Technical Service Bulletins
1996 EXPLORER - US (English)
06-14-4
MERCON ATF IS BEING REPLACED BY MERCON V ATF AS A SERVICE FLUID.
05-6-20
FRONT AXLE LEAKS FLUID FROM VENT TUBE - VEHICLES EQUIPPED WITH 4X4 OR AWD
03-22-10
TRANSMISSION - 4R44E - 4R55E - 5R44E - 5R55E - LOW LINE PRESSURE READING AT WIDE OPEN THROTTLE (WOT) - POSSIBLE DIAGNOSTIC TROUBLE CODES P0732, P0733, P1762 - VEHICLES BUILT BEFORE 12/1/2001
03-18-1
ELECTRICAL - REMOTE KEYLESS ENTRY (RKE) - SERVICE TIPS
03-14-8
TRANSMISSION - NEW TRANSMISSION COOLER FLUSHER - SERVICE TIPS
02-25-8
ELECTRICAL - NEUTRAL TOW AVAILABILITY
TRANSMISSION - NEUTRAL TOW AVAILABILITY
02-22-1
DRIVEABILITY - SURGE/ROLLING IDLE - GEAR DRIVEN SYNCHRONIZERS - INCORRECT INSTALLATION - CAMSHAFT POSITION SYNCHRONIZER (CMP) INSTALLATION TOOL CORRECT APPLICATION
ENGINE - GEAR DRIVEN SYNCHRONIZERS - INCORRECT INSTALLATION - CAMSHAFT POSITION SYNCHRONIZER (CMP) INSTALLATION TOOL CORRECT APPLICATION
02-17-6
LAMP - BRAKE - INADVERTENT DISABLING OF BRAKE SHIFT INTERLOCK
02-16-4
FUEL SYSTEM - FUEL PUMP "WHINING"/"BUZZING" NOISE COMES THROUGH ENTERTAINMENT OR TWO-WAY RADIO SPEAKER
RADIO - ENTERTAINMENT OR TWO-WAY COMMUNICATION - "WHINING"/"BUZZING" NOISE IN SPEAKERS CAUSED BY FUEL PUMP
NOISE - "WHINING"/"BUZZING" - COMES THROUGH SPEAKERS OF ENTERTAINMENT OR TWO-WAY RADIO
02-14-2
ENGINE - 4.0L OHV - POSSIBLE CRACKED FLEXPLATE - NOISE OR VIBRATION - VEHICLES EQUIPPED WITH AUTOMATIC TRANSMISSION ONLY
ENGINE - NO CRANK - POSSIBLE CRACKED FLEXPLATE - NOISE OR VIBRATION - VEHICLES EQUIPPED WITH 4.0L ENGINE AND AUTOMATIC TRANSMISSION ONLY
NOISE - NOISE DURING CRANKING - POSSIBLE CRACKED FLEXPLATE - VEHICLES EQUIPPED WITH 4.0L OHV ENGINE AND AUTOMATIC TRANSMISSION ONLY
TRANSMISSION - A4LD - 4R55E - NO FORWARD OF REVERSE ENGAGEMENT - POSSIBLE CRACKED FLEXPLATE - VEHICLES EQUIPPED WITH 4.0L OHV ENGINE ONLY
01-24-6
ENGINE - ENGINE OIL SYSTEM PRIMING PROCEDURES - SERVICE TIPS
01-23-6
ENGINE COOLANT - PROPYLENE GLYCOL - FORD MOTOR COMPANY POSITION ON ENGINE COOLANTS MADE FROM PROPYLENE GLYCOL
ENGINE COOLANT - PROPYLENE GLYCOL-BASED - FORD MOTOR COMPANY POSITION ON PROPYLENE GLYCOL-BASED ENGINE COOLANTS
01-21-6
ELECTRICAL - REVISED MECHANICAL HOOD LAMP SWITCH TO REPLACE OLD STYLE MERCURY HOOD LAMP SWITCH
01-19-7
ENGINE - 4.0L OHV - CARBON KNOCK ON ACCELERATION
NOISE - CARBON KNOCK ON ACCELERATION - VEHICLES EQUIPPED WITH 4.0L OHV ENGINE ONLY
01-15-6
CLIMATE CONTROL - REPEAT HEATER CORE FAILURE
