Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Offroad Tech Forums > Offroad Explorer - Ranger Projects
Notices
Offroad Explorer - Ranger Projects Big projects... Lifts, Swaps, etc... IMPORTANT As the subject use your name, or the name of your truck, and the name of the project. Such as Superlift 5.5" installation, Dana 44 conversion, etc.
Ryan's F250/Explorer hybrid
Reply
Thread Tools
Old 04-21-2002, 10:56 PM   #121
arsoul
Monroe, WA
arsoul's Avatar
94 Ex/79F250: X250
Vehicle Specs
(Original Poster)
The master cylinder. Kevin posted a pic of the slave and the bracket we fabbed to hold it. We used a combo from a 84 BroncoII. The master had to be shimmed against the firewall so that the rod could meet with an Explorer clutch petal.
__________________
Ex-250
Ryan
arsoul is offline   Reply With Quote
Old 04-21-2002, 11:02 PM   #122
arsoul
Monroe, WA
arsoul's Avatar
94 Ex/79F250: X250
Vehicle Specs
(Original Poster)
This pic shows the mild firewall modifications we had to make. In order to make clearance for the valve cover, we had to push the firewall back about 2 inches. I glued it all back together with JB Weld (about 40 dollars worth!). We also had to push the firewall back about an inch to make clearence for the exhaust manifold.
I knew from the beginning that there would be no A/C, but I didnt know I would have to tear out the A/C condensor to fit the engine. As it turns out, when the heater is on, the hot air passes by the condensor into the dash. I wanted to keep heat, so I had to fab that blue triangle you see to get the hot air into the dash.
__________________
Ex-250
Ryan
Old 04-21-2002, 11:05 PM   #123
arsoul
Monroe, WA
arsoul's Avatar
94 Ex/79F250: X250
Vehicle Specs
(Original Poster)
Here's the steering shaft we made. I ripped a steering shaft from a mid 90s Windstar. I wanted its ujoints. I then mixed those with the end from the explorers origonal steering shaft and from the other end from the F-250s steering shaft. Those are some narly angles, but they are not as bad as the ones in the Windstar. We'll wait and see how the ujoints hold up.
__________________
Ex-250
Ryan
Old 04-21-2002, 11:11 PM   #124
arsoul
Monroe, WA
arsoul's Avatar
94 Ex/79F250: X250
Vehicle Specs
(Original Poster)
Here's a shot from the rear of the Dana60. Thats the rear rock light (there are a total of 3, you can see the back of the middle light pointing down towards the t-case). I used simple tractor lights for those.
Thats the Hooker muffler, I love the sound of it. Also, we just finished the ebrake. The paint wasnt even dry when I took the picture. We had to fab that wierd looking bracket for the cables. I tell you, it was a pain splicing the cable from the Explorer to the cable of the F-250.
__________________
Ex-250
Ryan
Old 04-21-2002, 11:14 PM   #125
arsoul
Monroe, WA
arsoul's Avatar
94 Ex/79F250: X250
Vehicle Specs
(Original Poster)
The rear bumper isnt installed yet. I'm putting up this pic to show the rear cargo container I fabbed up. Access will be from under the bumper, I'll make a little door for it later. I figure I can put a tow strap and winch gear in there. The box is tucked up between the rails of the tow hitch. If it gets eaten by a rock I'll then make the bottem of the box out of 1/4inch plate.
__________________
Ex-250
Ryan
Old 04-21-2002, 11:18 PM   #126
arsoul
Monroe, WA
arsoul's Avatar
94 Ex/79F250: X250
Vehicle Specs
(Original Poster)
Here's something I had not anticipated. It called for an extra trip to the hardware store. Matching up the gas filler tubes was done by using exhaust pipe reducers. The explorers tube is somewhere around 3 inches, and the F-250s tube is 2.25 inches. By the way, the F-250 fuel tank is 24 gallons. That should be enough with the 1barrel carb.
__________________
Ex-250
Ryan
Old 04-21-2002, 11:20 PM   #127
arsoul
Monroe, WA
arsoul's Avatar
94 Ex/79F250: X250
Vehicle Specs
(Original Poster)
Here's a pic of the front axle, from the front. You can see the front rock light tucked up there in the frame rail.
__________________
Ex-250
Ryan
Old 04-21-2002, 11:24 PM   #128
arsoul
Monroe, WA
arsoul's Avatar
94 Ex/79F250: X250
Vehicle Specs
(Original Poster)
A couple other notes:
I'm going to build a front skid plate out of 1/4inch plate to protect the radiator.
After getting the bumper and winch on, the front end sagged down a 1/2inch. I dont see how I can lower the front suspension anymore. There is only 6 inches between the frame and the top of the leaf pack. I guess this is how tall its going to be. After I get the rear bumper with the tire carrier on, and I let it settle, I'll reduce the rear blocks to level the truck out.
If I have trouble on the trails being tippy, I'll just have to build myself an exo-cage
Thanks for the use of your camera Kevin. Much better than the one I have available to me.
