#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2011 - 2017 Ford Explorer 5th Generation Explorer > Stock 2011 - 2016 Ford Explorer Discussion
Notices
Stock 2011 - 2016 Ford Explorer Discussion 2011 - 2016 Ford Explorer reviews, problem solving, maintenance, TSB, service bulletins, owner reviews, specifications, Ecoboost.
I have a roofing nail in my tire!
Reply
Thread Tools
Old 11-12-2013, 10:34 AM   #1
LukerDooker
N.E.
2013Limited 301A TuxBlack
Vehicle Specs
Quoted: 153 Post(s)
(Original Poster)
Unhappy I have a roofing nail in my tire!
Roads around here are terrible, filled with debris and pieces of who knows what.
It looks like a roofing nail - wide head.
Running 20" Hankooks with polished rims.
I have not tried to pull it out, its not leaking air. Roofing nail may be short - maybe can just pull it out.
Tires still new, less than 5k miles.
I dont want to leave it but not sure what to do - local shop or dealer?
Both are pretty close but dealer will be seeing green...
LukerDooker is offline   Reply With Quote
( Join the Elite Explorers )
Old 11-12-2013, 10:42 AM   #2
DoraThe_Explorer
Vermont
2000 XLS
Vehicle Specs
Quoted: 12 Post(s)
If you would rather not do it yourself, then any tire shop or Mom and Pop shop should be able to repair it. Good luck!
DoraThe_Explorer is offline   Reply With Quote
Old 11-12-2013, 10:46 AM   #3
LukerDooker
N.E.
Vehicle Specs
Quoted: 153 Post(s)
(Original Poster)
I cant pull the wheel and using a plug requires some strength and leverage to get it in - need the right tools to get it in well.
The little hand tool plug kit in Autozone etc wont do it,
I have tried with past cars.
I'm just afraid of I pull it out the nail and its long - air will gush out...
I can just go to a local shop - very busy, clean place, many newer cars in there daily, they can do it maybe just on the rack without pulling tire(?)
The nail is in flush and straight, it must be short...
Old 11-12-2013, 11:05 AM   #4
Maniak
Moderator-Stock 91-94
Vail, Arizona
Maniak's Avatar
1992 XLT 4x4
Vehicle Specs
Quoted: 205 Post(s)
A tire shop is going to want to pull the tire off the rim. They will install a patch or a plug/patch if it went through.
If its within 1" of the edge of the tire most shops won't even touch it.
We pick up a nail or screw once every couple months.. I keep a spare pair of tires on rims for the mustang (directional) and a full size spare at the house for the honda. That way if I pick something up in a tire, or a tire goes flat etc I can toss on a different rim and get the other tire fixed at my leisure since I will still have a spare in the vehicle.
Now, the Explorer just gets plugs since I can do that in less time than it takes to put on the spare.. I pull out whatever is in and if it leaks I use the reamer to make the hole bigger and then put in the plug. The Explorer spends more time off-road than on-road so I'm fine with that... If your running higher pressure tires, or carrying weight etc. I'd get it done right, with a plug patch.
~Mark
__________________
Click HERE to see our Explorer Specs
Maniak is offline   Reply With Quote
Old 11-12-2013, 12:01 PM   #5
peterk9
Ottawa, Ontario area
peterk9's Avatar
2014 Lincoln MKT AWD
Vehicle Specs
Quoted: 1939 Post(s)
If it has punctured the tire, the only way to properly repair it is to use a combination of a plug and a patch inside the tire. The patch will help to restore the air containment of the inner tire while the plug will prevent water from reaching the steel belts and body core. A patched tire also will affect the original 'speed rating' of the tire.
__________________
Peter 2014 Lincoln MKT, 201A, 3.5L Ecoboost.
Previous rides;'99 Windstar; '02,'06 & 09 4WD Toyota Highlander Limiteds & 2011 AWD Explorer Ltd.
peterk9 is online now   Reply With Quote
Old 11-12-2013, 12:16 PM   #6
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 380 Post(s)
I've been using a basic plug repair kit for years, and fixed many tires without future issues. Sometimes it's possible to pull the nail out, and install a plug without removing the wheel. Could you post a picture of the tire with the nail inside?
