Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > General Explorations!!
Notices
General Explorations!! Closed to new posts. Place new posts in our new model year appropriate forum
Reprogramming Remote Keyless Entry
Thread Tools
Old 03-24-2002, 04:09 PM   #1
Chris94LTD
Coral Springs, FL
'94 Limited
Vehicle Specs
(Original Poster)
Question Reprogramming Remote Keyless Entry
I have recently purchased a '94 Explorer Limited and love it! I have accidently deprogrammed my remote entry by removing fuse #1 while the ignition was on. The symptoms I experienced were that the locks cycled and the horn beebed once. After visiting my local Ford dealership, he said they normally charge $35 to reprogram keyless entries, but after some prodding, said that I could try cycling the ignition 8 times then press a key on the remote. His method was correct, but not for my particular year. After some searching, I found "Remote Keyless Entry TSB 97-24-13" at http://www.v8sho.com/SHO/Remote%20Ke...2097-24-13.htm . It said for the 1994 model to "Turn ignition to RUN or ACC. Momentarily jump pins in programming connector located in left rear quarter panel area ..." The trouble is - the keyless module has three connectors with 13-16 pins each and I don't know which pins to momentarily short. I do not see any other eligible connectors inside the panel. Would someone be able to guide me with this problem?
Chris94LTD is offline
Old 03-25-2002, 09:49 AM   #2
TSTONE
Giddy up!
Oakland County, MI
TSTONE's Avatar
97 Mountaineer
Vehicle Specs
the connector you are looking for is light gray and about the size of your finger tip from the last knuckle forward, and only has 2 thick pins in it (about the diameter of a pen ink cartridge), also are you certain that you have a factory keyless remote system, they were pretty rare in 94, the remotes - fcc id # should be - GQ43VT4T, and TRW part# 3165189
__________________
“Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways, pork rhines in one hand, bottle of jack in the other, body thoroughly used up, totally worn out and screaming “WOO HOO what a ride!”
TSTONE is offline
Old 03-25-2002, 03:01 PM   #3
weebo
Louisville, KY
'92 XLT & '97 XLT
Vehicle Specs
does this process apply to my '97 as well. with the circumstance of rebuilding a wreck, i didn't receive the remote, but i ordered two off of ebay for my model year. he said he'd include programming instructions, but i'll believe it when i see it.
__________________
Randy
'97 XLT SOHC, K&N Gen II FIPK, 2" TT & Warrior Shackles, 31" x 10.50" BF Goodrich AT KO's, Safari Bar w/ Piaa 540 lights, Piaa Platinum White Headlamps, Aux. Tranny Filter, NR Auto Indiglo Gauges
weebo is offline
Old 03-25-2002, 05:44 PM   #4
'96explorereddiebauer
Explorer Emeritus
Clemmons, NC
'06 Honda Accord EX-L
Vehicle Specs
Weebo, for yours, it is letter D on that sheet, but don't go to the ACC position, stop at the Run position.
Got a question...on the sheet, where it has the troubleshooting section. There is a sub-section about the problem with turning off the Panic alarms. Their solution is to reroute the antanna assembly. Where is the antanna assembly??
__________________
Billy
'00 Acura Integra GS
'98 Honda Accord EX-V6
'05 Honda Odyssey EX-L
'96explorereddiebauer is offline
Old 03-25-2002, 11:05 PM   #5
Chris94LTD
Coral Springs, FL
'94 Limited
Vehicle Specs
(Original Poster)
Talking
Todd,
Thanks a lot for your help!
My programming connector turned out to be a black receptacle type, hiding with the tail light connectors on the left of the washer fluid reservoir.
My remote entry was definitely factory installed, with the Ford key fob numbers matching the ones you gave.
I was so lucky to find this truck. It was originally from Texas and is in mint condition. It had 116k mi when I bought it, 119k now. Only work I did was to change front pads and rotors, v-belt, some filters, oil and tighten some bolts on the I-beam suspension.