COOLING SYSTEM - REPEAT HEATER CORE FAILURE
01-10-12
WIRING - WIRE HARNESS TERMINAL REPAIR KIT AND WIRE SPLICE PROCEDURE
01-9-7
DRIVEABILITY - HO2S (HEATED OXYGEN SENSOR), CATALYST, AND FUEL SYSTEM MONITORS - SERVICE TIPS - OBD II VEHICLES ONLY
00-26-4
MALFUNCTION INDICATOR LAMP (MIL) - MIL ILLUMINATED - DIAGNOSTIC TROUBLE CODE (DTC) P0420 STORED IN MEMORY - VEHICLES EQUIPPED WITH 4.0L OHV ENGINE ONLY
LAMP - MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATED - DIAGNOSTIC TROUBLE CODE (DTC) P0420 STORED IN MEMORY - VEHICLES EQUIPPED WITH 4.0L OHV ENGINE ONLY
00-24-3
ACCELERATOR PEDAL BRACKET - SHEET METAL CRACKS OR FATIGUES AT DASH PANEL AREA - ALL MODELS - VEHICLES BUILT 9/1/1990 THROUGH 7/1/1999
00-23-10
TRANSMISSION - FLUID IN-LINE FILTER KIT - REPEAT REPAIRS OF TRANSMISSION - SERVICE TIPS
00-21-3
CLIMATE CONTROL - EATC - BLOWER MOTOR CONTROL SERVICE TIPS
00-8-3
NOISE - "RUBBING" FROM REAR OF VEHICLE DURING RIGHT HAND TURNS - VEHICLES EQUIPPED WITH 5.0L ENGINE BUILT THROUGH 1/5/2000
99-24-2
LOCKS - REPLACE AND/OR REPAIR ANY LOCK COMPONENT - AVAILABILITY OF INDIVIDUAL LOCKS
99-23-8
GAUGE - TEMPERATURE GAUGE FLUCTUATION AND/OR "KNOCKING/THUMPING" NOISE FROM COOLING SYSTEM - 4.0L OHV ENGINE
COOLING SYSTEM - PULSATING COOLANT FLOW - NOISE - "KNOCKING/THUMPING" - AUDIBLE IN PASSENGER COMPARTMENT - 4.0L OHV ENGINE
NOISE - "KNOCKING/THUMPING" - COOLING SYSTEM - AUDIBLE IN PASSENGER COMPARTMENT - 4.0L OHV ENGINE
99-23-4
MALFUNCTION INDICATOR LAMP (MIL) - DIAGNOSTIC TROUBLE CODES (DTCS) P0442 AND P0455 - NO DRIVEABILITY CONCERNS
99-20-6
AIR CONDITIONING - BURNING ODOR OR SMOKE WHILE BLOWER MOTOR IS ON
NOISE - "RUSTLING" HEARD ALONG WITH AN ODOR WHILE BLOWER MOTOR IS ON
99-20-3
BUMPER - FRONT BRACKET REPLACEMENT - SERVICE TIP
99-15-2
TRANSMISSION - NEW TRANSMISSION FLUSH AND FILL TOOL AVAILABLE THROUGH ROTUNDA
99-11-1
NOISE - TSB SPECIAL FOR NOISE/VIBRATION/HARSHNESS
VIBRATION - TSB SPECIAL FOR NOISE/VIBRATION/HARSHNESS
99-10-4
MALFUNCTION INDICATOR LAMP (MIL) - MIL ILLUMINATED WITH DIAGNOSTIC TROUBLE CODES (DTCS) P0171, P0174, P1131 AND/OR P1151 STORED IN MEMORY - 4.0L SOHC VEHICLES BUILT THROUGH 1/12/1998
LAMP - MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATED WITH DIAGNOSTIC TROUBLE CODES (DTCS) P0171, P0174, P1131 AND/OR P1151 STORED IN MEMORY - 4.0L SOHC VEHICLES BUILT THROUGH 1/12/1998
99-8-15
INTERIOR TRIM - DOOR TRIM PANEL REPLACEMENT - SERVICE TIP
99-8-8
