Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > General Explorations!!
Notices
General Explorations!! Closed to new posts. Place new posts in our new model year appropriate forum
Lifts on a 2wd?
Thread Tools
Old 12-28-2001, 03:52 PM   #1
mikegt98
Raleigh, NC
'94 XLT
Vehicle Specs
(Original Poster)
Lifts on a 2wd?
Hi guys,
I'm building an audio show car ('94 XLT 2wd 4.0), and would like to lift it.. is this even possible? Does anyone do 2wd to 4wd conversion kits for an automatic transmission? Heck, will Ford even do this?
Thanks!
-Mike
mikegt98 is offline
Old 12-28-2001, 03:55 PM   #2
TarHeel085
And den
Raleigh, NC
TarHeel085's Avatar
'99 Sport 4wd
Vehicle Specs
HEY someone lives near me, HAHA. um you can get 2wd lift spindles. ask trckmagik he's got a lift on his 2wd.
TarHeel085 is offline
Old 12-28-2001, 04:19 PM   #3
Trckmagik
Ole Bag
Celina, Texas
Trckmagik's Avatar
1996
Vehicle Specs
I have done 2wd lifts on 3 explorers. This is possible. You will need a skyjacker suspension lift for your early model explorer! I have also done 2 of these on newer models which use the spindle lift. Email me if you have any questions Trckmagik@aol.com
__________________
Brian Green
1996 V-8 Explorer
1994 4x4
Trckmagik is offline
Old 12-28-2001, 06:58 PM   #4
bigDerk
Stockbridge, GA
2001 Ranger Edge
Vehicle Specs
Can the 2WD Explorers/Rangers use the F150 spacer method? I sure hope so, because I've told several people about that option, and one of them has the spacers and is ready to do it over the holidays...
__________________
2001 Ford Ranger EDGE
Click for EdgeDomain.
- 2WD, 4.0L SOHC, Automatic
- 32 x 11.50 BFG All Terrains
- 2 inch torsion bar lift
- 4.10s and LS to install.
bigDerk is offline
Old 12-29-2001, 11:46 AM   #5
CoryL
Louisville, KY
94 Eddie Bauer
Vehicle Specs
If you want 4wd. Sell the 2wd and buy the 4wd. It is the easiest and cheapest way to obtain it ESPECIALLY if you can't do the work yourself.
Now, there are plenty of lifts for 2wd Explorers, especially 91-94 models.
Since it sounds like it is for looks only, I'd pass on the body lift. While cheap, they expose the frame and require the bumpers to be moved up as well. Doesn't look good in my opinion.
So this leaves you with suspension lifts. Skyjacker, Superlift, Rancho, Pro-Comp, Baja Concepts, H and M Motorsports, Donahoe Racing, Camburg Engineering, etc etc all have kits that would work. The question is what size tires do you want to run and how much can you afford to spend (and don't answer with as little as possible) on everything.....wheels, tires, lift, installation (if you can't do it yourself), gears (depending on tire size).
__________________
"You ever kill anybody?"
"I hurt someone's feelings once."
Moab Off-Road / Accessories and Custom Fabrication
CoryL is offline
Old 12-31-2001, 11:10 AM   #6
mikegt98
Raleigh, NC
'94 XLT
Vehicle Specs
(Original Poster)
Cory,
I pretty much have ruled out a body lift, and agree with what you said, IMHO, they're ugly.. I just don't think it will look that great. As for selling the car, I'm not desperate enough for 4wd to go that route, so I don't think it's worth it. I'm mainly looking for the lift, not the 4wd ability. This is going to be a show car, so 4wd isn't necessary because this truck isn't going to see a lot of off-road time (something I'm sure people on this forum don't want to hear :-) )
As far as suspension lift goes, I was thinking about a 6" lift, max. 8" or 9" is probably too much for what I'm looking for. What size tires can I reasonably expect to be able to put on a automatic V-6 '94 XLT with a 5.5" or 6" lift, without having to worry about rub, etc.? What gears should I look at getting to run said tires? The engine will have some hi-po parts, but nothing crazy like NOS/blower/turbo... is this going to be an issue when it comes to pushing/turning larger tires?
Also, money isn't really a concern, I know this will be expensive, but it won't be done at all once, and I'm fortunate enough to have a good job. I just need estimates to know what I'm in for. How much is the parts for a typical 6" suspension lift? Installation (I don't plan on tackling the lift on my own)? Tires? Gearing and all necessary hardware? What size wheels?
Another kinda off-the-wall question: I have a nice set of chrome 20" rims lined up for the car.. are there any 33" -36" tires that can accomodate a 20" rim?
Thanks for all the help,
-Mike
mikegt98 is offline
Old 12-31-2001, 11:34 AM   #7
Trckmagik
Ole Bag
Celina, Texas
Trckmagik's Avatar
1996
Vehicle Specs
The F-150 spacers will work on the 2wd but you will need to modify the bolt. I ended up having to pay my offroad shop to install these! But they will go on as I have had them on for about 6 months now totalling my 10.5" lift.
__________________
Brian Green
1996 V-8 Explorer
1994 4x4
Old 12-31-2001, 12:12 PM   #8
bigDerk
Stockbridge, GA
2001 Ranger Edge
Vehicle Specs
Modify which bolt, the one that runs up through the bottom of the coil, for the 1 1/8" nut?
I knew I shouldn't have told people about that lift...
__________________
bigDerk is offline
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
