Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
2000 mountaineer v8 to v6 swap
Reply
Thread Tools
Old 05-29-2013, 10:19 AM   #1
deloacda
2000 Mercury MountIneer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
How much trouble would it be to put A 2000 mountaineer 302 AWD motor in a 2000 mountaineer V6 AWD? I have an opportunity to buy a 2000 v6 in excellent shape that soesnt run. I want to put my motor in it. Would it be more trouble than its worth.
deloacda is offline   Reply With Quote
( Join the Elite Explorers )
Old 05-29-2013, 11:02 AM   #2
koda2000
Georgia
2001 Explorer EB 5.0L
Vehicle Specs
Quoted: 1150 Post(s)
edit: sorry I read your post backwards...
I think it would be more trouble than it's worth.
__________________
I reject your reality & substitute my own...
2001 Explorer Eddie Bauer 5.0L V8 2WD
2000 Mountaineer 5.0L 2WD/2000 Expl XLT 5.0L 2WD
2000 Mountaineer 5.0L V8 AWD, 2001 Expl Sport Trac
2001 Explorer XLT 4.0L SOHC V6 auto 2WD (RIP 5/13)
1997 Explorer Sport 4.0L SOHC V6 auto 2WD
koda2000 is online now   Reply With Quote
Old 05-29-2013, 01:14 PM   #3
FIND
Vermillion, SD
99 XLT V8 AWD
Vehicle Specs
Quoted: 10 Post(s)
V6 trucks are not AWD, they have electronic automatic 4wd.
V6 uses a different transmission and transfer case, the 302 won't bolt up to it. You would need to change all harnesses, including several body harnesses. Look up some of the other V8 swaps on this site. Generally, when it comes to 4 door trucks, it isn't worth it, because you can just as well go and find another clean v8 4 door. But, there are a bunch of V8 swaps into sports on here.
You would be better off using the V6 truck as the parts truck and donating to your currently running V8.
__________________
I strongly abide by the motto, "Safety third."
Quote:
Originally Posted by NICE59FORDF100 View Post
Dont forget numbers. Teacher Ladies LOVE numbers
FIND is offline   Reply With Quote
Old 05-29-2013, 01:20 PM   #4
B2-Bomber
SL,UT
1988 V8 EXPLONCO FW SAS
Vehicle Specs
Quoted: 0 Post(s)
IIRC the 4.0 ohc v6 was 210 hp, and the AWD 5.0 id 220hp? so a power increase of 4.5% ? the numbers alone would make it a pointless swap.
I've had a 1998 5.0 ex, and a 2000 ohc 4.0 ex. I liked the ohc motor better.
B2-Bomber is offline   Reply With Quote
Old 05-29-2013, 01:32 PM   #5
1992fordgreen
Inside the Rehabilitation Center
95 SC400 92 SC400 96 Ex
Vehicle Specs
Quoted: 76 Post(s)
Not recommended. Not reasonable. Not worth it. Buy another V6 Explorer instead of swapping engines...and everything in between....
__________________
1996 Ford Explorer EB SOLD 1992 Lexus SC400, 1995 Lexus SC400 SOLD, 1993 Lexus SC400, 1999 Mazda Miata, 1999 Lexus GS300, 2000 Mazda Miata SE, 2001 Toyota Sequoia, 2003 Chevrolet Suburban, 1971 Olds Cutlass SOLD 1992 Ford Explorer XLT SOLD
Quote:
Originally Posted by mattcatledge View Post
Got my 97 for $250; the previous owner thought the tranny was gone but it is actually the transfer case. They were not happy when I put it in 4 low and drove away.
1992fordgreen is offline   Reply With Quote
Old 05-29-2013, 04:47 PM   #6
vroomzoomboom
Elite Canuck STOCK SUCKS!
selkirk, manitoba
vroomzoomboom's Avatar
98 supercharged 347 sport
Vehicle Specs
Quoted: 366 Post(s)
yup. lots of work. i have done the v8 swap into my sport. motor, motor harness, cooling lines, some emissions lines, computer, ignition, pats, exhaust, trans, and transfer case. it is doable, and time consuming as well.
