Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
1991 Ford Explorer Eddie B 4X4
Reply
Thread Tools
Old 08-11-2013, 10:21 PM   #1
L.A.X
Los Angeles, Ca
1991 Ford Explorer EB
Vehicle Specs
Quoted: 54 Post(s)
(Original Poster)
I purchased a 91 for $500.00. I'm looking to get it running like it did in when it was driven off the showroom floor. I've been doing everything I can on the Ex by buying on craiglist, ebay, junkyard and bartering. I'm a father of 3 kids, 2 high schoolers so my budget is tight. This is what's been done so far. New fuel pump, cleaned gas tank and lines. New water pump, radiator, hoses, brakes, TPS sensor, cleaned MAF, throttle body, plugs, wires and removed AC. I want to take the truck on a long trip. This truck has always been stock so the majority of parts are over 20 years old. What is essential to change as far as sensors and components are concerned? The engine is running strong and the transmission was rebuilt in June 2012. I recently removed the condenser and added a transmission cooler from a F350. This is one of the best websites ever. Thanks for all your input.
L.A.X is offline   Reply With Quote
( Join the Elite Explorers )
Old 08-11-2013, 10:26 PM   #2
L.A.X
Los Angeles, Ca
Vehicle Specs
Quoted: 54 Post(s)
(Original Poster)
The engine is the 4.0 with automatic transmission, auto hubs with push button 4x4. I do all the work myself.
Old 08-12-2013, 01:04 PM   #3
awood
Kaysville, utah
94 XLT
Vehicle Specs
Quoted: 4 Post(s)
In my 94 (still a 1st gen), I replaced the O2 sensors while troubleshooting a check engine light. It didn't fix my problem, but it seemed to run better. After fixing the check engine light problem, I took it in for emission test. The tech commented on how good it was running and how good the emission test went.
I understand the O2 sensors degrade over time, and I believe the new ones helped the engine perform better. But someone with more knowledge may want to comment here....
They were pricey to replace, but I'm glad I did.
__________________
_______________________
90 Ranger (retired)
92 Explorer 4X4 (wrecked)
94 Ranger 4X4 (retired)
94 Explorer 4X4 (current)
awood is offline   Reply With Quote
Old 08-12-2013, 01:16 PM   #4
Jason94sport
South FL
93 Sport 2WD 5 speed
Vehicle Specs
Quoted: 49 Post(s)
If it's running good & isn't giving you problems I see no need to change anything just because. Do the things you should check before any long trips, cooling, oil, brakes, tires, etc.
__________________
1993 2WD Sport 5 speed
BBK TB, Flowmaster Force II Cat Back, CAI
Pioneer HU, Clarion speakers, RF R300 powered 10" sub
Jason94sport is offline   Reply With Quote
Old 08-12-2013, 02:03 PM   #5
Tony H
New York, Wading River (that's on Long Island)
'91 Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
I put 336K miles on my '91 and I didn't do half of that and it was running great when I sold it for $1500.
I'd look at other things. Brake line rust ( Rear , Drivers side) Front axle and driveshaft 'U' joints, raer axle seals... stuff like that.
P.S. this was my long range runner. This car was the one the family took to run up and down the East coast from Florida to Maine.
__________________
1975 CJ5 with fiberglass body and 350/345Hp chevy power:bought it in '79
1985 chevy stepside pickup, 300K on the clock: Original Owner
1989 Volvo 240 300K on the clock: Original Owner
the 1991 X is my newbie with 331K on the clock: bought OCT.'03 with 183K
http://home.lyse.net/brox/TonyPage4.html
Tony H is offline   Reply With Quote
Old 08-12-2013, 10:17 PM   #6
L.A.X
Los Angeles, Ca
Vehicle Specs
Quoted: 54 Post(s)
(Original Poster)
How much for OEM O2 sensors? What cars did Ford use the 4.0 on? Are heads, other parts interchangeable with my 91 block?
Old 08-13-2013, 07:57 AM   #7
Jason94sport
South FL
Vehicle Specs
Quoted: 49 Post(s)
Heads are tricky. You have a 91 so heads are weak. This is why I said coolant. If you overheat just once ever so slightly those 91 heads will crack or blow gaskets. The 94 heads are far better & then the 95-97 heads even more so. The engine was used in explorers all the way to 01. It's just the basic Ford 4.0L OHV engine. Rangers used it too.
The differences are in emissions components in later years. 94 started EGR, & some minor changes on the intake.
Think I paid around $60 for each 02 sensor.
Old 08-13-2013, 10:19 AM   #8
L.A.X
Los Angeles, Ca
Vehicle Specs
Quoted: 54 Post(s)
(Original Poster)
I've been paying really close attention to cooling issues. The cooling system received extra attention.
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Ford Explorer & Ranger Solid Axle Swap - SAS - Registry Index Randall Explorer/Ranger Solid Axle Swap Registry 23 07-23-2015 08:04 AM
1998 Ford Explorer 4.0 sohc 4x4 eddie Bauer ford007 New Member Introductions 0 03-30-2012 03:46 PM
1991 ford xlt 4x4 explorer BRAKE JOB??? catfisher81 Stock 1991 - 1994 Explorers 1 01-06-2010 03:00 PM
410Fortune 1988 Ford Bronco II Eddie Bauer 4x4 410Fortune Bronco II Registry 200 11-20-2009 06:11 PM
95 Ford Explorer Eddie Bauer 4x4 Horus Stock 1995 - 2001 Explorers 1 03-21-2007 10:44 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
