Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Offroad Tech Forums > Offroad Explorer - Ranger Projects > Explorer - Ranger Shocks, Suspensions, Lift Kits
Notices
Explorer - Ranger Shocks, Suspensions, Lift Kits Ford Explorer and Ranger chassis related posts. Get help choosing the right shock absorber and aftermarket suspension for your Explorer or Ranger based vehicle.
Torsion Bar 101, Everything you Need to look for!
Reply
Thread Tools
Old 05-23-2012, 02:31 PM   #481
WidgetTrac
Cypress, TX
2001 Sport Trac 2wd
Vehicle Specs
With my stock bolts maxxed out, the keys are almost at the end of ther range. If I got bolts that were 1" longer, I would only be able to use a small part of the additional length - basically just enough to cram the tops of the keys up against the end of the seat. To go beyond that, you could rotate the bars 60 degrees to the next hex flat, but that would probably be waaay too much spring pressure!!!
so if you're 2wd or just want MORE, (but not 60 deg. more!), then the keys are a way to re-index.
WidgetTrac is offline   Reply With Quote
Old 05-23-2012, 02:35 PM   #482
CDW6212R
Knoxville, TN
CDW6212R's Avatar
98 Mountaineer A4WD
Vehicle Specs
New keys(aftermarket) used to be $90 or so. The bars were $45 each from Ford, I have "B"'s now.
__________________
Don
91 Lincoln LSC/SE, 99/93 Explorer Limited 4WD, 98 AWD Mounty with 255/55/18's, big sway bars, and 12.75" x 1.25" rotors. Soon a BW4406, built trans, stereo and interior.
The best thing that could help us all, is the Fair Tax Plan.
Be American, Buy American (Manufacturer)
CDW6212R is online now   Reply With Quote
Old 05-23-2012, 02:58 PM   #483
WidgetTrac
Cypress, TX
2001 Sport Trac 2wd
Vehicle Specs
Quote:
Originally Posted by swshawaii View Post
...either method is just lifting and changing the LCA angle.
Don't see how the "preload" or "spring rate" changes...l
Thank you! I don't know how many warnings i've seen about this. Torsion twist is basically the same as a shackle lift in the rear - it doesn't change the springs or their stiffness or rate. you need AAL to do that, or just new springs ot T-bars, or coil springs, or coilover. You can wear springs out or ruin them with heat, but not make them firmer.
To put it another way, the front of your truck doesn't get heavier when you lift it, therefore the tires will still be pushing against the ground with the same force, therefore the same spring pressure.
Except for the very slight change in LCA angle. But that's very slight... usually.
Old 05-23-2012, 03:39 PM   #484
swshawaii
Kailua-Oahu, Hawaii
'05 Sport Trac XLS (RWD)
Vehicle Specs
usually.
You got it Widgettrac!
Claims of torsion keys retaining stock ride quality usually only comes from the people selling them.
The only reason to use them is if they're out of travel, or you don't want to do a torsion key flip to lower.
Stock LCA angles are almost parallel to the frame, small changes will make a huge ride quality difference.
swshawaii is offline   Reply With Quote
Old 05-23-2012, 03:48 PM   #485
WidgetTrac
Cypress, TX
2001 Sport Trac 2wd
Vehicle Specs
There's the man! Anybody who still doesn't get it, go back and read Dons post(s) around the middle pages of this thread!
There are lift key sets for $45 shipped, but they appear to be cut from flat bar instead of forged - maybe not as strong? maybe stronger, I dunno... Maybe tighter tolerances, maybe schmabey - if anyone actually knows anything about the cheap keys in particular, especially anything BAD, please post! I'm almost certain I'll end up going with lift keys, and even though they all basically provide the same function, some are bound to be made better than others...
Old 05-23-2012, 04:14 PM   #486
swshawaii
Kailua-Oahu, Hawaii
Vehicle Specs
Many people despise this company, fortunately I bought my drop keys used.
Haven't ever heard of them failing, mine have served me well without issues.
