Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Offroad Tech Forums > Offroad Explorer - Ranger Projects > Explorer - Ranger Shocks, Suspensions, Lift Kits
Notices
Explorer - Ranger Shocks, Suspensions, Lift Kits Ford Explorer and Ranger chassis related posts. Get help choosing the right shock absorber and aftermarket suspension for your Explorer or Ranger based vehicle.
Torsion Bar 101, Everything you Need to look for!
Reply
Thread Tools
Old 01-07-2008, 12:00 AM   #301
TheChadders
Parker CO
97 XLT
Vehicle Specs
so when installing the torsion bar bolts a longer set to get the 2" of lift is it like a hit and miss?
__________________
Chad F.
My ride
TheChadders is offline   Reply With Quote
Old 01-07-2008, 06:56 AM   #302
briwayjones
Sykesville, MD
briwayjones's Avatar
'00 XLS, '03 Sport
Vehicle Specs
If you have 4wd and lift it more than two inches using a torsion twist it will put improper stress on the CV joints and make them wear prematurely.
__________________
2000 XLS, 4DR, 4x4, OHV, Manual ; 2003 Sport, 2DR, 2WD, SOHC, Manual
Mobil 1 & Amsoil Synthetic Fluids, 2WD switch Brown wire mod, KKM air intake, overhead console, lighted sunvisors, custom 2nd HU install, '03 Ranger Fog lights, Hurst short-shifter, 75MM MAF, BBK 66MM Throttle Body
My 2000 Explorer
briwayjones is offline   Reply With Quote
Old 01-07-2008, 11:42 AM   #303
BocaJApache
Lubbock, TX
96 Eddie Bauer
Vehicle Specs
I have a 96 4x4 EB and it has 31" on there. How do I know if the previous owner already did the TT on it? I am going to put the shackles on there but not sure if they already did the lift on the front.
The rear seems low so most def shackles are going on.
BocaJApache is offline   Reply With Quote
Old 01-07-2008, 01:49 PM   #304
TheChadders
Parker CO
97 XLT
Vehicle Specs
sorry i worded that wrong i know that you cant go past the two inches or you can cause damage to the cv but i am planning on doing this so when i am installing the longer bolts do i just twist and measure. I understand that you need to lift the truck up in the front at least or the torsion bolts could snap so do i just twist and set down and measure untill i get the desired height of 2"?
__________________
Chad F.
My ride
Old 01-07-2008, 03:34 PM   #305
BocaJApache
Lubbock, TX
96 Eddie Bauer
Vehicle Specs
soooo, what is the measured clerance from what point to what point when you are done with a 2" lift with shackles and TT?
Old 01-07-2008, 07:30 PM   #306
Paraphoe
Go big or go home
Willow Grove, PA
Paraphoe's Avatar
'97 XLT
Vehicle Specs
Quote:
Twist, measure and repeat. That's the best way, because everyones truck is going to be different. I was told it would take about 6 turns of the bolt to get the 2''. I was at well over 6 turns when my bolts bottomed out before getting 2'' of lift. I needed to order new bolts and give a bunch more turns before I got there.
__________________
Jason
Truck - Mug - Bling
"These good times will never last, keep your hand on the wheel and your foot on the gas."
Paraphoe is offline   Reply With Quote
Old 01-07-2008, 09:35 PM   #307
98goldexplorer
Pine Bluff, AR
98
Vehicle Specs
hell it takes me 3 90 degree cranks to lower 1/2 inch
98goldexplorer is offline   Reply With Quote
Old 01-08-2008, 12:35 AM   #308
jodigirl
Las Vegas, Nevada
jodigirl's Avatar
"96 4x4 Sport
Vehicle Specs
I had mine adjusted about a year ago, it was off by 1 1/2 inches, but just on the right side. Why is that, and what makes the bar loosen?
jodigirl is offline   Reply With Quote
Old 01-10-2008, 02:21 PM   #309
chaseracer22
Decatur, AL
98 XLT
Vehicle Specs
cant you get like 3" torsion keys that lifts the front like 3" and if u can, can u twist the bolt that gives bout a in and a half and get the keys so that your front will end up being lifted about 4 1/2 inches?
__________________
98 xlt v8 5.0 awd
bull bar
cb
valor 700w
2 12s
1200 watt amp
now all the stuff i got that aint in yet:
3" bl
pa speaker for cb
and soon to buy:
roof rack
33" tires
chaseracer22 is offline   Reply With Quote
Old 01-24-2008, 08:18 PM   #310
03 Edge
Quebeck, TN
'03 Ranger Edge
Vehicle Specs
i ordered some torsion keys from ebay and they didn't fit in the cradles and after i grinded them to fit they made my bars bend in the middle. could i replace my bars with
4wd bars and make my keys work?
03 Edge is offline   Reply With Quote
Old 01-24-2008, 10:22 PM   #311
98goldexplorer
Pine Bluff, AR
98
Vehicle Specs
its possible but im not sure.........what would be another good way to lower my truck w/ torsion bars after i done cranked a 3 inch drop out of them?