CLIMATE CONTROL - ERRATIC OR INSUFFICIENT TEMPERATURE CONTROL - EATC EQUIPPED VEHICLES - SERVICE TIP
99-6-5
WINDNOISE - AROUND SIDE DOOR(S) - SERVICE TIPS
99-4-3
REPROGRAMMING POWERTRAIN CONTROL MODULES (PCMS) - OUT-OF-VEHICLE - EEC V VEHICLES ONLY
99-2-3
WATER LEAKS - WINDSHIELD SEALING - SERVICE TIP
WINDSHIELD - SEALING - SERVICE TIP
98-5A-13
BRAKES - DISC BRAKE CALIPER SLIDE GREASE - NEW SPECIFICATION - SILICONE BRAKE CALIPER GREASE AND DIELECTRIC COMPOUND ONLY TO BE USED
BRAKES - DRUM - SHOE-TO-BACKING PLATE LUBRICATION - NEW LUBRICANT MATERIAL
BRAKES - PETROLEUM-BASED LUBRICANT MAY CAUSE SWELLING OF RUBBER PARTS - SERVICE TIP
LUBRICANT - SILICONE DIELECTRIC COMPOUND - NEW APPLICATION - SILICONE BRAKE CALIPER GREASE AND DIELECTRIC COMPOUND
98-5A-11
BRAKES - ELIMINATION OF SANDING ROTORS AND DRUMS - SERVICE TIP
98-5A-5
BRAKES - AVAILABILITY OF HUB-MOUNT BRAKE ROTOR MACHINING EQUIPMENT
BRAKE ROTOR MACHINING - AVAILABILITY OF HUB-MOUNT BRAKE ROTOR MACHINING EQUIPMENT
98-5A-4
BRAKES - PREVENTING BRAKE VIBRATION - SERVICE TIP
WHEELS - PROPER LUG TORQUE PROCEDURES - SERVICE TIP
98-26-2
FUEL - INFORMATION ON GASOLINE - TIPS TO RESOLVE VOLATILITY RELATED DRIVEABILITY CONCERNS
98-24-6
ELECTRICAL - NEW TERMINAL GREASE RELEASED FOR SERVICE
98-23-10
MASS AIR FLOW (MAF) - SENSOR CONTAMINATION - SERVICE TIP
98-20-19
POWER SEAT SWITCH - BUTTON COMES OFF
98-20-10
EXHAUST SYSTEM - LOOSE CATALYST OR MUFFLER HEAT SHIELDS
NOISE - "BUZZING" OR "RATTLING" - LOOSE CATALYST OR MUFFLER HEAT SHIELDS
98-18-14
AIR CONDITIONING - WATER DRIPS ON FLOOR FROM EVAPORATOR WHEN BLOWER IS ON HIGH IN MAX A/C OR NORMAL A/C MODE
98-17-15
STEERING - DRIFT/PULL, TIRE WEAR, RIDE QUALITY - RIDE HEIGHT SETTING PROCEDURE
SUSPENSION - RIDE HEIGHT - SETTING PROCEDURE - SERVICE TIP
98-15-12
EMISSIONS - AVAILABILITY OF EVAPORATIVE EMISSION CANISTER COMPONENTS
98-14-8
BRAKES - ANTI-LOCK - ABS FALSE ACTIVATION AND/OR INTERMITTENT ABS LAMP ON WITH DIAGNOSTIC TROUBLE CODES (DTCS) 1145, 1155, 1230, 1233, 1234, AND/OR 1237 STORED IN MEMORY
BRAKES - PULLS WHEN ABS PUMP RUNS
NOISE - "GRINDING" AND/OR "WHINING" - ANTI-LOCK BRAKES - ABS FALSE ACTIVATION AND/OR INTERMITTENT ABS LAMP ON WITH DIAGNOSTIC TROUBLE CODES (DTCS) 1145, 1155, 1230, 1233, 1234, AND/OR 1237 STORED IN MEMORY
98-14-5
STEERING - "CLUNKING" FELT WHILE ROCKING STEERING WHEEL SIDE-TO-SIDE
98-12-5
AIR CONDITIONING - FILTERING REFRIGERANT AFTER A/C COMPRESSOR REPLACEMENT - SERVICE TIPS
98-11-11
