Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
1995 shift solenoid replacement
Reply
Thread Tools
Old 09-10-2013, 06:43 PM   #1
Jonathansblack
1995 Explorer XLT,
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Hey guys, anyone have any experience replacing the shift solenoid on the 1995 explorer tranny? Mine is out and I've never replaced it. Any advice would be awesome!
Jonathansblack is offline   Reply With Quote
( Join the Elite Explorers )
Old 09-10-2013, 08:51 PM   #2
imp
Missouri Ozarks
2004 XLT
Vehicle Specs
Quoted: 122 Post(s)
Quote:
What makes you think the solenoid is at fault? Trouble codes? I think you have the 4R44E transmission. My '96 was acting up, I was sure it was the solenoid, bought a new one, still no good. Tore trans. apart, found thrust bearings between clutch sections destroyed.
Wound up buying a reman. from Ford which worked perfectly. imp
imp is offline   Reply With Quote
Old 09-11-2013, 01:05 PM   #3
Jonathansblack
1995 Explorer XLT,
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
The whole tranny has been rebuilt down to the torque converter. The only thing that wasn't replaced were the solenoids. With talking to other folks (not on the forum) they seem to think that's the issue. What leads me to believe it is is that when you're driving it and it comes to a stop the rpms go down and the truck dies out. When I explained that to other mechanics they said its most likely the solenoids.
Old 09-11-2013, 07:13 PM   #4
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 417 Post(s)
Do you have any trouble codes? You have a 4R55E transmission. It sounds more like the TCC solenoid than a shift solenoid. The shift solenoids are basic on/off devices while the EPC & TCC solenoids are modulated.
BrooklynBay is offline   Reply With Quote
Old 09-11-2013, 07:29 PM   #5
rs2k
Wichita, KS
2014 Ram 1500 Laramie
Vehicle Specs
Quoted: 2 Post(s)
If your tranny's out then it's pretty easy to test the solenoids for proper resistance. I replaced both shift solenoids on my explorer because they were both out of spec... though I have a 4R70W.
The solenoids on the 4R55E tranny are at the bottom of the valve body and look like they're easy to get to.
rs2k is offline   Reply With Quote
Old 09-11-2013, 10:54 PM   #6
imp
Missouri Ozarks
2004 XLT
Vehicle Specs
Quoted: 122 Post(s)
Brooklyn is absolutely right: If the vehicle in being brought to a stop in DRIVE causes the engine to die, it's likely the torque converter clutch is not being released, this either due to faulty clutch (not likely), or faulty solenoid. This is exactly the same as coming to a dead stop with a manual transmission without releasing the clutch with the foot pedal. imp
Old 09-12-2013, 01:49 PM   #7
Jonathansblack
1995 Explorer XLT,
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Let me explain a little more. The o/d light is flashing and when you are driving at say 45 or 50 the tranny will not engage o/d at all that of course is in addition to it dying out at a stop that I mentioned earlier. As far as codes go I don't have any because I haven't taken them to shop to get them read. This is my only form of transportation and I don't really have the ability to just take it and leave it somewhere for them to pull up the codes.
Old 09-12-2013, 06:55 PM   #8
imp
Missouri Ozarks
2004 XLT
Vehicle Specs
Quoted: 122 Post(s)
Places like AutoZone will read the codes for you free. Takes about 5 minutes, if they aren't busy. Or, do yourself a favor and buy a code reader good ones are available under a hundred bucks. Be sure it will read "CAN" protocol. imp
Old 09-12-2013, 07:53 PM   #9
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 417 Post(s)
Sometimes the code readers that the stores use don't always read manufacturer specific transmission codes.
Old 09-13-2013, 07:26 AM   #10
rs2k
Wichita, KS
Vehicle Specs
Quoted: 2 Post(s)
Quote:
Maybe, but it's still worth a shot.
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Instrument Cluster Shift Cable Replacement mranderson214 Stock 2002 - 2005 Explorers 3 06-17-2013 10:53 PM
ford manufacturer specific codes whale45714 Stock 1995 - 2001 Explorers 0 04-16-2011 10:03 AM
Instant "Check Transmission" after solenoid replacement VBall23 Explorer & Ranger Transmissions, Transfer Cases, & Differentials 5 10-30-2009 09:03 AM
tell me how to change a shift solenoid C "96 explorer 4R55E crawdad13 Explorer & Ranger Transmissions, Transfer Cases, & Differentials 0 09-13-2007 10:09 PM
solenoid short/PCM may cause shift problems AHar_94XLT Explorer & Ranger Transmissions, Transfer Cases, & Differentials 4 08-13-2006 01:31 AM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
