Michigander
- February 20, 2001
- Flint, Midland, Ann Arbor, Alpena; all in Michigan
- 98 Contour SVT
Ok... I'm sick of this. I've had 4x4 problems on and off since I bought my X about 10 months ago and I know a lot of other people have too. So lets figure this out.
BACKGROUND INFO
The pre '94 Explorer has the Borg Warner 13-45 which acts as a normal TC. It is either on or off, putting the Explorer in 4x4 or 2x4.
However, I have the 1995 Explorer with the Control Trac. That means I have the Borg Warner 44-05 transfer case. The control trac is 2x4 or 4x4 auto. The auto set is 2x4 until the wheels spin and the TC will engage. As per my Chiltons Manual
The Borg Warner 44-05 TC operates in the same manner as the 13-54, except that is also houses a transfer case clutch. This clutch, which is controlled by the Generic Control Module (GEM), enables the vehicle to be driven in 4 wheel drive on dry pavement by cycling the clutch to compensate for different front and rear driveshaft speeds (as in turning). The system has a dealer installable Neutral position mode.
So if I read that right, if my TC is functioning correctly, the wheels WILL NOT bind as I turn, unless my rear tires are slipping.
So this is what I understand.
IF YOUR CONTROL TRAC NEVER ENGAGES, or gets stuck in 4WD, your problem lies in either the electric switch located in the cab, the transfer case shift motor or the auto hubs. This does not mean that you have a bad tranfer case.
IF YOUR CONTROL TRAC ENGAGES BUT FAULTS, your problem lies in the transfer case shift motor, the TC or the GEM.
MY PROBLEM
My explorer will engage perfectly, in 4 high and 4 low for the first few minutes that I have switched the electronic control into 4x4 auto or 4x4 low. Then I get the infamous 4x4 high and low flashing lights. When the ligts are flashing my 4x4 still works fine, however I obviosly have a fault (causing the lights to flash). If I am on dry pavement, most of the time I will feel "bump steering" meaning my 4x4 is still engaged (and it shouldn't be). The 4x4 will usually disengage when I switch it back to 2x4 on the electronic switch, however the lights will still be flashinging signalling a fault.
DIAGNOSIS; it could be
THE TRANSFER CASE- The "clutch" described above does not serve it's function. It only is in 4x4 high and does not disengage the TC to 2x4.
AUTO HUBS- I don't think this is my problem
THE GEM- my Chiltons said this is what controls the clutch in the TC. Therefor if this faults, the TC will not work correctly.
it can't be
THE TC SHIFT MOTOR- The TC shift motor engages as soon as I move the electronic switch, however it is up to the clutch inside of the TC to determine if the explorer is in 2x4 or 4x4. the shift motor should then disengage when the electronic switch moves back to 2x4.
ELECTRONIC SWITCH- it obviously works if the explorer engages.
If anyone disagrees, please post. If anyone has a comment or suggestion, please post. If you took the last 5 minutes to read this and wish you could have the 5 minutes back, please post.
BACKGROUND INFO
MY PROBLEM
it can't be
