Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
Rough IDLE P0172 and P0174 Codes
Reply
Thread Tools
Old 10-07-2013, 07:09 PM   #1
chloedad
Richmond, VA
2004 Ford Explorer
Vehicle Specs
Quoted: 5 Post(s)
(Original Poster)
Last week my Explorer began running rough. I had multiple misfire codes (300, 301, 302, 303, 316, etc.) I replaced all my wires, plugs, MAF, and crank shaft sensor. It still idles rough, more so after the engine gets warmed up. A little history about this vehicle....I put a new transmission in the vehicle approximately 30K miles ago and a new (used motor 58K) in it last August (22K miles ago). This motor now has about 80k on it.
I am now getting a P0172 Bank 1 Rich and a P0174 Bank 2 Lean codes. Any ideas. Also when I accelerate hard I hear the timing chain (so thought about changing the tensioner?). As much as I love this vehicle I am about ready to throw it in the river. I had to have the computer reprogrammed a few weeks ago since after I changed the battery the computer would no longer recognize the key.
But any thoughts on what I am getting now with the rich and lean codes?
chloedad is offline   Reply With Quote
( Join the Elite Explorers )
Old 10-07-2013, 09:44 PM   #2
HiImBrian
St. Petersburg, Florida
2003 Explorer Eddie Bauer
Vehicle Specs
Quoted: 21 Post(s)
Quote:
Originally Posted by chloedad View Post
Last week my Explorer began running rough. I had multiple misfire codes (300, 301, 302, 303, 316, etc.) I replaced all my wires, plugs, MAF, and crank shaft sensor. It still idles rough, more so after the engine gets warmed up. A little history about this vehicle....I put a new transmission in the vehicle approximately 30K miles ago and a new (used motor 58K) in it last August (22K miles ago). This motor now has about 80k on it. I am now getting a P0172 Bank 1 Rich and a P0174 Bank 2 Lean codes. Any ideas. Also when I accelerate hard I hear the timing chain (so thought about changing the tensioner?). As much as I love this vehicle I am about ready to throw it in the river. I had to have the computer reprogrammed a few weeks ago since after I changed the battery the computer would no longer recognize the key. But any thoughts on what I am getting now with the rich and lean codes?
A clogged catalytic converter can cause all kinds of problems like that by increasing the amount of back pressure. This has been a problem for a lot of people lately. Our Explorers are getting to the age where a lot of things start to wear out.
Take it to a reputable muffler shop and they'll check it for free. It can be expensive to replace them. However if you live somewhere that doesn't have emissions testing like I do, you can hollow them out or have them replaced with a piece of open pipe instead. Keep in mind that the "reputable" shops won't do that for you though... "TECHNICALLY" it's "illegal".
As far as the tensioner is concerned, pop off the valve covers and check for slack in the chains. If there is any, you've got another "fun" project.
__________________
2003 Explorer Eddie Bauer 4.6L V8
MMR Stage 2 Heads - Ported Bullitt Intake - BanksPower TransCommand - CodeAlarm Remote Start - Hunter Brushguard - Custom Roof Basket - 3rd Cat Cutout - Straightpiped/Magnaflow Catback - 3" Body Lift - 2.25/1.75 BTF Spacers - F-150 Towhooks - 2" Wheel Spacers - HID's - 35/70/17's - EGR & PCV System Delete - AND MORE!
My Registry: HiImBrian's Beachcomber
HiImBrian is offline   Reply With Quote
Old 10-09-2013, 09:07 AM   #3
redoxy
Edmonton, Alberta
2002 Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
Last week my Explorer began running rough. I had multiple misfire codes (300, 301, 302, 303, 316, etc.) I replaced all my wires, plugs, MAF, and crank shaft sensor. It still idles rough, more so after the engine gets warmed up.I am now getting a P0172 Bank 1 Rich and a P0174 Bank 2 Lean codes. Any ideas. Also when I accelerate hard I hear the timing chain (so thought about changing the tensioner?). As much as I love this vehicle I am about ready to throw it in the river. I had to have the computer reprogrammed a few weeks ago since after I changed the battery the computer would no longer recognize the key.
Rich and lean codes usually are the result of vacuum leaks. They are also the reason why you are getting multiple misfire codes. Before you throw another part at it. Check and make sure all the vacuum lines and intact and there are no leaks.
redoxy is offline   Reply With Quote
Old 10-09-2013, 12:25 PM   #4
chloedad
Richmond, VA
2004 Ford Explorer
Vehicle Specs
Quoted: 5 Post(s)
(Original Poster)
Is it harmful to drive it like this? Will it harm the vehicle?
Old 10-09-2013, 12:31 PM   #5
redoxy
Edmonton, Alberta
2002 Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
well for one thing misfiring mean throwing raw fuel into the cat converter which will likely burn it out and will require you replacing it if you continue to drive.
Also your fuel economy will go down with a misfire.
Old 10-14-2013, 12:31 PM   #6
chloedad
Richmond, VA
2004 Ford Explorer
Vehicle Specs
Quoted: 5 Post(s)
(Original Poster)
Well, I took it to a more upscale mechanic to have it "properly" diagnosed. Basically they have said that it is something internal on the passenger side of the motor. No leaks, no converter issues.....It is disappointing since this motor only has 80k miles on it.
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Rough IDLE P0172 and P0174 Codes chloedad Stock 2002 - 2005 Explorers 2 10-14-2013 12:07 PM
P0172 & P0174, rough idle after timing chain replacement vw06gti 2001-2005 Explorer Sport Trac 5 11-28-2012 03:16 PM
Multiple Codes - Cannot Diagnose - Please Help!! tsortor Stock 2002 - 2005 Explorers 7 10-21-2012 03:19 PM
P0301, P0302, P0303, P0172 and P0174 codes. David704 EEC V 6 01-10-2012 09:35 AM
p0172 p0174 Phreaq 2001-2005 Explorer Sport Trac 1 11-22-2011 04:24 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
