Mike-in-Maine
- August 10, 2013
- Lewiston, ME
- 2003 & 2005 Explorer
Wife called me at work with the news that OD/Off Light was flashing and the Explorer (190,000miles) is not shifting into 3rd gear (just got done Engine R&R for chains, guides, tensioners etc. I did all the work in my very limited spare time and it was running awesome).
Got home ran my scanner and pulled a FF DTC with P0745 and P0733. This does not look good. Before I pull the tranny for replacement of a broken band, are there ANY other items to check that could cause this problem?
UPDATE: Took it for a test drive. 1-2 shifts fine, 3rd gear flares, let off gas and it will eventually drop into 4th gear as long as speed doesn't drop too much during flare of third gear. 4-5 works. But third gearis non existent, just freewheels, rpms will simply increase and speed will drop. This is pretty much what happens on a hill unless you downshift and gas it up in mph then do the throttle trick to get the explorer to skip 3rd and drop into 4th. Then you can give it more gas and accelerate in 4th... otherwise the only option is to creep up the hill in 2nd gear, because youll never get speed in third and will never go to fourth once in 3rd.. Flat ground you can modulate the throttle to get out of the flaring third and then drop into 4th which will then stay in gear fine and eventually drop into 5th and TC will lock up as normal.
It looks grim at this point. We were without the explorer for a month and dropped about $1000 in parts for new chains, tensioners, gaskets, radiator, blend door motor, plugs, wires, t-stat housing, etc. etc. Just solved some electrical problems too... got 2 days of joy before todays surprise. Never had this issue before.
What should I check out short of dropping the entire tranny and replacing it with a good used unit? I am in no mood to rebuild the tranny. I have way too much going on before the snow flies. And I'm not financially in a position to pay a garage $2000-$3000 for a job like this on a vehicle that isn't even worth $5000.