Old 01-26-2008, 05:42 PM   #312
Burns
EF Late Night Crew
Memphis, TN
Burns's Avatar
1991 Explorer/2002 F-250
Vehicle Specs
If anyone could help him out i would be thankfull. He is a good friend and is in my area. Thanks
__________________
Jonathan Burns
Moderator of the Feature Truck Forum
Owner of the "Lime"
Forum Rules and Usage
Burns is online now   Reply With Quote
Old 03-09-2008, 10:01 PM   #313
storlied
Anchorage, Alaska
98 5.0L V8 AWD XLT
Vehicle Specs
How am I supposed to know when it's level with the rear? The 2nd gen Explorer body is kinda weird, the top of the wheel well things is lower than the front.. which no matter what you do makes it look sagging.. [unless your rear was higher than the front]
What's the best way to measure to see if it's all leveled out?
I figure for the TT, measure from the top of the wheel well to the ground.. but the back will be all weird... so idk
__________________
Lifted 98 302
Quote:
Originally Posted by joel903 View Post
These freaken explorers! Everything breaks
Ford: Fixed Or Repaired Daily. But still going, kicking and screaming all the way. =D Yeaaah.
storlied is offline   Reply With Quote
Old 03-10-2008, 03:16 PM   #314
Mbrooks420
High Voltage.
Erie, Pennsylvania
Mbrooks420's Avatar
1998 Mountaineer
Vehicle Specs
Just adjust them so you like the look. They may settle a bit.
__________________
1998 Mounty 5.0 AWD TT/Shackles/rear AirLift springs 31x10.5 Kelly TSR's
1995 Subaru Legacy AWD Sedan RIP---Killed by an suicidal deer
1972 El Camino---Project Dirty Old Chevy---Fresh Marine Longblock .060 over, Forged crank RV Cam 454/th400 swap, Hooker Headers, fresh coat of white
1999 KTM 300exc RaceTech Suspension, Rekluse Slipper Clutch, single track killer
Mbrooks420 is offline   Reply With Quote
Old 03-17-2008, 04:02 PM   #315
5percenttint
Lafayette, Louisiana
2002 Sport
Vehicle Specs
Quote:
im looking to drop mine as well. you got a 3" drop just from cranking the bars? no aftermarket keys or anything? please let me know cause that would be perfect for what im looking for
5percenttint is offline   Reply With Quote
Old 03-27-2008, 07:01 PM   #316
burtonbrd138
Massachusetts
2000 Explorer XLS
Vehicle Specs
orange Torsion
I have a question
burtonbrd138 is offline   Reply With Quote
Old 03-27-2008, 07:07 PM   #317
burtonbrd138
Massachusetts
2000 Explorer XLS
Vehicle Specs
orange Torsion
I have a 2000 Explorer XLS. As of now the back sits lower than the front(about 1.5 to 2 in). I am planning on getting a 4 in rear lift from Superlift, Part#SUP1147. After that it will be tilting front down(oppsite than before). If I do a torsion twist afterwards what are the chances it is level? If i get this lift is it necessary for me to get the aftermarket driveshaft from Superlift that they recomend because the stock one will wear out? or are they just trying to stiff me?
Old 04-02-2008, 11:14 AM   #318
privetryan89
Pa
'98 XLT 4.0 SOHC
Vehicle Specs
Question
Do you guys think my mechanic could do it when I get my xlt inspected or will he say something about bracking some type of law or messing up my alignment. Also, what type of add-a-leaf should I get or would universal lift blocks work (saw them in the new Jegs catalog). This has probbaly been answered but I don't have time to search for it.
privetryan89 is offline   Reply With Quote
Old 04-02-2008, 12:33 PM   #319
Mbrooks420
High Voltage.
Erie, Pennsylvania
Mbrooks420's Avatar
1998 Mountaineer
Vehicle Specs
It depends on your mechanic. Lift blocks will lower your Explorer due to the spring under axle.
__________________
Old 04-03-2008, 01:55 PM   #320
jtmx101
Shreveport, LA
00 XLS 4X4
Vehicle Specs
Quote:
That is the same thing I just did to my 2000 XLS, with the 4 in rear lift, and the tortion twist, the rear on mine sets about one inch higher, it really isnt that noticeable, I would recommend replacing the shocks tho, I used the Superlift Monotube shocks, and they ride really good. as for the drive shaft, im still using the stock one, ill replace it before i lift mine more
__________________
lookin for a new ex
01 Ranger, 5.0 coming soon
Totaled!! 2000 OHV 4X4 Brown wire mod, K&N intake, BBK Throttle body, modified Y pipe, rear cats removed, Single glasspack muffler, TT/AAL/Shackels, 285/70/17 BF Goodrich All Terrains, 17" Crager Soft 8 Rims JL Audio 13.5 subs, kicker 1000w amp
jtmx101 is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
