lmbaker
- January 20, 2013
- Fort Sill, OK
- 92 Explorer XLT
http://www.moates.net/ will find tuning products and EEC Editor
I went this path for my sohc conversion in my first gen. It is extremely expensive and complicated. But the problem I see with your plan is simple.
If your whole reason for doing this is gas mileage, why are you using a batch fire fuel injection computer. If you want to get better mileage out of a 91-93 OHV its simple switch to a 94 ecu witch uses SEFI. It will require rewiring the injectors and repining the ecu connector. but well worth it.
Edit: forgot to add you will have to add a cam position sensor and a big bonus is you get a second o2 sensor.
Hi, Carguy3J
Here is your ECU(computer) wiring diagram.
Here is a 1994 ECU wiring diagram. (notice how the injector wiring changes)
The problem is Ford never put a CMP-camshaft position sensor (be careful CPS means crankshaft position sensor in ford lingo) on the rangers in these years (federal emissions) for some reason. I have yet to find out if the Ranger ECUs are capable of using SEFI(sequential fuel injection).
But if you want to switch to SEFI here is what I think you have to do,
Disclaimer:
(this is where I am at on my project so I do not have the data to confirm this, but from studying the wiring diagrams and the Ford documents this is what I have come up with. I will post a whole thread on my findings on one of the forums ((most likely this one since is has helped me the most)) when I finish my project. I keep with the same user name so it will be easy to find).
Ok the switch from EFI (batch fire fuel injection, basically this means each bank of injectors opens at the same time ((for 4.0L OHV CYL. 1,2,3 injectors open and inject fuel when #1 is on intake stroke. This means CYL. #2 and #3 have fuel just sitting around until they are back to the intake storke.)) I believe this is not a huge deal on high RPM but at idle and in town driving this would be completely wasteful.)
To SEFI (sequential Fuel Injection, this is what I am working to get and solve for us first gen guys!This would mean the injectors only open when each cylinder is on the intake stroke. I do not see how this would not be beneficial through out the whole RPM range but once again I do not own a dyno or have numbers to back this up).
Okay enough messing around as I am sure you already know all of this I just want to make sure we are on the same page when I explain this.
Here is what you have to do, once more there may be more to this I will be expand on it more as I go.
If you have a manual(standard) transmission (I have no idea about automatics since I do not play with those, but this should apply the same, you just might have to change the pins on your ECU, DO YOUR HOMEWORK OR YOU WILL FRY YOUR ECU) ranger or explorer that is a 4.0L OHV from 19xx to 1993 (1993 explorers are supposed to have a CMP but are not wired for SEFI, I do not get this as the only purpose for the CMP is SEFI confuses the heck out of me. Can some one explain that to me??)
But anyway back to the point, you need to find yourself a 1994 ECU from an explorer even if you have a Ranger.(If your vehicle is a manual find a manual fed emission ECU, or if you have an automatic find an automatic ECU. The Ford federal emission ECU for manual trans. part number is F47F-12A650-KA or F47F-12A650-KB).
Then after you find yourself the right ECU you will need to rewire your injectors(so each one goes to the ECU on the ground side they each have separate pins on the ECU), wire in a CMP to pin 33, and a second o2 sensor if you do not have one, you also can wire in a EGR vacuum regulator off of pin 24 if you want one, pin 60 an 40 coming off of the ECU now will be a combined ground I don't understand this yet?, and the MAF no longer grounds to the ECU.
Edit #1 forgot 1994 wiring diagram.
JD,
I keep looking at this and thinking to myself that it seems so easy to just swap a computer and add an extra O2 sensor and CPS and away I go. From what I see here, it is as simple as that.
On the other hand, sometimes there are super simple fixes that make world of differences, why couldn't this one be one of them?!
Good question JD. I think we should ask '94 Explorer owners to take a look at the color of the wiring on the injector harnesses and see what they are for each position. I can't see any way to ascertain which from the schematics.
Looks like you all ready did this JD. Thanks!