__________________
Chris
White 94 Explorer Limited 4dr 4x2 4.0
Factory Installed: tilt-up sun roof, roof rack, overhead console (outside temp, compass, map lamps, garage opener), lighted vanities, auto-dim rearview mirror, heated pwr sideview mirrors, cruise ctrl, 8-way pwr leather seats w/pwr lumbar, JBL sound sys, tinted glass, rear window washer/wiper/defogger, fog lights, running boards, alloy mags, hitch pkg, remote entry & anti-theft sys.
Old 03-26-2002, 12:08 AM   #6
Steve94LTD
Chicago, IL
94 Limited
Vehicle Specs
you copied my user name. heh
Steve94LTD is offline
Old 03-26-2002, 08:53 AM   #7
TSTONE
Giddy up!
Oakland County, MI
TSTONE's Avatar
97 Mountaineer
Vehicle Specs
Quote:
programming a 95/96/97
cycle iginition from off to run 5 times within 10 sec, ending in run, all doors will lock then unlock to confirm programming mode, press any button on the 1st remote transmitter. door locks will cycle(lock then unlock) to confirm programming. to program additional remotes - press any button on the next remote(upto 4 total possible) locks will cycle again. turn iginition off. locks will again cycle to indicate the end of the programming mode.
programming a 98/99/00/01
same as above - but cycle iginition off to run 8 times within 10 seconds
__________________
TSTONE is offline
Old 03-26-2002, 09:48 AM   #8
weebo
Louisville, KY
'92 XLT & '97 XLT
Vehicle Specs
Excellent! Thanks for the great info!
__________________
Randy
weebo is offline
Old 04-24-2002, 09:47 PM   #9
Firedawgy
Charleston, SC
2002 XLT 4x4
Vehicle Specs
Well so far tonight I have learned an awful lot about my 97 E.B. from this web site. Maybe someone can help me with this reprogramming. Anyone know the programming instructions for a 95 Ford Windstar. I am sure its just like the X of the same year but just like to make sure before I short the van out.
Firedawgy is offline
Old 04-25-2002, 10:53 PM   #10
Chris94LTD
Coral Springs, FL
'94 Limited
Vehicle Specs
(Original Poster)
Firedawgy,
For the 95 Windstar, follow the instructions letter "H" from the Remote Keyless Entry (RKE) Technical Service Bulletin (TSB) link listed in my original post ...
H. Turn ignition to RUN or ACC. Momentarily jump pins in programming connector located behind glove compartment. All doors will lock then unlock to confirm programming mode. Press any button on 1st transmitter. The door locks will lock then unlock to confirm programming. Press any button on 2nd transmitter (up to 4 transmitters total possible). Turn ignition to OFF. The door locks will lock then unlock to confirm programming.
__________________
Chris
Old 11-22-2002, 01:26 PM   #11
bgomez
Anaheim, CA
98 Explorer Sport
Vehicle Specs
Hi I have 98 Explorer sport and it only came with one remote. I got a couple more from ebay and was trying to program the new ones. I turn the key from off to on 8 times leaving it on on.
the door locks the first time I go from off to on. But when I get to the 8 turn the door locks don't unlock to confirm programming. Am I doing something wrong or do I need to do something else?
bgomez is offline
Old 11-22-2002, 01:36 PM   #12
Robert
Mesa, AZ
'97 4x4 Sport
Vehicle Specs
It sounds like your current keyless entry system is an aftermarket system. Your locks shouldn't lock the first time you turn your key to on with the Ford factory system. The only time I have seen that happen was on aftermarket keyless entry systems, usually as a part of a carjacking feature. If you have the factory system, you turn your key off-on 8 times. On the 8th time, leave your key on. At that time your locks should lock and then unlock. Then you would press a button on each remote to program it. Each time you press a button, your locks will cycle to confirm. Do you have the keypad on the outside of your driver's door? If not, then you probably don't have the factory keyless entry system. If you do, then it's possible your RAPS module might be bad.
