| EF Swag Store | 2013 Ford Explorer | Forums | Elite Membership | Chat Room | My Posts | Reviews | Explorer Photo Gallery |
| Hybrids, Electric, Hydrogen, Bio-diesel, E-85, Fuel Economy Discussion This forum is for information and discussion of fuels for tomorrow and fuel economy tips for our current vehicles. Hybrids, Electric, Hydrogen, Bio-diesel, Natural Gas, Propane, E-85 which will become our next mainstream fuel? |
Thread Tools |
#1401 |
Wannabe Elite Explorer
UK, Richmond, Surrrey.
2000 Northface
How do you ride with 40 psi?
I have dropped mine to 28 as its way too firm for my softer bits! Or maybe the roads here are rubbish- (think an airstrip in Kuwait would be smoother)! I drive mostly in the suburbs in Surrey England. I guess on a highway I will give 40 psi a try- Good luck to you with your fantastic milage. __________________ H http://www.reverbnation.com/scratchthemonkey Kevin P shackles, TT twist, induction kit. UK 2000-Northface. |
#1402 |
Elite In Memoriam
1999 XLT
I notice very little difference in ride quality from 37 psig to 40 psig.
How are your shocks? __________________ Al Franklin My truck My Quest for 30 RIP Al Franklin! 1947-2010. Gone but not forgotten! :( |
#1403 |
Sykesville, MD
'00 XLS, '03 Sport
28 is too low and not good for the tires. I suggest a minimum of 32lbs.
__________________ 2000 XLS, 4DR, 4x4, OHV, Manual ; 2003 Sport, 2DR, 2WD, SOHC, Manual Mobil 1 & Amsoil Synthetic Fluids, 2WD switch Brown wire mod, KKM air intake, overhead console, lighted sunvisors, custom 2nd HU install, '03 Ranger Fog lights, Hurst short-shifter, 75MM MAF, BBK 66MM Throttle Body My 2000 Explorer |
#1404 |
Ontario, Canada
06 F150 SC 5.4
I ran at 45psi (max 50) this summer.. did notice a small difference in gas mileage (was at 32psi).
__________________ 2006 F150 XLT Supercrew 5.4L 1994 XLT 4.0L 1997 XL 4.0L |
#1405 |
wooster, ohio
2001 XLT 4x4
Al,
I remember a while back you where researching new tires and the effect of rolling resistance on mileage. Have you made a decision on new tires? I imagine you are looking at more of a “highway/street” tread as compared to the RT/S? Have you thought about moving down a size to a 225? Just curious, your thread is very informative. Thanks Drake |
#1406 |
Knoxville, TN
98 Mountaineer A4WD
Many tires ride smoother with higher pressures than other tires. Of course those tires which have a 44psi MAX rating can be used with higher pressures than 35psi MAX tires. I have also had tires which rode more harshly with average air pressures, my last sets of Yokohama tires were that way. My current Destination AT tires are a little softer now, with the same (38/34)psi pressures. Regards,
__________________ Don 91 Lincoln LSC/SE, 99/93 Explorer Limited 4WD, 98 AWD Mounty with 255/55/18's, big sway bars, and 12.75" x 1.25" rotors. Soon a BW4406, built trans, stereo and interior. The best thing that could help us all, is the Fair Tax Plan. Be American, Buy American (Manufacturer)
#1407 | |
Blaine, MN
2000 Sport (2-door)
Quote:
![]() _redman2 |
#1408 |
Sammamish,WA
01 Sport Trac
28 is way too low. The door sticker on mine recommends 32 front and 36 rear. I put 36 front, 38 rear and don't notice any ride difference. The rollover problems with the Firestone tires were caused by underinflation.