BrooklynBay is online now   Reply With Quote
Old 11-12-2013, 01:17 PM   #7
182RG
Winchester, VA
'11 XLT / '13 Touareg TDI
Vehicle Specs
Quoted: 182 Post(s)
Let a shop pull the wheel, install a proper patch inside, and remount. An hour or two of time and $30.
182RG is online now   Reply With Quote
Old 11-12-2013, 07:44 PM   #8
VinceL
Frisco, TX
2013 Explorer Limited
Vehicle Specs
Quoted: 37 Post(s)
We have always had good luck with Discount Tire patching our tires for free, whether we bought the exact tire there or not (we have purchased a good number of tires over the years from them and that may make the difference).
__________________
We bought a Ford
She got a 2013 Ex
Meet the Gray Ghost HERE
Check out the Gray Ghost on Fuelly.com
Average Mileage: 21.3
Best Tank: 26.5
VinceL is offline   Reply With Quote
Old 11-12-2013, 10:24 PM   #9
LukerDooker
N.E.
Vehicle Specs
Quoted: 153 Post(s)
(Original Poster)
Dk Exp I pulled it out
I pulled it out. It was loose, in the past a nail in good and tight was long and for sure a repair.
It was a tiny 1/2" roof nail with a wide head in the middle of a line of tread, but didnt pass through the bottom of the tread.
I got 1 nice flash pic and I can see right into the hole, which is smooth and still sealed.
Nice!
Old 11-12-2013, 10:44 PM   #10
tenny
B
LI NY
tenny's Avatar
2001 mounty
Vehicle Specs
Quoted: 33 Post(s)
wow.....talk about making a mountain out of a mole hill...haha
glad it worked out.....lol
tenny is offline   Reply With Quote
Old 11-13-2013, 07:33 AM   #11
NEWPORTNJ
JERSEY CITY
2014 TUXEDO BLK LTD 302A
Vehicle Specs
Quoted: 93 Post(s)
I'm with you tenny i have never seen so much talk over a nail in a tire. I cant wait and see when a paper clip gets stuck on a tire...!lol nice day to all.
NEWPORTNJ is offline   Reply With Quote
Old 11-13-2013, 09:54 AM   #12
LukerDooker
N.E.
Vehicle Specs
Quoted: 153 Post(s)
(Original Poster)
ahh cman gang it was touch and go for a while...
These 20" tires are pretty thin and to see a nail that looked so large from the top, and I was driving it to the tire place, and back because they blew me off, last thing anyone needs on the first real cold 35* day is a shredded Hankook and damaged rim.
(...if it was a large nail, ...but it wasnt...)
...Or a scratched rim and damaged sensor from someone throwing it on a wheel spinner to fix it, with typical bravado...
From the look the tire gut gave my car as I pulled in, I'm so glad I didnt need it repaired.
Old 11-13-2013, 10:06 AM   #13
roamingphantom
NYC
2013 EX Limited, 302A
Vehicle Specs
Quoted: 121 Post(s)
Straying from the topic a bit - I thought we had run flats.
roamingphantom is offline   Reply With Quote
Old 11-13-2013, 10:19 AM   #14
LukerDooker
N.E.
Vehicle Specs
Quoted: 153 Post(s)
(Original Poster)
Not on mine, that's a feature that's not cheap-you would know for sure if you had it as you would pay a premium for those.
Its not mentioned in the manual anywhere(?)
Old 11-13-2013, 11:10 AM   #15
peterk9
peterk9's Avatar
Vehicle Specs
Quote:
No run flats unless of course you want to keep diving on a flat tire.
I may be wrong, but I believe that, these days, vehicles with 'run flat' tires do not have a spare.
__________________
Reply
Similar Threads
Thread Thread Starter Forum Replies Last Post
Are you a redneck? jjue General Topic Polls 132 04-03-2015 08:32 PM
Warranty - Powertrain 1995E Stock 2011 - 2016 Ford Explorer Discussion 6 09-04-2013 12:39 AM
"Herc Tour" Report GJarrett Offroad 4x4 Runs Planning and Discussion 49 09-11-2008 01:30 AM
Predictions on War!! 96_explorer.com Exploring every thing under the sun!! 0 09-20-2001 02:20 PM
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
