Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood
Notices
Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories.
OIL PRESSURE READ LOW? READ THIS!
Reply
Thread Tools
Old 02-19-2002, 12:53 PM   #1
rjc
CA
1993 XLT
Vehicle Specs
(Original Poster)
While my explorer was never as bad as the one below I wanted to post these links with a short description of the problem. Basically, the RTV pan gaskets can break down over time leading to chunks of gasket material in the oil pan which get sucked into the oil pump screen clogging it and leading to problems with oil pressure. I've had variable pressure readings mostly on the low side for a while now. My pressure reads pretty good only when hot on the freeway. I'm going to use the Matt88 method and try to modify it to work even better.
Matt made a coat hanger the correct shape to scrap his oil filter screen by going through the oil drain plug hole and then rinsing his pan through the oil senser hole. All in all it's a great idea. I am thinking about finding some small copper or steel tubing to fabricate a mini vaccum or spray device that will unclog the screen directly. It's gotta be small diameter so I went to home depot and see they have 1/4" copper tubing for refrigerator water line. If I can't find anything smaller I'm going to buy some and try to bend it to the appropriate shape to reach the screen. I haven't figured out the rest of it yet but am toying with the idea of injecting WD-40 or other solvent directly onto the screen through the copper tubing or hooking up the copper tubing to some kind of suction system to see if I can make a mini gasket/vac to scrape and suck gasket material from the filter. Any suggestions would be appreciated. In the end this will be a lot faster than dropping the pan. Has anyone dropped the pan without removing the engine or transmission and gotten it back together correctly again? rc
http://www.glue.umd.edu/~singletn/exp.html
http://www.glue.umd.edu/~singletn/we.../oilflush.html
rjc is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
