| Body Work & Detailing Waxing washing, wheel cleaning and body work. This is the place to discuss those topics. |
Thread Tools |
#1 |
Indianapolis, IN
1996 5.0
Screwing into the headliner
I have a neon setup in my head that I really want to do, and it involves putting some tubes up on the ceiling. My question is, I want to screw the tubes up there, but I don't know what type of screws to use, or where I should screw them in at. I DO NOT want to take the headliner down.
If anyone has screwed something into the headliner, please share your ideas PLEASE! Thanks.
__________________ 1996 Explorer 5.0 V8 - TT/shackles, 31" BFG A/T - Registry thread 2005 Mustang GT - Sonic Blue |
#2 |
League City, TX
'92 XLT 4x4
Make sure you hit a crossmember or it is going through the roof. When you drill the holes, get "drill stops" that clamp on your drill bit with a set screw so when you bust through you don't go through the roof. Use sheet metal screw with a blunt end (usually come in brass), so that if you screw them in too far, you have less chance of making a point in your roof. Most of the roof area has a single skin of metal. You can see where the crossmembers are, but you should really consult a set of drawings from someplace like AllData so that you don't drill through a wiring harness.
__________________ Michael 92 XLT 4 Dr 4x4 33x12.50s on Black Rock Crawlers, SmittyBuilt Tube Front w/W9000, 3" body lift, Lift Lips, 2 1/2 "Rancho suspension lift w/Warrior shackles. |
#3 |
Indianapolis, IN
1996 5.0
Will do, gotta look for a set of plans. Thanks for your help.
#4 |
Moderator Emeritus
Glade Hill, Virginia
'97 XLT & '06 Limited
My best advice for you is to suck it up and remove the headliner. It's way too risky not to. Plus, with the headliner down you will be able to make a sturdy mount above the headliner and not have to ever worry about the light falling down.
__________________ ~ My Mugshot1997 XLT and 2006 Limited Try not. Do. Or do not. There is no try. ~ Jedi Master Yoda |
#5 |
Indianapolis, IN
1996 5.0
Yeah, but I heard once you take the headliner down it'll never be the same again. Plus, it's a pain to take it down.
#6 |
League City, TX
'92 XLT 4x4
You can always replace it with shag carpeting and call it Retro-plorer.
| Thread Tools | |
