#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Ranger - Mazda B-Series Forum > Ford Ranger - Mazda B-Series Forum
Notices
Ford Ranger - Mazda B-Series Forum Ford Ranger and Mazda B Series forums. The Mazda B2300 B3000 and B4000 are clones of the Ford Ranger, with all systems the same. The only differences are trim and a few body parts. This forum discusses Ford Ranger and Mazda B series specific issues. Owners of the older Mazda B2000 B2200 and B2600 are welcome as well.
1996 Ranger - No power to ignition, get a load of this...
Reply
Thread Tools
Old 01-26-2013, 05:29 PM   #1
RacerXGTO
California
1996 Ranger 4 Banger
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I make this entry for posterity. I've also been lurking around here and have found a great source of help working on my own Ranger, perhaps my findings will help others as you've helped me.
_____
Problem - No power to ignition switch. Cab lights work, headlights work, everything else works, but absolutely no power to the ignition switch for ignition or accessories.
Checking the basics - Fuses, OK. All fuses have ohms continuity, power is getting to the Ignition 50A engine bay fuse box. All the fuses in the PCM(interior fuse box) check out OK and power readings are taken by the fuse box. Fusible links and wires to relay check out OK
Checking the ignition switch under the steering wheel -
Using a power meter, no power readings can be made from ANY of the four hot yellow wires.
When I got to this point, I was about ready to go thermonuclear. My hatred toward Ford was about to go off the scale. All I could envision was something buried deep in the wire harness that required the entire dashboard to be pulled out just to get to a stupid short. But then I thought, forget it, I'll just run a 10 gauge wire from the battery, fuse it with the 50Amp fuse and run it right to the switch. Another part of me said, jiggle something and see what happens. I jiggled the ignition harness wire and heard some arcing noise inside the harness. Ah! Ok, so this may be within reach. I disconnected the battery (-) and began carefully cutting off the harness wrap back exposing all the yellow hot wires and low and behold the culprit was found. You just cannot make this stuff up. In all of Ford's brilliance, they hot crimped the four switch wires together and then wrapped the hot ignition wire from the fuse box together inside the harness. No bridging block, no connector, just wrapped. And as many miles of bumps, potholes would have it, eventually it came undone and ceased all power to the switch. I made the repair as shown in the pictures, wrapped my wire lug good so it wouldn't ground out on the steering column by accident. I took a Dremmel wire wheel attachment and brushed all the copper wire good. They were all crudded up with that sticky wire wrap, so I wanted to ensure a solid electrical connection with bare copper touching bare copper before sliding on the wire lug nut and sealing it shut. Double checked my work, reconnected the battery, started right up.
RacerXGTO is offline   Reply With Quote
( Join the Elite Explorers )
Old 01-27-2013, 12:49 AM   #2
Jack Flash
Ethel, MS
(3) '88 BII's, '99 Ranger
Vehicle Specs
Quoted: 2 Post(s)
I like the wire lug repair. never would have thought of that ! now I have more ways to repair similar disconnects.
__________________
Jack of All Trades
Retired From Most
www.internationalcuemakers.com
www.jimboarmy.com
Latest Project: '86 Ranger 4X4
Jack Flash is offline   Reply With Quote
Old 01-27-2013, 07:59 PM   #3
McCormack
S.E. WI
2000 Ranger
Vehicle Specs
Quoted: 3 Post(s)
Thanks for sharing. Ford doesn't seem to be real proficient at designing wiring, because a couple of years ago I could only get one speed out of my heater/AC blower motor, and after checking all the obvious stuff I couldn't figure out what was wrong so I took it to the stealership, and $230 later it turned out to be a wiring harness connector. Not one of Ford's better ideas.
McCormack is offline   Reply With Quote
Old 01-29-2013, 12:16 AM   #4
RacerXGTO
California
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
heh, weeding out electrical Gremlins is no picnic. I jokingly tell myself these are all descendants of the Pinto, it could blow at any time.
:p
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
1994 ford ranger / 1996 ford explorer - ok, i give up... worthspending Modified 1991-1994 Explorers 1 09-09-2012 11:15 PM
just bought a 1993 ranger and have no power steering please help! fordnut96 Stock 1991 - 1994 Explorers 3 04-03-2012 07:26 PM
97 Ford Ranger ABS light on since power steering hose broke gzydek New Member Introductions 1 11-29-2011 04:44 PM
Ranger with a 2.3L has no power. rocket-ron Ford Ranger - Mazda B-Series Forum 10 11-19-2009 07:10 PM
Help with bad gas mileage and no power from OHV Ranger scruff Under the Hood 14 02-26-2008 11:29 AM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