TRANSFER CASE - WATER INGESTION THROUGH VENT TUBE WHILE DRIVING THROUGH HIGH WATER
98-6-10
STALL - STALLS ON DECEL WHILE ENGINE IS COLD - VEHICLES EQUIPPED WITH 4.0L ENGINE AND MANUAL TRANSMISSION
98-5-2
TIRE - TIRE COMPANY TELEPHONE NUMBERS FOR CUSTOMER ASSISTANCE
98-1-26
WIRING - LAMP OUTAGE MODULE HOUSING AND SURROUNDING PLASTIC COMPONENTS MELTED - EDDIE BAUER AND LIMITED EDITION MODELS EQUIPPED WITH MESSAGE CENTERS AND IMPROPERLY CONNECTED TOW WIRING KITS (VEHICLES BEING TOWED)
98-1-24
TRAILER WIRING - PROCEDURE FOR INSTALLING TRAILER WIRING HARNESSES - EDDIE BAUER LIMITED MODELS
WIRING - LAMP OUTAGE MODULE HOUSING AND SURROUNDING PLASTIC COMPONENTS MELTED - VEHICLES WITH MESSAGE CENTERS AND IMPROPERLY CONNECTED AFTERMARKET TRAILER WIRING - EDDIE BAUER AND LIMITED EDITION MODELS
98-1-12
TRANSMISSION - 4R44E/5R55E - NEW SERVICE PART - CENTER SUPPORT - SERVICE TIP
TRANSMISSION - A4LD - NEW SERVICE PART - CENTER SUPPORT - SERVICE TIP
97-26-21
CD PLAYER - "SKIPS" - HIGH SERIES CONSOLE - NORMAL DRIVING CONDITIONS
NOISE - "SQUEAKING" FROM HIGH SERIES CONSOLE - NORMAL DRIVING CONDITIONS
VIBRATION - HIGH SERIES CONSOLE - NORMAL DRIVING CONDITIONS
97-24-25
AIR CONDITIONING - DISCHARGE AIR TEMPERATURE DOES NOT CHANGE WHEN MOVING TEMPERATURE LEVER
97-24-13
REMOTE KEYLESS ENTRY (RKE) - DIAGNOSTIC SERVICE TIPS
97-22-17
CLUTCH - HARD TO DISENGAGE OR FREQUENT REPLACEMENT OF CLUTCH SLAVE CYLINDER - EARLY WEAR-OUT OF SLAVE CYLINDER
97-22-4
TRANSMISSION - A4LD, 4R44E/4R55E, 5R55E - TORQUE CONVERTER SLIP - DIAGNOSTIC TROUBLE CODE (DTC) 628 OR P0741 STORED IN MEMORY
97-22-1
DELTA PRESSURE FEEDBACK EGR (DPFE) - DIAGNOSTIC TIPS
97-21-15
SHUDDER OR BINDING SENSATION - IN TIGHT TURNS WHILE VEHICLE IS IN 4X4 AUTO MODE - VEHICLES BUILT THROUGH APRIL 1997
TRANSFER CASE - SHUDDER/BINDING SENSATION IN TIGHT TURNS WHILE VEHICLE IS IN 4X4 AUTO MODE - VEHICLES BUILT THROUGH APRIL 1997
97-20-15
DRIVESHAFT - U-JOINT - AVAILABILITY OF GREASEABLE SERVICE PARTS
DRIVESHAFT - U-JOINT - IDENTIFICATION OF SERVICE PARTS BY MEASUREMENT
DRIVESHAFT - U-JOINTS - IDENTIFICATION OF SERVICE PARTS BY MEASUREMENT
97-19A-1
EVAPORATIVE EMISSIONS
97-19-11
COOLING SYSTEM - "ON-VEHICLE" HEATER CORE PRESSURE TEST REQUIRED FOR WARRANTY CLAIM
97-18-9
COOLING SYSTEM - TEMPERATURE GAUGE FLUCTUATION - VEHICLES WITH 4.0L ENGINE
NOISE - "THUMPING" HEARD FROM WATER PUMP AREA - VEHICLES WITH 4.0L ENGINE
97-17-24
TRANSMISSION - 4R44E/4R55E - EXTENDED SHIFT AND ENGINE RPM ABOVE EXPECTED LEVELS OR "NO UPSHIFT" - TRANSMISSIONS BUILT BEFORE 6/20/95
