#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2011 - 2017 Ford Explorer 5th Generation Explorer > Stock 2011 - 2016 Ford Explorer Discussion
Notices
Stock 2011 - 2016 Ford Explorer Discussion 2011 - 2016 Ford Explorer reviews, problem solving, maintenance, TSB, service bulletins, owner reviews, specifications, Ecoboost.
Advice on Replacing Side Mirror 2013 Explorer
Reply
Thread Tools
Old 01-25-2013, 04:20 PM   #1
bob61
Illinois
2013 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Short story, wife broke mirror on 2013 Explorer, 2,000 miles. Egads....
So long story and looking for advice. Dealer wanted $536, $416 parts plus $120 labor (1 hour). I picked up new mirror on Ebay for $250, dealer said they would install if I brought it in. It doesn't need to be painted, so +1 on that!
Dealer said door panel needs to be pulled, yada, yada, yada that's why 1 hour labor. Anyone replaced the side mirror? Does the whole panel need to be pulled or is there easier way to get to the bolts to remove the nuts? How difficult is it to replace this myself?
Thanks
bob61 is offline   Reply With Quote
( Join the Elite Explorers )
Old 01-25-2013, 08:48 PM   #2
peterk9
Ottawa, Ontario area
peterk9's Avatar
2014 Lincoln MKT AWD
Vehicle Specs
Quoted: 1938 Post(s)
Thanks
Not knowing exactly the type of mirror you have, fordparts.com lists them from $283 to $525 so $250 is less than the least expensive one. Good luck. It seems to me that I read a post that mentioned that the door panel had to be removed.
__________________
Peter 2014 Lincoln MKT, 201A, 3.5L Ecoboost.
Previous rides;'99 Windstar; '02,'06 & 09 4WD Toyota Highlander Limiteds & 2011 AWD Explorer Ltd.
peterk9 is online now   Reply With Quote
Old 01-25-2013, 09:39 PM   #3
bob61
Illinois
2013 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Quote:
I had checked out Ford Parts, it's part #BB5Z17683BA. Same price as dealer (dealer price is with tax). Another seller on Ebay has this same part for $290 so better deal to be had on Ebay for this Ford Part. I've looked at the door panel and was hoping there was alternative to getting the black plastic panel off instead of removing the whole panel. With all the switches and such I think I'll have to dip into the wallet to have dealer do the job.
Old 01-25-2013, 10:36 PM   #4
cnsheets
2011 Explemoner
Vehicle Specs
Quoted: 0 Post(s)
No, the whole panel does not have to be removed, just the black piece that sits above the panel. The screws holding the mirror on sit behind that. Do a search, someone else did a mirror replacement and thats all it took.
cnsheets is offline   Reply With Quote
Old 01-25-2013, 11:21 PM   #5
bob61
Illinois
2013 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Quote:
From the replacement part I can see it should be easy to replace if I can get to the bolts/nuts. I had done several searches and haven't found info on how to remove the black plastic cover. The dealer then said they had to remove the panel so I thought I'd ask here. Seems like it should be simple, just can't figure out how to get the panel off.
Old 01-25-2013, 11:51 PM   #6
cnsheets
2011 Explemoner
Vehicle Specs
Quoted: 0 Post(s)
Did you try pulling on it? Seriously......there are 3 clips that hold it on. Get your fingers slightly behind it and pull.....There are TWO nuts that hold the mirror in place.....just dont drop the nuts, otherwise you will be pulling the door panels off.....but for those, its just 2 screws and a bunch of clips also....
Took me more time to take the pictures and right this post than it did for me to pop it off.......
Old 01-26-2013, 08:34 AM   #7
bob61
Illinois
2013 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thanks for the response. And yes, I did try to pull on it and saw that it had some movement. But before I started to pull on it and have something snap off trying to pry it off I thought I'd ask first. As dealer told me they had to pull the door panel I wasn't sure if there might be some attachment under the panel for this plastic cover. After seeing how Ford f'd up easy access to the fuse panel nothing would surprise me.
Thanks again!
Old 01-26-2013, 11:12 AM   #8
peterk9
peterk9's Avatar
Vehicle Specs
Thanks for jumping in with that cnsheets. I wasn't sure about that part. I do recall a post where someone mentioned that there were screws by the armrest that had to be removed but I could not recall if it was for the mirror access or not.
The old memory banks are not what they used to be.
__________________
Old 01-26-2013, 06:17 PM   #9
cnsheets
2011 Explemoner
Vehicle Specs
Quoted: 0 Post(s)
If you need to remove the entire door panel, there is a screw behind a cover at the door pull handle of the armrest area, and a screw behind a cover that sits behind the door release lever, then the rest are just clips...but for mirror, its just the top black panel as shown in the picture.
Old 01-17-2015, 11:49 PM   #10
hpad06
Vaughan, Ontario
2011 Explorer
Vehicle Specs
Quoted: 11 Post(s)
My explor r is base model, can I replace the basic model mirror with oem heated mirror ?
Is it fully compatible ?
hpad06 is offline   Reply With Quote
Old 01-17-2015, 11:59 PM   #11
peterk9
peterk9's Avatar
Vehicle Specs
I think that you can probably interchange them but whether you can make it work is another issue. The heated mirrors work in conjunction with the rear defrost.
__________________
Old 01-18-2015, 08:11 AM   #12
hpad06
Vaughan, Ontario
2011 Explorer
Vehicle Specs
Quoted: 11 Post(s)
Any idea if it is the same plug ?
The heated mirror seems all come with signal and blind spot sensor which do not exist on the basic model
I really want to have heated mirror for Canadian winter and since wife broke the mirror , thinking if I can get heated mirror it might not be a bad thing
Old 01-18-2015, 09:46 AM   #13
peterk9
peterk9's Avatar
Vehicle Specs
On Fordparts.com the mirrors all look the same although part numbers are different. Unless someone here has first hand knowledge regarding the plug, it may be an idea to contact your dealerships parts department. They may have more detailed info. Good luck.
__________________
Old 01-18-2015, 03:28 PM   #14
hpad06
Vaughan, Ontario
2011 Explorer
Vehicle Specs
Quoted: 11 Post(s)
Thanks Peter, I looked at the youtube video again and compare with mine, I notice my car has less wires - only 3. So I think it is the same plug, but because the connection wires are not available, I won't get these features even I put on a heated mirror.
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
98 Ford Explorer xlt passenger's side is 1-1/2" higher than the driver's side. dflickinger Stock 1995 - 2001 Explorers 5 01-04-2016 07:27 AM
Modifying Ford Explorer Leaf Springs for Lift using F-150 Leaf Springs Bronco638 Explorer - Ranger Shocks, Suspensions, Lift Kits 209 08-13-2015 09:57 PM
Superlift Install Instructions-Ranger-BII-and Explorer 83-97 Tbars4 Explorer - Ranger Shocks, Suspensions, Lift Kits 0 01-21-2010 03:20 PM
2008 Ford Explorer Features Rick Auto Industry News 22 08-23-2007 12:49 PM
Advice Needed: 99 Explorer Limited Pirate New Member Introductions 1 08-19-2004 01:34 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
