- April 3, 2009
- Kailua-Oahu, Hawaii
- '05 Sport Trac XLS (RWD)
Thanks for the follow up Brakeman. For anyone using aftermarket end links with poly or thermoplastic rubber bushings, the 18-22 ft/lb. factory torque spec listed in the Ford Workshop Manual applies to STOCK end links. The OEM bushings are very hard, and compress very little. Also, measuring torque accurately on any rubber or poly bushing is difficult, if not impossible. As noted above, this is why most aftermarkets such as ES, Moog, and Prothane don't list torque specs and instruct to tighten visually and by feel.