And if it makes you feel better, call them ChassisTech, NOT AirBagIt. LOL
http://www.airbagit.com/product-p/key-x-fr98.htm
Old 05-23-2012, 04:16 PM   #487
CDW6212R
Knoxville, TN
CDW6212R's Avatar
98 Mountaineer A4WD
Vehicle Specs
For lifting you may be able to find later Ranger keys. The Rangers had keys clocked to provide higher ride heights. So it could be cheaper to buy those used if you have a salvage yard that lets you work on them. I'm not sure of which year models, I just recall reading on the RPS forum about people using the Explorer keys to lower with.
__________________
Don
Old 05-23-2012, 04:54 PM   #488
WidgetTrac
Cypress, TX
2001 Sport Trac 2wd
Vehicle Specs
People also seem confused about whether to do this with the truck sitting on the ground or jacked up. There are pros and cons to either method. The correct method is the method that suits your situation tje best.
FoMoCo says to do it on the ground, but ask yourself "why?" The official procedure was developed for the benefit of the dealership service department, and they do things differently than a guy in his driveway. They do in an alignment bay, where a guy can walk underneath. More significantly, the tires will be on "floating" pads that allow the suspension to settle WHILE you are adjusting, so you can instantly tell exactly how high it is. You set it and you're done , exactly right, right away, and you're ready to move on to the next job. Time is money, so get it done and get it out and get on to the next one.
At home, there aren't any floating pads, so you have to roll the car a few feet to relieve the camber change pressure against the tire sidewalls, so you don't get 100% accurate real-time feedback while doing the adjustment. If you do it on the ground you can still see approximately how much it's moving, but you still have to roll it to see where it will settle. At home, the pros for doing it on the ground are less time spent jacking, and being somewhat able to see the effect of what you're doing while you're doing it.
BUT... those bolts can be a reat biatch! Especially if they've never been moved...
Jacking the front tires off the ground makes the adjusters a bit easier to turn. I counted about 80 "cranks" on my ratchet from top to bottom, which I figure is about 20 full turns. My arms literally fell off, poetically speaking. Anything that helps, helps, so that's why most people do this with the front jacked.
...and also why people who write procedures for dealer mechanics prefer their way. There are good reasons for either method, mostly depending on facilities.
Old 05-23-2012, 05:27 PM   #489
WidgetTrac
Cypress, TX
2001 Sport Trac 2wd
Vehicle Specs
Airbagit has interesting 2wd lift spindles, but i've decided against spindle lift due to track width increase and wheel backspace limitations. The torsion keys above look just like the cheap ones on Ebay, meaning they are cut from flat bar or plate, which is probably fine if well designed... Water jets do nice work!
But finding OEM for the same price or less would be fantastic!
I'll have to find pics of a key flip , because I can't see how the keys would fit into their seats, unless the seats are flippable in some way as well. That was actually the reason I came to this thread in the 1st place, lol...
Old 05-23-2012, 05:48 PM   #490
swshawaii
Kailua-Oahu, Hawaii
Vehicle Specs
Appears the key flip would only work for lowering, the indexing is opposite for lifting.
Don's idea of using the Ranger keys sounds great if it works. Check the Ranger forums.
http://www.explorerforum.com/forums/...highlight=flip
Old 05-23-2012, 08:18 PM   #491
CDW6212R
Knoxville, TN
CDW6212R's Avatar
98 Mountaineer A4WD
Vehicle Specs
I had one stock key flipped to get my truck as low as I wanted it, one side was far far from the adjustment of the other one. Now with two lowering keys, I have the height where I want it, but with the keys oriented properly for the bolts.
Set the final heights with the truck on the ground, and it has to be rolled some, or driven, to check it. You can lower the truck with it on the ground, but don't raise it that way. The weight of the truck is too much to force the bolt in(up) to lift the truck. Simply jack up the front for the few seconds it takes to crank the bolts up, and then drop it to the ground to check the new height.