TRANSMISSION - 4R44E/4R55E - O/D OFF LAMP FLASHING AND/OR DIAGNOSTIC TROUBLE CODES (DTCS) 645, 646, 647, 648, P0731, P0732, P0733, P0734
97-17-22
COOLING SYSTEM - COOLANT LEAKING FROM ENGINE BLOCK HEATER - VEHICLES WITH 4.0L ENGINE
97-17-2
REAR VIEW MIRROR - NEW PROCEDURE FOR PREFERRED REATTACHMENT METHOD
97-15-22
MALFUNCTION INDICATOR LAMP (MIL) - MIL LAMP ILLUMINATED - DIAGNOSTIC TROUBLE CODES (DTCS) P0133 AND P0153 STORED IN MEMORY - EXPLORER WITH 4.0L OR 5.0L ENGINE, AND MOUNTAINEER WITH 5.0L ENGINE
LAMP - MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATED - DIAGNOSTIC TROUBLE CODES (DTCS) P0133 AND P0153 STORED IN MEMORY - EXPLORER WITH 4.0L OR 5.0L ENGINE, AND MOUNTAINEER WITH 5.0L ENGINE
97-15-5
AIR CONDITIONING - OIL REFILL CAPACITY CHART - SERVICE TIP
97-12-13
TRANSMISSION - C6, E4OD, AOD, 4R70W - LOW TRANSMISSION FLUID LEVEL AND/OR SHIFT AND/OR ENGAGEMENT CONCERNS - 4X4 AND AWD VEHICLES ONLY
97-11-11
TRANSMISSION - 4R70W - ERRATIC OR PROLONGED 1-2 SHIFT
TRANSMISSION - AODE - ERRATIC OR PROLONGED 1-2 SHIFT
97-11-5
REMOTE ANTI-THEFT PERSONALITY (RAP) TRANSMITTERS - REPROGRAMMING INFORMATION
97-10-5
AIR CONDITIONING - COMPRESSOR FAILURE - INSUFFICIENT AMOUNT OF REFRIGERANT OIL
AIR CONDITIONING - LACK OF COOLING - INSUFFICIENT AMOUNT OF REFRIGERANT OIL MAY CAUSE COMPRESSOR FAILURE
97-9-8
POWERTRAIN CONTROL MODULE - REPROGRAM POWERTRAIN CONTROL MODULE (PCM) - SERVICE PROCEDURES - SERVICE TIP
97-9-5
LONG CRANK - STICKING IDLE AIR CONTROL (IAC) VALVE - VEHICLES BUILT FROM 11/1/94 THROUGH 3/30/96
STALL - AFTER STARTING WHEN ENGINE ALLOWED TO SOAK FROM 1-4 HOURS - STICKING IDLE AIR CONTROL (IAC) VALVE - VEHICLES BUILT FROM 11/1/94 THROUGH 3/30/96
97-8-8
AIR CONDITIONING - EATC SERVICE TIPS
97-8-6
MALFUNCTION INDICATOR LAMP (MIL) - DIAGNOSTIC TROUBLE CODES (DTCS) P0300, P0301, P0302, P0303, P0304, P0305, P0306, P0307, AND/OR P0308 STORED IN MEMORY
LAMP - MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATES - DIAGNOSTIC TROUBLE CODES (DTCS) P0300, P0301, P0302, P0303, P0304, P0305, P0306, P0307, AND/OR P0308 STORED IN MEMORY
97-4-7
FRAME - RIVET REPLACEMENT WITH BOLTS - SERVICE TIPS
97-3-14
TRANSFER CASE - BINDING OR SHUDDER - DIAGNOSTICS - VEHICLES WITH 4.0L ENGINE - SERVICE TIP
97-3-8
LOCKS - REMOTE KEYLESS ENTRY (RKE) - RKE INOPERATIVE - VEHICLES BUILT THROUGH 10/30/96
96-26-19
ENGINE - 4.0L - TORQUE-TO-YIELD (TTY) CRANKSHAFT DAMPER BOLT - SERVICE TIP
