turboexplorer
- August 23, 2008
- Eagle Mountain, UT
- 98' XLT 5.0L 4X4
- Callsign
- Turbo
So this weekend I started on the winch mount. I am super happy with the results so far, but it has also taken a bit more effort than I originally thought as the winch is very tight in there but is a perfect placement.
Front bumper removed.
Got bumper set aside and winch out for fitment.
This is what it started as.
Quick throw in to see a rough idea on placement. I already knew I would have to move the transmission cooler up some.
Holding the winch up higher with 2X4's on the cross memeber and the jack stands on the front. You can see the edges of the frame bumper horns where I had to cut a bit so it will clear easy as the frame horns roll around about 1/2-5/8"
Can see how tight the initial fit was to the motor.
