Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood
Notices
Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories.
High pitched humming sound.
Reply
Thread Tools
Old 06-28-2002, 11:20 AM   #1
psychotic
Olathe, KS
psychotic's Avatar
RIP: '02 V8 Limited 4WD
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Have you ever had one of those tubes (or heard one) thats a toy, and you swing it around real fast and the wind causes a high pitched humming noise?
Well, my ex decides to sometimes, not always, but a lot of the time, hum like this at idle. It can be very loud and annoying. It started right after I put in my K&N FIPK, so i thought maybe that might have something to do with it, but I don't know what. Also my dad thinks it may be a fuel pump going bad, or the alternator straining to recharge the battery because of my system? Any help or ideas?
psychotic is offline   Reply With Quote
( Join the Elite Explorers )
Old 06-28-2002, 11:59 AM   #2
Luv2explorer
Belvidere, Il
92' 4X4 Sport
Vehicle Specs
Quoted: 0 Post(s)
You need to try and place where the noise is coming from. I have the same sound, and I believe that it is my fuel pump.
__________________
Over 185,000 miles, and still kickin! Anyone gotta cure for rust????
Luv2explorer is offline   Reply With Quote
Old 06-28-2002, 12:10 PM   #3
Lifted95X
The Xplorer U Luv to H8
EASTPOINTE, MI
Lifted95X's Avatar
03 4.6 Mounty
Vehicle Specs
Quoted: 0 Post(s)
It is probably the IAC. Do a search.
__________________
03 Mounty and an 05 Evo
Lifted95X is offline   Reply With Quote
Old 06-28-2002, 09:12 PM   #4
RedBeard
North Georgia, USA
'95 XLT
Vehicle Specs
Quoted: 0 Post(s)
If you give it gas and it goes away, its the IAC. Mine was so loud I could hear it out of my tailpipe.
-RB
__________________
1995 XLT 4.0L OHV 4WD 4DR
Magnaflow w/ 2.25" pipe Catback
RedBeard is offline   Reply With Quote
Old 06-28-2002, 09:17 PM   #5
Texplorer
Morgantown, WV
Texplorer's Avatar
96 XLT 4x4 4.0
Vehicle Specs
Quoted: 0 Post(s)
Good thing I saw this post, mine has the same noise and it does go away when I give it gas. The sound only starts after the X has warmed up a while.
__________________
2005 F-150 SuperCrew 4x4 5.4L on 33" Nitto TG's
1996 XLT Lifted on 33's SOLD
1996 Limited Stock SOLD
2008 Jeep Grand Cherokee Rocky Mountain Edition
Texplorer is offline   Reply With Quote
Old 06-29-2002, 09:47 AM   #6
mercury
Ogden, UT
91
Vehicle Specs
Quoted: 0 Post(s)
Mine does the same thing.....What is the IAC?
mercury is offline   Reply With Quote
Old 06-29-2002, 10:14 AM   #7
Lifted95X
EASTPOINTE, MI
Lifted95X's Avatar
03 4.6 Mounty
Vehicle Specs
Quoted: 0 Post(s)
Idle air control.
__________________
Old 06-29-2002, 11:12 AM   #8
RedBeard
North Georgia, USA
'95 XLT
Vehicle Specs
Quoted: 0 Post(s)
Quote:
Here ya go!
-RB
__________________
Old 07-02-2002, 02:04 PM   #9
TPLYNCH
Brewster, NY
1999 XLS
Vehicle Specs
Quoted: 0 Post(s)
Mine does the same thing when idling while warm. I traced it to my air intake (stock). If I open it up while it's running, the hum is deafening! So I figure it's an intake problem, unless the IAC causes a hum that resonates back down intake tube.
__________________
Tom Lynch
'99 XLS
4 wonderful very used (80K miles) but still like new Michelin XC LT4 tires
"Forget world peace. Visualize using your turn signal."
TPLYNCH is offline   Reply With Quote
Old 07-02-2002, 02:31 PM   #10
bigA
Valrico, FL
2005 Limited
Vehicle Specs
Quoted: 0 Post(s)
If the sound is coming from the air intake box, it's the IAC. Usually more common when it's warm out.
bigA is offline   Reply With Quote
Old 07-02-2002, 07:35 PM   #11
Texplorer
Morgantown, WV
Texplorer's Avatar
96 XLT 4x4 4.0
Vehicle Specs
Quoted: 0 Post(s)
Alright, I opened up my hood after the humming started to see where it was coming from and sure enough it was from my air intake. Does it matter that I have a KKM or is it still the IAC.
__________________
Old 07-02-2002, 08:00 PM   #12
Digger196
Winston-Salem, NC
98 Cherokee
Vehicle Specs
Quoted: 0 Post(s)
dude i got the same! so what we concuding it to be? the IAC ?
