Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Offroad Tech Forums > Offroad Explorer - Ranger Projects > Explorer - Ranger Shocks, Suspensions, Lift Kits
Notices
Explorer - Ranger Shocks, Suspensions, Lift Kits Ford Explorer and Ranger chassis related posts. Get help choosing the right shock absorber and aftermarket suspension for your Explorer or Ranger based vehicle.
Torsion Bar 101, Everything you Need to look for!
Reply
Thread Tools
Old 05-03-2006, 11:02 AM   #261
hokiej21
Richmond,VA
97, Mountaineer
Vehicle Specs
so would that exact body lift work on my truck and what size tires can i fit with that and a TT and add a leaf?
hokiej21 is offline   Reply With Quote
Old 05-14-2006, 07:58 PM   #262
xman98
home-Norwalk, CT school-Springfield, MA
xman98's Avatar
98 XLT
Vehicle Specs
Question
hey guys, ive read through the hole thread and i have a couple of questions.
When I do a TT and shakles in the back does it lift the body and suspension or just body because i have a brush guard bolted to the frame and when i do a tt will that effect the brushguard. Its conected in two spots, mounting brakets underneath and 2 between the front bumper and grille conected to the top of the frame. Will the brush guard still be in line with the front of the X or will it then be lower and the light guard arms off the main frame of the brush guard not match up because of the lift?
thanks, great work and research done on the topic!
__________________
stuff for sale.....
xman98 is offline   Reply With Quote
Old 05-14-2006, 08:14 PM   #263
SkanlaxJMO
Syracuse, New York
96 XLT
Vehicle Specs
it is a suspension lift
__________________
2005 F-150
SkanlaxJMO is offline   Reply With Quote
Old 05-14-2006, 08:32 PM   #264
xman98
xman98's Avatar
98 XLT
Vehicle Specs
therefore the brush guard will be fine?
__________________
stuff for sale.....
Old 05-28-2006, 08:21 PM   #265
SkanlaxJMO
Syracuse, New York
96 XLT
Vehicle Specs
yes
__________________
2005 F-150
Old 05-28-2006, 09:06 PM   #266
xman98
xman98's Avatar
98 XLT
Vehicle Specs
great, thanks for the answer
__________________
stuff for sale.....
Old 08-12-2006, 10:07 PM   #267
TomFord
Tewksbury,MA
Explorer '95 XLT
Vehicle Specs
if i do the TT and use these shackles ( http://www.tellico4x4.com/product_in...oducts_id/6362 ) what size tires will i be able to put on with out rubbing? Also where do you measure from the ground to the fender?
thanks
tom ford
TomFord is offline   Reply With Quote
Old 09-23-2006, 08:56 PM   #268
m4dc0w
Edmonton, AB, Canada
Explorer 97XL
Vehicle Specs
Hey guys,
Does anyone know a local dealer that may stock warrior shackles in Western Canada? or a US dealer that ships to Canada??
-mc
m4dc0w is offline   Reply With Quote
Old 11-09-2006, 02:34 PM   #269
JIGAWHAAT
Vehicle Specs
tt question
after reading all of the posts on tortion twists i climbed under my 97xlt to see what it looked like. well to my surprise the bolt on the passenger side is sticking down about 2 inches and is on an angle. is this a major problem?
thanks
jeff
i can take pics of it if needed
JIGAWHAAT is offline   Reply With Quote
Old 11-09-2006, 02:36 PM   #270
MountaineerGreen
Towing Moderator
North East Arkansas
MountaineerGreen's Avatar
2012 F150 4x4
Vehicle Specs
Quote:
thanks
jeff
Nope, thats normal.