__________________
Stroke Me, Blow Me. 347 Stroker + M112 Eaton Supercharger = Evil
roll pan build for 1st and 2nd gen explorers
door switch LED convention
vroomzoomboom is offline   Reply With Quote
Old 05-29-2013, 04:55 PM   #7
tgibbonsfordluv
Allegan County, Michigan
96 Explorer XLT 5.0 AWD
Vehicle Specs
Quoted: 14 Post(s)
The horsepower might not be much more, but the tourque is significant.
Honestly though, this would be a real big pain in the butt. If you're buying a truck with the v8 in it, just fix it up. Would be way easier.
tgibbonsfordluv is offline   Reply With Quote
Old 05-29-2013, 04:58 PM   #8
tgibbonsfordluv
Vehicle Specs
Quoted: 14 Post(s)
Honestly, It might actually be easier to swap the bodies.
Old 05-29-2013, 05:05 PM   #9
FIND
Vermillion, SD
99 XLT V8 AWD
Vehicle Specs
Quoted: 10 Post(s)
The horsepower and torque aren't even the important part. The 5.0 and its transmission are many magnitudes more reliable, and easier to build up. If you want a 4.0 to make power, you have to go nuts on the damn thing, and you will just have timing chains to replace soon anyway, right before your transmission craps out.
__________________
Old 05-29-2013, 05:44 PM   #10
tgibbonsfordluv
Vehicle Specs
Quoted: 14 Post(s)
Quote:
When I bought my Explorer I did some looking into parts and common malfunctions. I was buying a fixer-upper off craigslist. I priced the timing chain cassettes and the labor involved in replacing them for the SOHC 4.0. You couldn't GIVE me one of them for free.
My 5.0 has got 211k miles on it, the trans is original and it is still very fast. You wanna talk modified power, slap some ported and polished heads on it and a fancy cam and you'll smoke most production sports cars. For that matter, a little time with a power programmer and you'll be running it WAY over 220 hp.
Old 05-29-2013, 06:10 PM   #11
james t
moderation
Texarkana AR/TX
james t's Avatar
94 SAS sport
Vehicle Specs
Quoted: 19 Post(s)
97-01 V8 Explorers are cheap. Like $2000 in good condition cheap. If you bill yourself at an imaginary $15 an hour to do the swap, it's going to cost you 6 grand.
You're ten steps ahead of the game if you sell what you have and buy what you want.
__________________
my rebuild
james t is offline   Reply With Quote
Old 05-30-2013, 02:26 AM   #12
deloacda
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thanks for all the replies. The issue is the v6 doesn't run that im looking at buying, but its in great shape. Im only interested in the outer body of it. My v8 is not damaged but the paint is starting to fade and crack in spots. It is wedgewood blue. the v6 is light green/tan 2 tone. I think those look the best of the mountaineers. I thought about taking it to maaco and having the repaint it 2 tone. I was afraid you would be able to tell it was originally a different color.
Old 05-30-2013, 04:00 AM   #13
FIND
Vermillion, SD
99 XLT V8 AWD
Vehicle Specs
Quoted: 10 Post(s)
Then swap bodies. Last thing you want to do is waste money on a Maaco paint job.
__________________
Old 05-30-2013, 01:15 PM   #14
B2-Bomber
SL,UT
Vehicle Specs
Quoted: 0 Post(s)
to be clear, I was talking stock-for-stock, and for street daily-driving
if you want to talk modified, none of the V6 engines are even remotely good candidates. That's why the cammed out, high compression engine under my hood isn't a 4.0 . when it comes to performance, if you want to modify it, start with a decent v8
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Highroads Long Travel Trac V8 Swap HighRoad 2001-2005 Explorer Sport Trac 39 08-13-2014 05:06 PM
V6 to V8 swap.. how different are they? PUR PONY Stock 1995 - 2001 Explorers 7 04-04-2010 07:44 AM
2000 Ranger 5.0 swap using 98 mountaineer donor phoenixisrizen Modified 1995-2001 Explorers 7 09-29-2008 02:18 PM
v8 swap freeridejunkie87 Modified 1991-1994 Explorers 2 09-12-2007 10:56 AM
V8 swap BislamJoe Offroad Explorer - Ranger Projects 25 07-18-2001 12:36 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
