#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > General Explorations!!
Notices
General Explorations!! Closed to new posts. Place new posts in our new model year appropriate forum
engine rev
Thread Tools
Old 04-20-2002, 11:37 AM   #1
abarlow
brunswick, Me
98 Explorer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
engine rev
98' 4.0 L
With the engine at idle it sounds like the engine is reving with no change in rpm indications. It won't do it long enough to take a look under the hood. It never does it on intitial start up, only after driving for a while. It will stop after hitting the gas for a second or two. Any ideas?
abarlow is offline
( Join the Elite Explorers )
Old 04-20-2002, 02:52 PM   #2
Robb
Vehicle Specs
Quoted: 0 Post(s)
Any rev of the engine should show up on the tach. I have heard that O2 sensors could cause the up/ down rev. I also had a Honda once that would do the same thing (usually in hot weather) and after engine heated up. I thought it was sensor somewhere, but found out the throttle cable just needed some lubing. It was fine when cold, but when it heated up, the cable would expand and rub on sleeve.
Robb is offline
Old 04-20-2002, 03:07 PM   #3
Alec
Elite Moderator
Houston, Texas
Alec's Avatar
2008 JK
Vehicle Specs
Quoted: 0 Post(s)
Does it do it with both the A/C off and on? If it doesn't do it with the A/C off (system completely off) then it's the A/C compressor cycling. This is normal.
__________________
Alec "Dr. Candlepower" Rosenbaum
Daily: 2008 JK
Gone: EE "Splat", 2003 VW GTI VR6, 85 Bronco project
Alec is offline
Old 04-20-2002, 03:32 PM   #4
abarlow
brunswick, Me
98 Explorer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
After reading some other posts, it may be the idle air control valve. I'll check on the a/c on and off. Thanks for the info. How hard is it to change the iac valve?
abarlow is offline
Old 04-20-2002, 04:01 PM   #5
Alec
Elite Moderator
Houston, Texas
Alec's Avatar
2008 JK
Vehicle Specs
Quoted: 0 Post(s)
Takes about 10 minutes to change. No biggie at all.
__________________
Daily: 2008 JK
Alec is offline
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
