Welcome to the Forum GPS.:wavey:Hi guys
Anyone knows which relay flasher needs to be install in the 2013 Eco Explorer for install led bulb without flickering?
Thanks!!!
Is it possible that the hyper flash can be turned off in the BCM like the F-series trucks, the turn signal switch is opperated the same on both trucks,
Not sure what you mean by 'hyper flash'. There is no way that I'm aware of to adjust the flash rate of the turn signals on the Explorer.Is it possible that the hyper flash can be turned off in the BCM like the F-series trucks, the turn signal switch is opperated the same on both trucks,
Thank you. I guess I should have read back up the thread a bit. I thought the talk was about our regular turn signal lamps and couldn't understand why they would be in 'hyper' mode. I guess I shouldn't reply to posts as I'm about to shut down and go to bed.Hyper flashing is when the flashing is faster than normal. It makes it look like police lights flashing.
As indicated in my PM, I have merged your post with the existing one you probably referred to. There is no need to begin a new post.There was a debate on another thread as to whether the relay in the fuse box actually controlled the flasher rate on the Explorer or whether the computer does it.
Has anyone swapped the relay out for any other type of relay? The new Range Rover's flashers do a double blink which I think is much more attention grabbing and I would love to be able to fit to my Explorer if it's as simple as swapping a relay.
So instead of the flashers going on---off---on---off---on---off they instead go on-on---off---on-on---off---on-on---off
