Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Oil leak on exhaust manifold bolt
Reply
Thread Tools
Old 05-13-2013, 02:44 PM   #1
10pound
San Diego CA
2001 Explorer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Hi everyone and thanks in advance for reading, I sincerely appreciate any insight you can offer into my problem.
My wife has a 2001 Explorer with the 4.0 v6. For the past few months, after driving it, one would smell that distinctive aroma of oil sizzling into vapor coming from the engine. Oil level never dropped and it wasn't that big of an issue at the time, so I didn't look that hard for a leak. Last night, I drove it to the 7-11 around the corner and when I returned, I noticed vapor/smoke coming from under the hood. This morning when I could actually see something, I hosed the motor down with degreaser and water, started it up and waited for the aroma and vapor to return. I didn't have to wait long. It appeared as though oil was dripping down onto the exhaust manifold on the driver's side. Closer inspection shows the oil emanating from the lower exhaust manifold bolt for cylinder 6 (the rearmost cylinder on driver's side). At first I thought that perhaps the PCV valve was leaking some oil down onto the bolt but I couldn't find anything other than dirt around the PCV valve. I cleaned it all off again, especially this exhaust manifold bolt, started it back up and got underneath the vehicle where I could watch this bolt. Sure enough, I watched it go from clean to oily within minutes. I could actually see as the oil began to well up to a point where it would then drip down onto the manifold right where it connects to the catalytic converter.
Here is an image showing the bolt/threads with a drop of oil welled up on the end of it:
Anyone have an idea of what I am facing here? I run synthetic 5w-30 through it and change it regularly. Any insight, assistance or opinions are much appreciated.
10Pound
10pound is offline   Reply With Quote
( Join the Elite Explorers )
Old 06-14-2013, 10:55 PM   #2
lobo411
1996 Explorer 4.0 OHV
Vehicle Specs
Quoted: 107 Post(s)
Quote:
10Pound
How about the valve cover gaskets? I just installed new ones on my 96 4.0 tonight...sadly, mine were actually in like new condition after 7 years, and it wasn't till I had the car torn to pieces that I figured out it was the PCV valve leaking the whole time.
lobo411 is online now   Reply With Quote
Old 06-14-2013, 10:59 PM   #3
nitrodude
97 ford explorer
Vehicle Specs
Quoted: 0 Post(s)
I've got the same leak on my 97.
Hopefully one of us finds the culprit!
nitrodude is offline   Reply With Quote
Old 06-29-2013, 07:50 PM   #4
nitrodude
97 ford explorer
Vehicle Specs
Quoted: 0 Post(s)
Any luck finding the leak 10pound?
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Possible exhaust manifold leak? Fire488 Stock 2006 -2010 Explorers 7 05-28-2013 07:50 AM
01 explorer exhaust manifold leak and removal question. 01explorerv801 Stock 1995 - 2001 Explorers 7 06-02-2009 01:49 PM
Hold-A-Bolt Trick... ExplorerDMB Technician's Tips and Tech 12 05-01-2008 06:35 AM
Exhaust manifold Leak nissanboy Under the Hood 2 04-27-2005 04:18 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
