Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > General Explorations!!
Notices
General Explorations!! Closed to new posts. Place new posts in our new model year appropriate forum
Severe Gas Ping on '94 4.0L
Thread Tools
Old 12-21-2001, 09:51 PM   #1
hammer58
Lubbock, Texas
'94 XLT
Vehicle Specs
(Original Poster)
My 94 4.0L has a severe gas ping on acceleration. When I disconnect the spout connector, which retards the base timing, it really helps alot. Can anyone tell me if this will hurt my fuel milage and why do I have to disconnect the spout connector. Does this decrease the power?
hammer58 is offline
Old 12-21-2001, 11:15 PM   #2
fox
Clackamas, Oregon
89 F150 xlt Laramie
Vehicle Specs
ya thats not good, have you ever overheated it, DON'T lie. i used to. if you did you need to check compression in all of you cylinders. they should be around 200 psi, get a manuel to chech for shure. if you have overhaeted it they you will most likely need new heads. the casting is of very poor desing, the are very well known fro cracking in sutch a way that they are unfixable. so you need to check your compression. just taking that plug out is not an answer, thats just delaying the enevidable. any Q's just ask.
__________________
6" lift
35" BFG AT'S
warn manuel hubs
5 spd w/I 6
headers w/ 3" exhaust
K$N air filter
500watt pioneer premere system
fox is offline
Old 12-22-2001, 02:57 AM   #3
MSTNGGUY88
Theodore, AL
'96 XLT 5.0
Vehicle Specs
Your timing is just to high man. Bump it down a few degrees and try it. This isn't any big deal. You won't see a mileage difference or feel a severe power difference. Ask a local mechanic if you think i'm crazy but try it. Anytime the timing is too high on a vehicle pre-detenation occurs and every motor seems to be different on the amount of timing they can run.
MSTNGGUY88 is offline
Old 12-22-2001, 08:26 AM   #4
hammer58
Lubbock, Texas
'94 XLT
Vehicle Specs
(Original Poster)
How do you adjust the timing on a Distributor-less ingnition?
p.s. it has never been overheated
hammer58 is offline
Old 12-22-2001, 08:16 PM   #5
srvblues00
Denver, NC
94 Sport / 88 Turbo Stang
Vehicle Specs
I had really bad pinging in my 94 Sport in all 5 gears. I then cleaned the MAF sensor and the problem was instantly solved. I would still recomment doing the above suggestions, but I think you should add this to the list! My truck still pings slightly on the interstate once it has heated up pretty good (middle of heat range on guage) when I give it a lot of gas. I'm thinking about taking off the upper and lower intakes, cleaning them, gasket matching, and replacing the gaskets. Good luck and keep us posted on the progress.
__________________
88 2.3 Turbo Mustang Hatchback - Ported everything, T3 turbo, Powerstroke Intercooler, Schneider custom roller cam, Big log center mount header, EEC tuner, WB O2
1994 Ford Explorer Sport - 2 door 4.0 OHV V6 5spd - K&N, 3.55 ring/pinion, track-lok shimmed really really tight - FOR SALE
srvblues00 is offline
Old 12-22-2001, 08:20 PM   #6
MSTNGGUY88
Theodore, AL
'96 XLT 5.0
Vehicle Specs
I knew that your motor has never been overheated. I never thought that in the first place. I've never even heard of that before causing a ping and i've been building motors for awhile for personal rides. I will check into how you can adjust that on your own but I think that it might can only be done by a certified mechanic though because it has a crank trigger. I've never changed it because my buddy works for Ford and he hooks it up to the computer at his work and changes it that way. Sorry I couldn't help anymore.
Old 12-22-2001, 10:07 PM   #7
hammer58
Lubbock, Texas
'94 XLT
Vehicle Specs
(Original Poster)
I never heard of overheating causing a ping either. That was a suggestion from Fox. I found a post regarding re-torquing the intake manifold bolts. I'll try that and also cleaning the MAF sensor. Thanks for your help guys and I'll keep you posted.
hammer58 is offline
Old 12-23-2001, 07:24 PM   #8
Lemondrop
Cocoa , Florida
1995 Sport , 1996 XLT 5.0
Vehicle Specs
My 94 Ranger splash I killed in a crash did the same thing . The MAF (Mass air-flow Sensor) was DIRTY . The little filaments inside the sensor had gobs of dirt and nasties stuck to them . Without the MAF working correctly , then engine dosent know you are doing anything other than reving the engine at idle . It will only send a small amount of fuel (signal) to the injectors as it dosent think you need more . This will cause a lean fuel mixture which will cause the PING your getting .
Remove the MAF (Im sure it's on the airfilter box ) You will need a special TORX bit ( a security version) the 2 screws that hold the MAF on are security torx bits that you can get a removal tool for at just about any auto parts store . Get some Oxygen sensor safe carb cleaner and blast the 2 filaments off (after removing the MAF from the airbox) . Once they are clean and dry , install the MAF and hook up the wires . Also be sure to re-torque the intake lower bolts ( where the intake attaches to the heads at ) . These are known to loosen and cause a air leak inside the engine , which can result in a ping .
Best bet is the MAF being dirty . If yours suddenly started doing this be sure to check your airfilter and or replace it . Also check for leaks between the MAF sensor housing and airfilter housing , as if it draws dirt in it's bad for the sensor and your engine .
Lemondrop is offline
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