__________________
Don
Old 06-09-2012, 11:49 PM   #492
bushgeroge551
Vehicle Specs
I have an 04 LC. It had a pretty drastic stinkbug stance, so I had the torsion bars cranked to level it out a bit (still some slant). I believe that all the mechanic did was crank the bars (and an alignment) and that he did NOT re-index the torsion bars.
My LC currently looks good (right stance) and drives well (on the street and fire roads, I don't drive it on anything harsher). I've also had subsequent alignments with no issues.
My questions are: What exactly does re-indexing the torsion bars do (I know it affects/increases down travel)? Should I get my torsion bars re-indexed and re-cranked (and an alignment) even though I'm not noticing any ride issues? Does re-indexing and cranking change the CV angles less than just cranking (i.e., would I be less likely to need a diff drop if I do both instead of crank only)?
Last, but not least, would you expect re-indexing and re-cranking to reduce some of the misc. noises that I sometimes experience and that seem to be coming from my front suspension (some pops and/or clank-type noises I get from time-to-time)?
Thanks in advance!!
bushgeroge551 is offline   Reply With Quote
Old 06-30-2012, 04:56 PM   #493
Codil7
Bowling Green, KY
2003 Ford Explorer
Vehicle Specs
Where are the torsion bolts on a 2003 explorer? i cant find them anywhere and the diagram looks like its for a much older model. Im probably looking right at them i just dont know it.
Codil7 is offline   Reply With Quote
Old 06-30-2012, 07:35 PM   #494
swshawaii
Kailua-Oahu, Hawaii
Vehicle Specs
Quote:
You don't have torsion bars/bolts unless you have a 2-door Sport.
Ford changed to coil springs starting from 2002 Gen 3. Search link:
http://www.explorerforum.com/forums/...splay.php?f=98
Old 08-27-2012, 04:53 PM   #495
fordfrystak
Indiana
1999 Explorer XLT 4.0 4x4
Vehicle Specs
Went down a horse trail for the first time with my ex..... hit a rock that was hidden in a puddle... and well the rock fought back. Ripped off that nice piece of metal that covers the rear mounting point of the front right torsion bar. Very easy to replace but man did i feel it yank
fordfrystak is offline   Reply With Quote
Old 10-23-2012, 03:06 AM   #496
black98exploder
98 explorer xlt
Vehicle Specs
to lower my front end on my 98 explorer 4 door 4wd can i completely remove the torsion adjuster bolts or do they need to stay in part way? i do plan on lowering so im pretty close to a 30 1/2 inch height all around as the front driver side sits at 33" even and the passenger sits at 33 1/2 and i know the back sags a bit as i have a big system in the back but i want to get everything as close as i can i know ill probably have to do the TT but for now i just want to bring the front down without doing the tt right now
__________________
98 explorer sohc
black98exploder is offline   Reply With Quote
Old 10-25-2012, 10:44 PM   #497
antdemoe6
Southington Ohio
1997 Mercury Mountaineer
Vehicle Specs
If i tighten the bolts does that lower or lift it?
antdemoe6 is offline   Reply With Quote
Old 10-25-2012, 10:45 PM   #498
albi1cnobi1
Elite Mountaineer
South Jersey
albi1cnobi1's Avatar
99 Mountaineer V6 4x4
Vehicle Specs
Tighten = lift, loosen = lower.
__________________
Al
99 Mountaineer 4.0 SOHC.
TT/Warrior Shackles, 2" BL, 32x11.5/15 BFG A/T's, Rancho 5000's, Supplemental HHO Generator(out for cell redesign), Electric Fan Conversion, AVM Manual Lockout Hubs, Dual Battery System, Gibson cat back exhaust. EATC Mod. BW1354 swap, finally done! My 4405 To 1354 Swap Thread Support your own economy, Buy American, all of our jobs depend on it.
albi1cnobi1 is offline   Reply With Quote
Old 10-25-2012, 10:47 PM   #499
antdemoe6
Southington Ohio
Vehicle Specs
if i want to lift it do i loosen or tighten the bolts?
Old 10-25-2012, 10:48 PM   #500
antdemoe6
Southington Ohio
Vehicle Specs
ok thank you
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