__________________
4.56 Powertrax No-Slip, SOHC V6, SuperChip, K&N FIPK (#57-2513-1), Borla cat-back (#14748), 2" torsion lift, 3" PA body lift (#853), Monroe Reflex shocks, 285 75R16 BF Goodrich T/A ko, 2WD mod
Earnhardt Ford, Berge Ford, U-Haul
My Explorer
Robert is offline
Old 11-22-2002, 01:51 PM   #13
bgomez
Anaheim, CA
98 Explorer Sport
Vehicle Specs
Thanks for the quick reply. I don't have a keypad outside my door. But the remote itself that came with my explorer has the ford name on remote itself. It's still a ford product from the looks of it.
bgomez is offline
Old 11-22-2002, 07:21 PM   #14
Robert
Mesa, AZ
'97 4x4 Sport
Vehicle Specs
Ford also offers a remote entry system as a dealer installed add on that gets installed by the dealer rather than during manufacturing. It still carries the Ford logos, but is manufactured by another company. That sounds like what you have since you don't have the keypad. In '97 the only way to get the remote keyless entry was with the keypad. I am assuming that '98 was the same way.
__________________
My Explorer
Robert is offline
Old 03-10-2003, 04:02 PM   #15
Metallic2001
charleston, sc
1994 explorer limited 4x4
Vehicle Specs
I have a 94' limited too and I dont have the remote key that came with it and I am planning on getting another one and I am going to try to program it myself b/c the ford dealership said they would charge me $60 to do it....what did u mean by "momentairly jump the pins in the programming connector located in the rear?" after u turn the ignition to "acc"
Metallic2001 is offline
Old 03-26-2003, 11:54 AM   #16
Positive Vibes
Santa Cruz, Ca
Positive Vibes's Avatar
'94 XLT
Vehicle Specs
Chris94LTD: So did you get the remote to work. I just got one and I'm still unclear to which pins we jump together?? On which connector??? Thanks!
__________________
'94 XLT, 5.5" superlift, cat back flowmaster, KKM, custom rocksliders, 33X12.5 XTerrains, 4.10's, custom bumpers, Detroit in 8.8, on board air, ARB locker in front winch,etc.
What is greater than God, More evil than the devil, The poor have it, The rich need it, And if you eat it, you'll die?
Positive Vibes is offline
Old 03-26-2003, 07:32 PM   #17
rangerjeff
Cass City, MI (Outcast in Chevy country)
1998 XLT 5.0 AWD
Vehicle Specs
how to unlock ALL doors when key turned off
On my 98 XLT, how can I get it to unlock ALL the doors when I shut off the ignition ? It locks all 4, but only unlocks the drivers door. I could not find any info in the owners manual.
__________________
Don't cross-breed america. If you own a Ford, it better be powered by Ford.
rangerjeff is offline
Old 03-26-2003, 09:57 PM   #18
VairKing
Midwest-Xplorer Member
Kalamazoo, Michigan
VairKing's Avatar
'97 EB V8 AWD
Vehicle Specs
I would be interested in how to make the truck unlock the doors after the truck is turned off as well.
When I first got the 97, I had to program a keyless remote fob for it. To do this (on a 97 anyway) turn your ignition on and off 5 times within 10 seconds, after the 5th time the locks will lock then unlock, then press any button on your remote and the locks will cycle again. Then the new remote is programed.
VairKing is offline
Old 03-26-2003, 10:47 PM   #19
Metallic2001
charleston, sc
Vehicle Specs
Wish it was that easy for my 94
__________________
drive it like you stole it
Old 03-27-2003, 10:08 AM   #20
Positive Vibes
Santa Cruz, Ca
'94 XLT
Vehicle Specs
So who has a 91-94 and has succesfully programed a remote entry????
__________________
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
