1997XLTRollover
- February 28, 2007
- 1996 AWD 5.0
Hey guys, long story short I completely rebuilt the 302 in my 96 Explorer. It's now a 306 and had the heads cleaned up so may have a hair higher than factory compression. Engine is still stock everything including cam and heads, only had a minimal amount taken off to clean the head deck up).
Anyway I have 1600 miles on the engine now and I can't get better than 10-11 mpg. It also sputters once every couple weeks like it wants to stall. I'm thinking it doesn't have the power to keep running because the compression is too low and that may be causing this. I checked for vac leaks and found none at all.
The truck seems to run decent, starts up ok and has no real drivability issues or noises but isn't super super smooth and kind of seems flat (my buddies say I'm crazy but something felt off). So this lead me to do a compression check.
I only tested 3 cylinders, 2 on the passenger bank and 1 on the drivers and all 3 read 125-130 psi cold and 130-135 warm without adding oil to the cylinder. This to me seems pretty low, could my machine shop have screwed up the hone job and my engine isn't broken in right? Or am I freaking out for nothing? I feel like the thing should have more power than it does and have at least a 160 psi cylinder pressure.
