Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > General Explorations!!
Notices
General Explorations!! Closed to new posts. Place new posts in our new model year appropriate forum
How do I take my dash apart?
Thread Tools
Old 06-28-2002, 06:58 PM   #1
VBVA
Go Dukes!
Northern Virginia
VBVA's Avatar
'93 XL
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I need to remove a portion of the dash, most likely left of the steering wheel, so I can mount another switch for more lights. How would I go about removing portions of the dash plates so I can do this?
__________________
- Brian -
The Ex
The Mug
VBVA is offline
( Join the Elite Explorers )
Old 06-28-2002, 08:43 PM   #2
ahhjaws
Moab Edition Explorer
Ft. Collins, CO
ahhjaws's Avatar
1992 Explorer XLT
Vehicle Specs
Quoted: 0 Post(s)
It is kind of hard to try and explain. What you should do is get a Haynes Manual for X's, that has helped me figure out how to take everything apart. It really comes in handy.
__________________
Chris
Four Wheelin: An insane, incontrollable human psychological, pathological problem.
Facebook
Never Forget
"I brake for.....Oh sh!t! No brakes!"
ahhjaws is offline
Old 06-28-2002, 08:48 PM   #3
section525
sextion525
Red Bluff, Ca
section525's Avatar
1975 Ford Bronco 4x4
Vehicle Specs
Quoted: 22 Post(s)
Check this out.. courtesy of BigTigEx
Indiglo Gauge Install Process
__________________
Support the Forum
'13 3.5 Explorer
'75 5.0 Bronco
'04 6.0 Super Duty
section525 is offline
Old 06-28-2002, 10:28 PM   #4
fireftr
strongsville,ohio
'05 Limited 4.6
Vehicle Specs
Quoted: 2 Post(s)
dash removal
The plastic dash face can be removed by GENTLY prying all around the edges with a flat, rigid tool. I use a small pry bar that has a flat end on it. Pry all the way around until loose, then pull away from dash with fingers. I've found its easier to get the panel free by pulling the shifter downward to get it out of the way. Just be careful not to crack the panel. Some electrical connections need to be disconnected before the panel can be completely removed. Good luck. After you've done it once, its alot easier next time.
__________________
eb guy
fireftr is offline
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
