Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
5R55E Transmission Fluid Change
Reply
Thread Tools
Old 04-23-2013, 02:34 PM   #1
AP9
Chicago SW suburbs
2000 XLT 4WD, 4.0L OHV V6
Vehicle Specs
Quoted: 15 Post(s)
(Original Poster)
Lightbulb 5R55E Transmission Fluid Change
Though I've read varying versions of the story, in general it seems as though a pressurized or reverse-flow transmission flush is a bad idea in these transmissions, as it can cause sludge or other contaminants to clog or damage valve bodies and solenoids.
There are even those who will go a step further and say that just replacing fluid will cause trouble, since the existing transmission fluid may already be supersaturated (fully saturated during "hot" operating conditions) with contaminants that have settled, and the fresh detergents in the new ATF will stir up these settled deposits which could then cause problems before they even get to the filter.
So I was thinking: if existing garbage in the system is really that big of an issue, why would "flushing" the system with an excess of fresh ATF be problematic? Sure it may not prevent ALL problems, but it would reduce the likelihood.
Here's my logic:
Pull the pan, clean it out, and change the filter. Then attempt a slightly modified version of the following procedure:
http://www.explorerforum.com/Singlet...pages/at1.html
not pinching the hose or restricting flow (which I'd think would cause undesirable backpressure or unintended upstream turbulence in the transmission), but rather using a large new bucket of ATF, and a large waste bucket of "old" ATF. And by "large new bucket of ATF" I'm talking about one of the 5-gallon pails you can buy Dex/Merc in. Maybe even add some transmission additive/cleaner to it. Then, when that 5-gallon pail is getting close to empty, throw in 12 or so quarts of good Mercon V, and stop once that's in the transmission. Then flush out the TOC and lines so cooler contaminants are removed at the same time. Top off with Mercon V as needed.
That way, a full five gallons of "fresh" ATF flows through the transmission to pretty much guarantee that all old fluid gets out, and hopefully carry with it any other garbage that's not accessible by just dropping the pan and changing the filter--even if it gets stuck further downstream in something, that's 5 gallons of flow so hopefully it'll get knocked out eventually. At the same time, nothing in the transmission is subjected to abnormally high fluid pressures or incorrect direction of flow. Sure it would be a bit expensive and kind of a waste of ATF, but a lot cheaper than a transmission rebuild--and the ATF can be recycled anyway. Who knows, maybe some of the "later" batch of the ATF to come out could be recaptured and used in the power steering or something if it's clean enough.
Want to know what other peoples' thoughts are on this. Pointless? Good idea? Terrible idea? Waste of money?
AP9 is offline   Reply With Quote
( Join the Elite Explorers )
Old 04-23-2013, 03:31 PM   #2
my98nnj
Boonton, New Jersey
1998 XLT
Vehicle Specs
Quoted: 71 Post(s)
It's a 13 year old transmission and while I don't agree or disagree with the change the fluid and it quits myth, I do think you should be careful.
FYI - Here's my yearly fluid change process. Disconnect the upper tranny cooler line from the top of the radiator. Plug the radiator end, put a hose on the line coming from the tranny and route it into a gallon container.
Start the engine and let the gallon container fill up, then shut it down. Add 4 quarts and reconnect the cooling line.
Been doing that every year since I've owned the truck. Takes 10 min, no mess and the fluid properties aren't drastically altered with this method.
If your fluid is dirty, I'd put a schedule of monthly in place until it clears up.
Good luck!
my98nnj is offline   Reply With Quote
Old 04-23-2013, 04:38 PM   #3
2000StreetRod
Greenville, SC
2000StreetRod's Avatar
00 Sport FI,03 Limited V8
Vehicle Specs
Quoted: 45 Post(s)
5r55e flush complications
According to available documentation the external cooling loop on the 5R55E does not open until the temperature in the torque converter reaches 150 degrees F. However, thru simple experimentation I learned that even at cold engine start if the external cooling loop is broken, there will be ATF output flow from both the inlet and the outlet lines. The flow from the outlet line exceeds the flow from the inlet line.
The external cooling loop only circulates a portion of the ATF in the transmission. It will take considerable flow to replace most of the fluid in the transmission. The system works comparable to a low flow bypass engine oil filter.
2000StreetRod is online now   Reply With Quote
Old 04-24-2013, 12:39 PM   #4
AP9
Chicago SW suburbs
Vehicle Specs
Quoted: 15 Post(s)
(Original Poster)
Good luck!
Basically only taking some of the old fluid out and "diluting" it with new fluid, though allowing the TOC & lines to drain as well? I'm assuming that too much of a sudden change in transmission fluid properties could cause problems or require the transmission to retrain shift points and behavior?
So this means that only once at operating temperature, the pump starts going or increases its flow? Perhaps just a simple thermostat? In that case, even five gallons of "pusher" ATF may not be enough to get all the old fluid out. Hmm....
Old 06-05-2014, 01:12 PM   #5
skipperj
Titusville,Fl.
2002 Explorer vin K
Vehicle Specs
Quoted: 0 Post(s)
I say that's good advice.And one thing that I've been doing with good results (on trans. that don't have one),is to install a 3" by 1/4 to 1/2" donut magnet in the bottom of the pan.Locate it away from any solenoids.Mix a little batch of JB Weld and install.It is a passive way of getting rid of ferrous metal particles from continuously circulating with the fluid.It will catch any size iron based particle,something the filter can't do.Don't put it near the inlet of the filter as the flow is too fast.It's a "passive" way of catching THE most damaging metal (steel or Iron),you can have in the fluid.I learned this trick back in the 80's when I worked at a GMC Truck dealership.It was an addon kit from the factory for heavy duty automatic tansmissions.Proven to lengthen the life of the trans.Because they were failing inside the warranty period.This trick,got more miles & time to get them out of warranty.That is what they told me.Was it crooked? Depends on how you look at it I guess!Next time you drop the pan,you'll see what's what,believe me.
skipperj is offline   Reply With Quote
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
transmission flush or just fluid change? Bandido Under the Hood 25 08-05-2015 06:12 AM
Troubleshooting Transmissions dallasmef Explorer & Ranger Transmissions, Transfer Cases, & Differentials 21 04-08-2015 12:51 PM
OBD-II Diagnostic Trouble Codes (DTCs) BobWiersema EEC V 8 03-26-2013 10:22 PM
When to change the transmission fluid in a 5R55E (5 speed automatic) on a 2000 Sport? BigE Stock 1995 - 2001 Explorers 4 07-16-2005 03:50 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
