry News 46 10-14-2010 07:42 PM
Bilstein Shocks..... ornithology Stock 1995 - 2001 Explorers 9 03-13-2009 12:46 AM
2002 Explorer: Many refinements and new devices Rick Auto Industry News 2 03-08-2004 02:26 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