__________________
2006 F-250 CC
Digger196 is offline   Reply With Quote
Old 07-02-2002, 08:29 PM   #13
RedBeard
North Georgia, USA
'95 XLT
Vehicle Specs
Quoted: 0 Post(s)
When I first had the "moose call", I thought for sure it was my brand new K&N FIPK (which was installed 3 days before the IAC took a dump).
I was certain that my FIPK was the problem because the sound was coming from the filter... I removed my IAC, cleaned it, and it worked fine for a day, then the noise returned. I replaced the IAC and the noise was gone for good.
-RB
__________________
Old 07-02-2002, 10:19 PM   #14
Texplorer
Morgantown, WV
Texplorer's Avatar
96 XLT 4x4 4.0
Vehicle Specs
Quoted: 0 Post(s)
Is the replacement IAC just a simple unbolt the old one and bolt up the new one process?
__________________
Old 07-03-2002, 12:08 PM   #15
Robert
Mesa, AZ
'97 4x4 Sport
Vehicle Specs
Quoted: 0 Post(s)
When you get the "humming" do you get it at all speeds or only when idleing? Mine has definately picked up a hum since I cleaned my engine a couple of months ago. It hums while idleing and any time I put the gas pedal more than 1/4 of the way down. I thought it was from my FIPK since one of the mounting holes has been broken for some time. I figured it was leaking air so I put my stock air-box back on but the humming is still there. It is a bit quieter though, but still noticeable.
I thought that since the IAC only controls the idle, that it would only make the noise at idle. If it can cause the "humming" while driving also, then at least I can be reasonably certain that is where the noise is coming from and I won't worry about it anymore. I was beginning to think that I had a bearing going out somewhere. It only showed up after I sprayed engine cleaner all over my engine and hosed it off.
__________________
4.56 Powertrax No-Slip, SOHC V6, SuperChip, K&N FIPK (#57-2513-1), Borla cat-back (#14748), 2" torsion lift, 3" PA body lift (#853), Monroe Reflex shocks, 285 75R16 BF Goodrich T/A ko, 2WD mod
Earnhardt Ford, Berge Ford, U-Haul
My Explorer
Robert is offline   Reply With Quote
Old 07-03-2002, 12:34 PM   #16
Lifted95X
EASTPOINTE, MI
Lifted95X's Avatar
03 4.6 Mounty
Vehicle Specs
Quoted: 0 Post(s)
Mine hums while applying gas too...but after a decient amount, it cuts off. It's the IAC.
__________________
Old 07-03-2002, 01:18 PM   #17
Texplorer
Morgantown, WV
Texplorer's Avatar
96 XLT 4x4 4.0
Vehicle Specs
Quoted: 0 Post(s)
Good timing, I just stepped in the door. I was just at auto zone asking about the IAC and the guy there told me that I dont have one. He told me to check for carbon build up inside the intake tube.
__________________
Old 07-03-2002, 01:31 PM   #18
RedBeard
North Georgia, USA
'95 XLT
Vehicle Specs
Quoted: 0 Post(s)
Autozone... Gotta love em. Other than their free tool rental, they pretty much blow.
__________________
Old 07-03-2002, 01:46 PM   #19
Robert
Mesa, AZ
'97 4x4 Sport
Vehicle Specs
Quoted: 0 Post(s)
Quote:
Texplorer - you would have stood just as good of chance at getting a correct answer by going to Tot's Unilimited and talking to one of the students. You most definately do have an IAC valve.
__________________
My Explorer
Old 07-03-2002, 03:49 PM   #20
DasFrem
Elite Poseur
Memphis, TN
DasFrem's Avatar
2 '97 sports
Vehicle Specs
Quoted: 1 Post(s)
Hey RedBeard, how long have you had the new IAC, I looked at NAPA and they sell 'em for $120 is this about what you paid? I tried the whole cleaning it out (with EFI cleaning spray) and put it back it and that didn't help. Then I just tried unpluggng the IAC which dropped my idle to about 500 instead of 1100-900. When you unplug it, the noise goes away, but it's idleing real low. Arg, it's been like this in the hot months for the two years I've had my KKM Filter on. And from what I can see, the only people who get this problem are those of us who go with a KKM or K&N FIPK. Any other suggestions out there?
__________________
Matt Fremstad
1997 Explorer Sport 4x2, 3.73LS, 5 speed, lowered 2" (SOLD)
1997 Explorer Sport 4x4 4.56s, 5 speed, Detroit locked rear, 35" MTs, Man T-Case (SOLD)
2006 Subaru Outback
Loads of bicycles
DasFrem is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
