Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2006 - 2010 Explorer Mountaineer 4th Generation > Stock 2006 -2010 Explorers
Notices
Stock 2006 -2010 Explorers Stock 2006 -2010 Ford Explorer Forum. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Key FOBs program but won't work
Reply
Thread Tools
Old 03-20-2013, 05:10 PM   #1
thoyer
Warminster, PA
2008 Explorer
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
2008 Explorer. Two key fobs both stopped working at the same time. Reprogrammed the remotes as a pair, they both work during reprogramming. Cycle key 8 times, locks cycle, press remote button, locks cycle, turn ignition off, locks cycle. Press button on either remote, nothing happens. Repeat above sequence, same result.
It appears like the FOBs are being recognized during programming, but do not work after programming.
I'm open for ideas?????
Thanks,
Tom
thoyer is offline   Reply With Quote
( Join the Elite Explorers )
Old 03-20-2013, 05:21 PM   #2
FROADER
Moderator
Huntington Beach, CA
FROADER's Avatar
2010
Vehicle Specs
Quoted: 64 Post(s)
The same thing happened to me (2010) last week. I even ordered new FOBs from Amazon. Before you do that, try this. I disconnected my batter for 30 seconds, reconnected and the FOBs work... Weird I know, but it's worth a try.
FROADER is offline   Reply With Quote
Old 03-20-2013, 07:26 PM   #3
thoyer
Warminster, PA
2008 Explorer
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
Quote:
Good idea. I'll give it a shot and report back.
Thanks
Old 03-21-2013, 03:10 PM   #4
FordService
Official Ford Rep
Dearborn, MI
FordService's Avatar
2014
Vehicle Specs
Quoted: 307 Post(s)
Quote:
Thanks
Hi thoyer,
I wanted to touch base with you and see how your key fobs are doing. Any updates?
Crystal
__________________
FORD SERVICE
p: 800.392.FORD
t: @FordService @Ford
f: facebook.com/FordExplorer facebook.com/Ford
FordService is offline   Reply With Quote
Old 03-23-2013, 02:05 PM   #5
thoyer
Warminster, PA
2008 Explorer
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
Quote:
Originally Posted by FordCustSrvc View Post
Hi thoyer,
Crystal
I finally got some free time today so I disconnected the battery for a minute or so. I took the opportunity to clean the battery terminals. Reconnected and the FOBs now work.
Thanks for the suggestion FROADER.
Tom
Old 03-23-2013, 11:28 PM   #6
FROADER
Moderator
FROADER's Avatar
2010
Vehicle Specs
Quoted: 64 Post(s)
Awesome! Glad it worked for you too.
Old 03-24-2013, 06:37 PM   #7
thoyer
Warminster, PA
2008 Explorer
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
Well, it worked for ONE day. This morning I went to get in the vehicle and neither FOB worked............... again...............
So, looks lie disconnecting the battery was a Band-Aid. Any more ideas on how to fix this for good?
Tom
Old 03-24-2013, 07:04 PM   #8
FROADER
Moderator
FROADER's Avatar
2010
Vehicle Specs
Quoted: 64 Post(s)
Interesting. Mine still works and its been 2 weeks. Hopefully you can figure something out.
Old 04-07-2013, 07:19 PM   #9
thoyer
Warminster, PA
2008 Explorer
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
Hi thoyer,
Crystal
I had some time today to work on this a bit more. Tried disconnecting the battery but this time it made no difference. Reprogrammed the FOBs after reconnecting the battery. Each programmed just fine, but still would not lock/unlock the car after exiting program mode.
I have all three factory service manuals for this Explorer but could not find any references to the key FOBs and how to troubleshoot them. I did check for codes with my scanner and there were non.
What module controls the interface with the key FOBs?
Tom
Old 04-08-2013, 01:29 PM   #10
FordService
Official Ford Rep
Dearborn, MI
2014
Vehicle Specs
Quoted: 307 Post(s)
Tom
Hi Tom,
Since I'm not a mechanic, I'm not the best resource for technical advice. If you're still running into issues, I recommend making an appointment at your dealership; they'll be happy to help!
Crystal
__________________
FORD SERVICE
p: 800.392.FORD
Old 08-12-2014, 01:28 PM   #11
show13
Atlanta, GA
2010 Explorer - XLT 2WD
Vehicle Specs
Quoted: 0 Post(s)
Had the same problem. Disconnected the battery, waited for 30 seconds, programmed the remote and it's been working ever since. It's been 3 weeks.
show13 is offline   Reply With Quote
Old 08-12-2014, 03:05 PM   #12
FROADER
Moderator
FROADER's Avatar
2010
Vehicle Specs
Quoted: 64 Post(s)
It happened to me again. Not really sure why it's happening so often, but disconnecting the battery worked again.
Old 08-13-2014, 09:47 AM   #13
Flag Gibby
Flagstaff, AZ
2006 Mountaineer AWD
Vehicle Specs
Quoted: 171 Post(s)
Sounds like it has to do with the receiver on the vehicle getting locked up or something since the FOBs work once you do a hard reset on the system.
Oh, and what's up with all the scripting going on with this site lately... it keeps locking up my browser and making it run so slow here???
Flag Gibby is offline   Reply With Quote
Old 08-13-2014, 11:33 AM   #14
wsar10
Central, PA
several JEEPS
Vehicle Specs
Quoted: 4 Post(s)
X2...
this is by far the worst forum for scripting and ads.....
__________________
06' XLT
good old German engineered 4.0
90k mi
wsar10 is offline   Reply With Quote
Old 08-13-2014, 02:41 PM   #15
Tech By Trade
Your mom's house
07 Sport Trac
Vehicle Specs
Quoted: 190 Post(s)
If you are running firefox throw on adblock plus. Kills em all.
Tech By Trade is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Key doesn't work on either of my explorer hatches Shylock Stock 1995 - 2001 Explorers 8 10-27-2013 03:38 PM
Key won't work in door lock!?!?!? exploration1997 Stock 1995 - 2001 Explorers 18 11-09-2012 09:07 AM
2002 Explorer XLT. Problems with programming key fobs. ianweb Stock 2002 - 2005 Explorers 2 06-30-2011 09:29 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