__________________
Ex-250
Ryan
Old 04-22-2002, 08:31 AM   #129
Diff Whack Daddy
And the Roll Over Posse!
Under the Hood Moderator
Mount Vernon, WA
Diff Whack Daddy's Avatar
1st Gen XLT 4dr
Vehicle Specs
Thumbs up
I'm glad I ledt the camera as I am sure the rest of the followers of this thread are. I am impressed with how fast that thing is coming together.
__________________
Mount Vernon, WA
Keep the Rubber Side DOWN!!
OHV: 1st Gen-XTREME Tow/Chase Vehicle: Banks powered F-350 SuperDuty w/ camper Commuter: 08 Ford Focus SES(35 mpg, SYNC system) Projects: House, better on board air. Kevins Big Model and list of mods
Diff Whack Daddy is online now   Reply With Quote
Old 04-22-2002, 10:51 AM   #130
jonny 5
Seekonk, MA 02771 (home), N. Dartmouth, MA (college)
'98 XLT SOHC
Vehicle Specs
That's one sweet looking....uhhh.......eX-250. Get a comparision pic next to a stock F-250 and an explorer.
Let's see that thing in action!
__________________
Westin Safari Bar, Bugdeflector II, Lund Windjammer, KKM, Edelbrock ISA shocks, custom painted vinyl.
jonny 5 is offline   Reply With Quote
Old 04-22-2002, 09:36 PM   #131
arsoul
Monroe, WA
arsoul's Avatar
94 Ex/79F250: X250
Vehicle Specs
(Original Poster)
I need a rear driveshaft first....should have it in the next couple of days.
__________________
Ex-250
Ryan
Old 04-22-2002, 09:43 PM   #132
Diff Whack Daddy
Mount Vernon, WA
1st Gen XLT 4dr
Vehicle Specs
Are you just going to have the original f250 driveshaft shortened?
__________________
Mount Vernon, WA
Old 04-22-2002, 09:58 PM   #133
arsoul
Monroe, WA
arsoul's Avatar
94 Ex/79F250: X250
Vehicle Specs
(Original Poster)
Yup. needs new yokes, but its otherwise good. upgrading to 1350 ujoints, making 48 inches long.
__________________
Ex-250
Ryan
Old 04-23-2002, 06:21 PM   #134
91'explorer 2wd
McAllen, TX
'92 XLT 4x4
Vehicle Specs
Thumbs up
that is one bad TRUCK , can't wait to see that thing in a layer of mud.
__________________
'02 x rims
3 chamber flows w/no cat
k&n filter that's worthless
33" wrangler at/s
b/lift, still working on her...slowly but surely
91'explorer 2wd is offline   Reply With Quote
Old 04-24-2002, 01:26 AM   #135
arsoul
Monroe, WA
arsoul's Avatar
94 Ex/79F250: X250
Vehicle Specs
(Original Poster)
Kevin came over today just after I got my new driveshaft installed. We flexed the beast out a little. Keep in mind, I havent done any work to increase flex as of yet.
I guess the rock lights work pretty well.
__________________
Ex-250
Ryan
Old 04-24-2002, 01:27 AM   #136
arsoul
Monroe, WA
arsoul's Avatar
94 Ex/79F250: X250
Vehicle Specs
(Original Poster)
From the front, unfortunatly kevins camera took a crap.
__________________
Ex-250
Ryan
Old 04-24-2002, 09:00 AM   #137
Flounder
Elite - Owns 10,000 Marbles
Pennsylvania
Flounder's Avatar
'04 Sport Trac
Vehicle Specs
Is it me or is this project progressing at an incredible rate?? :-D
Flounder is offline   Reply With Quote
Old 04-24-2002, 07:49 PM   #138
Clint
Mesa ,AZ
91 sport
Vehicle Specs
!!!!WEAK!!!!
__________________
7" of total susp. lift .... 33's blah blah blah
Clint is offline   Reply With Quote
Old 04-24-2002, 07:50 PM   #139
espnfreak
Elgin, IL
'99 Maxima SE-L *5spd
Vehicle Specs
i wasnt payin attention to this thread. That beast is incredibly awesome. Its huge!! congrats!
__________________
Mechanical Engineering @ Purdue University
1996 Ford Explorer - TOTALLED
*Life's A Garden - Dig It*
'99 Maxima SE-Limited 5 spd - 42,000 mi, fully loaded, silver
espnfreak is offline   Reply With Quote
Old 04-24-2002, 07:53 PM   #140
Rick
Admin
Pumpkin Pilot
Wayoutin, Aridzona
Rick's Avatar
'93 XL
Vehicle Specs
I thought you said you had 37s under there
__________________
Rick Horwitz, AB7FH "Serious Exploration's" Admin
Rick's '93/'98 Explorer "The Great Pumpkin"
Dodge Dart 512 Resto/Race 10.29 @ 129
2004 Mustang Mach 1
2003 Dodge Ram/Cummins Dually
Rick is online now   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