96-26-12
TRANSAXLE - TORQUE CONVERTER REPLACEMENT GUIDELINES AND TORQUE CONVERTER/TRANSAXLE COOLING SYSTEM CLEANING PROCEDURES - SERVICE TIP
TRANSMISSION - TORQUE CONVERTER REPLACEMENT GUIDELINES AND TORQUE CONVERTER/TRANSMISSION COOLING SYSTEM CLEANING PROCEDURES - SERVICE TIP
96-25-24
ENGINE - 4.0L - NEW TORQUE-TO-YIELD CONNECTING ROD FASTENERS
96-24-16
VIBRATION - IN FLOOR PAN - AT WIDE OPEN THROTTLE (WOT) AND/OR STEADY HIGHWAY SPEEDS (70+ MPH) - 5.0L VEHICLES WITH ALL-WHEEL-DRIVE (AWD) - EXPLORERS AND MOUNTAINEERS BUILT IN LOUISVILLE THROUGH 7/29/96 AND/OR ST. LOUIS THROUGH 8/12/96
96-24-9
TORQUE CONVERTER - LEAK TEST PROCEDURE - SERVICE TIP
96-24-6
WIRING - ELECTRICAL DIODE IDENTIFICATION AND SERVICE REPLACEMENTS
96-23-1
STEERING - "CLICKING" NOISE HEARD WHEN TURNING STEERING WHEEL
NOISE - "CLICKING" SOUND HEARD WHEN TURNING STEERING WHEEL
96-22-5
MASS AIR FLOW SENSOR - REPLACEMENT AS AN ASSEMBLY - SERVICE TIP
96-22-1
WINDSHIELD AND INTERIOR GLASS - FOG/FILM
96-21-9
STALL - STALL ON DECEL WHEN CLUTCH IS DISENGAGED AFTER CLOSED THROTTLE ENGINE ON DOWNHILL GRADE - MAY HAVE MIL CODE P1506 STORED IN MEMORY - 4.0L MANUAL TRANSMISSION VEHICLES ONLY
ENGINE - 4.0L - STALL ON DECEL WHEN CLUTCH IS DISENGAGED AFTER CLOSED THROTTLE ENGINE ON DOWNHILL GRADE - MAY HAVE MIL CODE P1506 STORED IN MEMORY - 4.0L MANUAL TRANSMISSION VEHICLES ONLY
96-20-8
AIR CONDITIONING - NEW O-RING APPLICATIONS - THICKER O-RINGS FOR SPRING LOCK FITTINGS - SERVICE TIP
AIR CONDITIONING - SPRING LOCK COUPLING CLEANING PROCEDURE - SERVICE TIP
96-20-7
AIR CONDITIONING - NEW O-RING AVAILABILITY AND APPLICATIONS - SERVICE TIP
96-17-16
BUMPER - FRONT - PREMATURE SIGNS OF WEAR AND/OR CHROME CRACKING - VEHICLES BUILT THROUGH 2/11/96
96-15-6
AIR CONDITIONING - FILTERING REFRIGERANT - SYSTEM FLUSHING - TRACER DYE - LEAK TESTING - O-RING TOOL - TSB REPUBLICATION TO INCLUDE LATEST MODEL YEAR
96-14-13
STEERING - NOISE HEARD THROUGH STEERING COLUMN DURING PARKING LOT MANEUVERS AND/OR STOP-AND-GO OVER BUMPS - VEHICLES BUILT THROUGH 3/25/96
NOISE HEARD THROUGH STEERING COLUMN DURING PARKING LOT MANEUVERS AND/OR STOP AND GO OVER BUMPS - VEHICLES BUILT THROUGH 3/25/96
96-12-17
COOLING SYSTEM - COOLANT LEAK FROM RADIATOR IN COLD AMBIENT TEMPERATURES - VEHICLES WITH 3.0L OR 4.0L ENGINE
LEAKS - COOLANT - COOLANT LEAK FROM RADIATOR IN COLD AMBIENT TEMPERATURES - VEHICLES WITH 3.0L OR 4.0L ENGINE
96-12-9
