ahmos
- December 29, 2009
- 98 xlt
Hii
My car has a bad gas mileage so I started to check the egr system ..
I started to check the egr pressure sensor or dpfe and it gave me good readings
So I checked the egr exhaust valve and the car had a rough idling then normal when I apply vacuum to it then release.. so I think its ok too
Now I have a doubt that the egr vacuum regulator/solenoid valve have some trouble
I checked its tubes and it has a good vacuum source from engine but I think it does not give vacuum source to the exhaust valve..
I checked the wires and it has 13 volt source.... I checked the resistance it gave me about 37 ohm
I connected a vacuum pump to the solenoid valve to check the vacuum power but it give me no reading .. I try to accelerate but nothing
So I dont know if it could be broken or not or should I change it.
That valve has this part number f57e-9j459-ca .. and this number on the cap pa66-gf33
Now another question .. there is another solenoid valve beside the one I mentioned above
There is a printed word (lectron) on it .. and it has a US pat no. 4728916.... so what is that part and does it affect the other one work? And from where to buy
B.s im from outside of America
Thank you all for your help all over the time and sorry if my English is bad