MountaineerGreen is offline   Reply With Quote
Old 11-09-2006, 03:54 PM   #271
JIGAWHAAT
Vehicle Specs
cool
thanks for the reply
jeff
Old 12-25-2006, 01:00 AM   #272
98goldexplorer
Pine Bluff, AR
98
Vehicle Specs
so if ur tightening the torsion bolts its givin lift.........how much would u need to losen if ur trien 2 get from 2"-3" of drop
98goldexplorer is offline   Reply With Quote
Old 02-18-2007, 03:17 PM   #273
Firehawk88ta
New Milford CT
2001 Sport
Vehicle Specs
read the whole thread, still have a question, i have a 01 Xplorer Sport(not the truck) and im doing the TT on the front, im gonna do the shackle in the back(well i like to) but i read one post where it said the spring will flatten out? if so is that bad? its a daily driving truck and it will see off-road time(mainly mud pits, but trail rides also) if thats the case, will a AAL work? i wanna jack the back up 2" and the front bout 1.5" to level it out. is that correct. also the truck has the towing package whats the difference? just the rear springs or the bars 2?
__________________
1988 Pontiac Trans AM - Worked 305 TBI. 406 SBC to come
2001 Ford Explorer Sport - Stock, for now, moms ride
Firehawk88ta is offline   Reply With Quote
Old 02-18-2007, 03:20 PM   #274
98goldexplorer
Pine Bluff, AR
98
Vehicle Specs
id guess rear springs but im not sure....best to do is get the shackle kit and probably some better leafs for the back
Old 05-02-2007, 07:03 PM   #275
TRILBYREDNECK
DADE CITY, FLORIDA
04 RANGER EDGE
Vehicle Specs
FOR A TORTION LIFT ON A 04 RANGER DO YOU JUST TWIST THE ADJUSTER BOLTS OR DO YOU TWIST THE WHOLE BAR CAN SOMEONE GIVE ME A QUICK STEP BY STEP thanks my ranger is 2wd and i want to make the front level with the rear how long can i dive it before i need front end alined will it damage any parts
TRILBYREDNECK is offline   Reply With Quote
Old 05-28-2007, 09:46 AM   #276
Bob McNabb
1999 4x4 ranger
Vehicle Specs
1999 Ranger torsion bar
My torsion bar cracked while in 4wd. Road was a little rugged but not that bad. What would cause this? Metal fatigue or something? what about wear of other front end suspension parts would that cause the bar to crack? what should I look for? Link rod (that goes to lower control arm seems to have bad rubber) ANy help or suggestions would be GREAT. Can I drive the truck at low speed 6 miles to the shop without damaging anything?
Bob McNabb is offline   Reply With Quote
Old 05-29-2007, 03:28 PM   #277
TRILBYREDNECK
DADE CITY, FLORIDA
04 RANGER EDGE
Vehicle Specs
i would not drive it but i work for a towing company i will cut you a hell of a deal to tow it call me 813-802-1502
Old 06-17-2007, 06:13 AM   #278
Beowulf
Corn Country Indiana
00 Ranger XLT 4X4
Vehicle Specs
I have to say, this has been a very informative thread. There are definitely answers to a lot of questions I have had in the past. Nice work gang!!
Beowulf is offline   Reply With Quote
Old 06-19-2007, 06:28 PM   #279
mace
Mullica Hill, NJ
2000 Mountaineer AWD 5.0
Vehicle Specs
this thread saved me a headache...thx !
thanx for this write up. i had my lower ball joints and control arms done today, but the torsion bars were put back as low as they can get. i guess they forgot to wrench them down...it looked so screwed up all lowered. didnt notice til i was on the road....so i got home and i just cranked em up evenly, and im ok. doesnt seem to pull either, so i guess i got it right. the headache would have been driving down there and complaining, and not knowing about this adjustment, and looking dumb. plus not having the truck for another day. thanx again for this write up !
__________________
my ride :http://www.cardomain.com/ride/810998
mace is offline   Reply With Quote
Old 07-29-2007, 04:19 PM   #280
sid23man
clevelan, tennessee
sid23man's Avatar
'98 XLT
Vehicle Specs
the link doesnt work for me??
sid23man is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