NOISE - "CHATTER" DURING TIGHT TURNS OR TURNS AFTER AN EXTENDED PERIOD OF HIGHWAY DRIVING - TRACTION-LOK DIFFERENTIAL - 7.5 AND 8.8 INCH RING GEAR REAR AXLES
AXLE - NEW SERVICE KIT AVAILABLE FOR TRACTION-LOK DIFFERENTIAL - 7.5 AND 8.8 INCH RING GEAR
AXLE - TRACTION-LOK DIFFERENTIAL - 7.5 AND 8.8 INCH RING GEAR - "CHATTER" NOISE DURING TIGHT TURNS OR TURNS AFTER AN EXTENDED PERIOD OF HIGHWAY DRIVING
96-11-1
LOCKS - INTRODUCTION OF NEW LOCK DESIGN - SERVICE TIP
96-10-7
FUEL - CALIFORNIA REFORMULATED GASOLINE (CARFG) - SERVICE TIP
96-10-6
NEW GENERATION STAR (NGS) TESTER - INCORRECT INFORMATION DISPLAYED DURING DIAGNOSTIC MONITORING TEST RESULTS - VEHICLES WITH ON-BOARD DIAGNOSTICS (OBD) II
96-8-15
COMPASS - ERRATIC - VEHICLES BUILT THROUGH 2/1/96
LAMP - MAP LAMP BULB BURN OUT - VEHICLES BUILT THROUGH 2/1/96
SWITCH - MAP LAMP OPERATION ERRATIC - VEHICLES BUILT THROUGH 2/1/96
96-7-26
WIRING - TRANSMISSION INTERNAL WIRING HARNESS SERVICE - FLUID PAN CHANGE REQUIRED FOR TRANSMISSIONS BUILT BEFORE 11/30/95 - SERVICE TIP
TRANSMISSION - 4R44E/4R55E - TRANSMISSION INTERNAL WIRING HARNESS AND FLUID PAN REVISION - TRANSMISSIONS BUILT AFTER 11/30/95 - SERVICE TIP
96-7-15
LOCKS - NEW DESIGN LOCKSETS HAVE BEEN INSTALLED ON CERTAIN TRIAL VEHICLES - LIGHT AND HEAVY TRUCK VEHICLES REFERENCED - SERVICE TIP
96-7-11
TRANSMISSION - 4R70W - SPECIAL SELECTION PROCEDURE FOR LOW SERVO PISTON - SERVICE TIP
TRANSMISSION - 4R70W - UNIQUE CASE WITH LOW/REVERSE SPACER - SERVICE TIP
96-7-6
MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATION - CODE 0446 STORED IN MEMORY - VEHICLES BUILT FROM 12/21/95 THROUGH 2/8/96
LAMP - MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATION - CODE 0446 STORED IN MEMORY - TAURUS/SABLE VEHICLES BUILT FROM 12/21/95 THROUGH 2/8/96 AND EXPLORER 5.0L BUILT FROM 2/5/96 THROUGH 3/14/96
96-4-19
TRANSMISSION - 4R44E/4R55E - TRANSMISSION OVERHAUL AND SEAL KIT - SERVICE TIP
96-3-20
TRANSMISSION - 4R44E/4R55E - SCREEN AND GASKET SERVICE KIT - INCORRECT PARTS - SERVICE TIP
95-23-1
PAINT - 1996 COLOR CHART - AFTERMARKET SUPPLIER CROSS-REFERENCE LIST
95-21-1
SUPPLEMENTAL RESTRAINT SYSTEM - AIR BAG MODULES - DISCOLORED OR MARRED COVERS - PAINTING RESTRICTIONS
95-19-13
TRANSMISSION - 4R44E/4R55E - DIAGNOSTIC SERVICE TIP
95-18-4
AIR CONDITIONING - FORD APPROVED FLUSHING PROCEDURES - SERVICE TIP
95-16-1
SHEET METAL - ROOF PANEL AND DRIP RAIL REPLACEMENT - SEAM SEALER APPLICATION PROCEDURE
________________
TSBs found:115
