Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
Replacing the heater coil
Reply
Thread Tools
Old 03-28-2013, 02:24 PM   #1
sk
ocala, fl
96 xlt
Vehicle Specs
Quoted: 2 Post(s)
(Original Poster)
Trying to replace the heater coil in my 04 Explorer. Haveing trouble getting the dash out to get to it. Have all the trim off and radio out but can't get the passenger trim off the A post because of the "oh crap" handle.
Any suggestions?
sk is offline   Reply With Quote
( Join the Elite Explorers )
Old 03-30-2013, 08:42 AM   #2
FordFool2
Cedar Rapids, IA
04 Eddie Bauer & 13 Ltd
Vehicle Specs
Quoted: 37 Post(s)
There should 2 round covers on the A pillar trim that you need to pop off with a small flat blade screw driver. They may be hard to see from inside the vehicle but very obvious if you look through the windshield. The handle is held on with 2 small bolts or nuts.
FordFool2 is offline   Reply With Quote
Old 03-30-2013, 09:03 AM   #3
sk
ocala, fl
96 xlt
Vehicle Specs
Quoted: 2 Post(s)
(Original Poster)
Actually found thoe and got it done. Thanx.
Now my problem is that I have discovered it isn't the heating coil at all but the Blend Door that has to be replaced. Basically the same job but having trouble getting the dash out. Any ideas, shortcuts, or suggestions would be appreciated.
Old 03-30-2013, 09:05 AM   #4
rrgone
Tucson, AZ
'02 XLT
Vehicle Specs
Quoted: 22 Post(s)
Look up in the 'stickies'. There's a good detailed thread there. No need to pull the dash.
rrgone is offline   Reply With Quote
Old 03-30-2013, 09:08 AM   #5
sk
ocala, fl
96 xlt
Vehicle Specs
Quoted: 2 Post(s)
(Original Poster)
Awesome Thanx
Old 03-30-2013, 09:48 AM   #6
Exproblems
Orchard Park, N.Y.
'05 Explorer XLT 4.0L
Vehicle Specs
Quoted: 85 Post(s)
Quote:
In your OP, I think you meant to say heater "core", not "coil". Below is the link to the sticky thread with the Temp Blend Door repair. Look at page #1 and post #1 from "BigRondo". Has all the photo's you'll need with instructions to do the repair.
http://www.explorerforum.com/forums/...d.php?t=294140
Exproblems is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
2006 - 2008 Ford Explorer Ignition Coil (Set of 8) for V8 4.6L 1ATony Explorerforum Vendors 0 08-24-2012 10:23 AM
2006 Mecury Mountaineer ignition coil question. jcallanan Stock 2006 -2010 Explorers 17 02-20-2012 11:32 AM
2002 - 2005 Ford Explorer Ignition Coil (SET of 8) for 4.6L V8 1ATony Explorerforum Vendors 0 12-21-2010 01:02 PM
1991 Ford Explorer Heater Bypass Valve Installation shamaal Explorer, Ranger, A/C & Heater systems HVAC 6 05-31-2010 08:30 PM
Replacing Coil springs with leaf springs audiodude332001 Explorer - Ranger Shocks, Suspensions, Lift Kits 2 08-04-2004 06:28 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