__________________ 2001 Sport Trac 4x4, AEM Brute force intake, syn fluids, Gibson cat-back exhaust |
#1409 | |
St.Albert, Alberta
1991 XLT 4x4
How to get better mileage from First Generation 1991 XLT 4x4
Quote:
I drive a 1991, XLT, 4x4, 4 Door Explorer. 175180 kms (108851 miles) Mods include. Warrior Shackles and F150 Spacer - Gave me 2" Lift KKM True Rev Air Fliter Kit - The Cone shape Airfilter New Exhaust - Removed Catalitic converter, New pipe increased size by 1/4" New Tires, Stock size inflated to 34 PSI Regular Oil Changes using Penzoil non synthetic The Ex is in good overall shape and had a tune up within the last 2yrs. I'm not sure what the gear ratio is. I've been tracking my fuel consumption for a few years but never did any calculations until I ran across this amazing thread. First off I want to make sure I'm doing my calculation correctly: I'm canadian so I work in Kilometers/Litre then convert to MPG. Ex. from my records Travel 366km then fill up tank with 59.86 liters. I divide 366km/59.86Litres to get 6.11 Km/L. Is this correct. Then I've been coverting the Km to Miles and Liters to U.S Gallons(Liquid not Dry Gallons) and dividing. To Give me 277.42 Miles / 15.81 Gallons =17.54 MPG. I used a website to do the conversions individually and Liters to Gallons (U.S Liquid). A previous suggestion on this site I could multiply KM/L by 2.85 to get MPG but this gives a much higher MPG than calculating my way, Maybe I misread this? Using my method of calculation gives me a really crap number compared to many others on this thread. I'm consistantly getting around 17 MPG. Is this consistant with all the other first Generation explorers out there? Am I above or below average. What can I do to improve my mileage? cheers Russ |
#1410 |
Anchorage, Alaska
'97 Explorer XLT AWD 5.0L
366 kilometers is equal to 227.422 miles
59.86 liters is equal to 15.813 gallons (US) 227.422/15.813 = 14.382 __________________ Daily Driver: 1997 V8 Explorer - K&N FIPK, Granatelli MAF, 3" Body Lift, WAR-153 Shackles, Torsion Twist, custom-built skidplate. 4.56s, Ion Alloy 133's, 33x12.5 Interco TrXus STS. 1986 Bronco2: RIP |
#1411 | |
St.Albert, Alberta
1991 XLT 4x4
Quote:
Yikes thanks for the correction, so my MPG is actually around 14 MPG, even worse than I thought. This is insane, my explorer is in great condition and its a pig on gas it seems compared to other explorers. What do other first Generation owners get for mileage?? |
#1412 |
Mississauga Ontario Canada
'94 XLT
I have 1 94 xlt and I get around 15-16 KPL. I have been trying everything to get more... I'm thinking of getting one of those "improve millage chips" but all my research shows that some of them work and some don't.
__________________ Trucks are like women... (Pick ur own joke here) |
#1413 |
'94 XLT
I have a 94 xlt and I get around 15-16 KPL. I have been trying everything to get more... I'm thinking of getting one of those "improve millage chips" but all my research shows that some people say they work and some people say they don't.
#1414 |
Elite In Memoriam
1999 XLT
A chip will do little if anything for your model year truck. Sorry.
#1415 |
Brooklyn NY
1997 XLT
Aldive, may I also suggest that, you're getting good MPG also because the amount of traffic lights in FL. I remember when I visited Fort Lauderdale 2 Summers a go, driving down I haven't stop at a traffic light for about 2-4 miles. Here in NYC, you get about a light every block... which kills the MPG and time, off course you can cruise down the block when you see the light but even when you get to the end of the block, it's still not green yet.
![]() And also, I have also seen smoother steering with more PSI in the tires, went from 30PSI to 35PSI, and it seems like I get more faster pick up from traffic lights.
#1416 |
Aerostar Forum Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
NY also has 10% ethanol in their gas while Florida doesn't.
#1417 |
Elite In Memoriam
1999 XLT
All of my mileage testing is highway only driving. I rarely monitor in town mileage,
#1418 |
Jelgava, LV-3008
Not really Explorer, it's '89 Bronco II with 2.9 V6. Getting 12.7 l/100km = ~18.5mpg. No mods, just stock. |
#1419 | |
Anchorage, Alaska
Quote:
You cannot compare a Bronco2's gas mileage with an Explorer's __________________ Daily Driver: 1997 V8 Explorer - K&N FIPK, Granatelli MAF, 3" Body Lift, WAR-153 Shackles, Torsion Twist, custom-built skidplate. 4.56s, Ion Alloy 133's, 33x12.5 Interco TrXus STS. 1986 Bronco2: RIP |
#1420 |
Dalhart, TX
2001 sport trac
Al
Torrie at fastpartnetwork has been working on a new tune that is supposed to get a little better fuel mileage. You might get ahold of him._Ron
| Thread Tools | |
