Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > General Explorations!!
Notices
General Explorations!! Closed to new posts. Place new posts in our new model year appropriate forum
Fuel Cap Warning Light
Thread Tools
Old 07-05-2002, 02:41 AM   #1
VOATMJ1
Southwest, Iowa
'00 Sport 4X4
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
US Fuel Cap Warning Light
I have a 2000 XSport 4x4, and on the instrument cluster, there is a warning light that says, "Check Fuel Cap." (Not to be confused with the lettering that tells you which side the fuel cap is on) According to the owners manuel, this light comes on when the fuel cap is not properly on and or missing. (Someting about fuel pressure). I have never seen this light come on and have driven the vehicle (as a test only) with the fuel cap completely off, to see if it would come on..it did not. Does anyone else have this warning light, and does it actually work? The vehicle warranty will be up in about 3000 more miles, and I am trying to get EVERYTHING working that is suppose to work while still under factory warranty. My Ford dealer denied the existence of such a warning light, until I got a flashlight and showed it to him, as well as the owners manuel. He then claimed it takes 3 days of not having the fuel cap on for it to illuminate. At this point I would not trust him to tell me what time it is!! Thanks.
VOATMJ1 is offline
( Join the Elite Explorers )
Old 07-05-2002, 12:33 PM   #2
Robert
Mesa, AZ
'97 4x4 Sport
Vehicle Specs
Quoted: 0 Post(s)
When you first start your Explorer, your PCM will run a series of tests on your charcoal canister. One of the tests it will run is to close your canister vent valve (CVV) and apply a vacuum to your fuel hoses. If it doesn't maintain vacuum for a predetermined amount of time, it will fail the test. If this test fails twice in a row with a minimum of 8 hours between each test, it will set a P0455 code (evaporative emission control system leak detected (gross leak)). Since most of the time this code means that your gas cap is loose or faulty, Ford wisened up and put a "Check Fuel Cap" light instead of using the "Check Engine Light" that my '97 uses. I'm not sure when Ford put the light on the Explorer but I do remember seeing it on a '00 Focus rental car. I would say probably 2000 or 2001 for the Explorer. Anyway, if you leave your cap off for two complete drivecycles with a day in between it should set off your Check Fuel Cap light.
__________________
4.56 Powertrax No-Slip, SOHC V6, SuperChip, K&N FIPK (#57-2513-1), Borla cat-back (#14748), 2" torsion lift, 3" PA body lift (#853), Monroe Reflex shocks, 285 75R16 BF Goodrich T/A ko, 2WD mod
Earnhardt Ford, Berge Ford, U-Haul
My Explorer
Robert is offline
Old 07-06-2002, 12:46 AM   #3
VOATMJ1
Southwest, Iowa
'00 Sport 4X4
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thank-You for indepth and detailed answer. Now I FINALLY understand what this light does. I wonder why my Ford dealer could not explain this like you did? I appreciate you taking the time and explaining this for me!
VOATMJ1 is offline
Old 07-08-2002, 01:17 PM   #4
Robert
Mesa, AZ
'97 4x4 Sport
Vehicle Specs
Quoted: 0 Post(s)
You're welcome. Your dealer can't explain it like this because they have probably 20 different models that they see over a wide range of years. Unfortunately they are to quick to say something as fact when infact they don't really know the answer. Since they are in the position of "authority" on the subject they aren't questioned very often. They do their position no justice when they say something is fact when they aren't really sure. I would feel a lot better about my local dealer if the Service Advisor was up front with the fact that he wasn't really sure than I would be if I found out after the fact that he fed me a line of BS. You know what the most common reply is from a Service Advisor that doesn't know the real answer to a problem? "It is just a characteristic of your particular vehicle, they all do it". Anytime I hear that I know the person saying it doesn't have a clue about what he's talking about.
__________________
My Explorer
Robert is offline
Old 07-20-2002, 01:22 AM   #5
FordSploderXLT
West Des Moines, Iowa
95 XLT and 97 XLT V8
Vehicle Specs
Quoted: 0 Post(s)
US
My 95 X has the same light, never seen it on though. Always wondered what it would take to get it to come on though....
FordSploderXLT is offline
Old 07-22-2002, 08:46 PM   #6
gijoecam
Village Idiot
Trenton, MI
98 ExSport, '00 F-150
Vehicle Specs
Quoted: 10 Post(s)
Quote:
Been there, buddy!
Advisor: "That hammering in the headliner over your head is a functional operating characteristic of your sunroof."
Me: "Really? Ford made 475,000 Explorers last year, and you mean to tell me that EVERY SINGLE ONE WITH A SUNROOF MAKES THAT NOISE?!?!?! I don't THINK so!"
Advisor: "uuuuh... well, we can't seem to find anything wrong, so, uuuuh, you can call Ford's Customer Service Line. I think we have the number around here somewhere..."
Turned out they forgot to install a piece of foam rubber between the inner roof brace and the outer roof panel (just as I suspected and told them the FIRST time it was in!). rote a letter to the service manager, and finally convinced them to drop the headliner and take it for a spin. (This was the 4th time it had been in with that problem, mind you)
I love that line! "functional operating characteristic"
__________________
-98 Explorer Sport, 4.0 SOHC, K&N drop-in, LEMON in progress!
-'00 F-150, mucho mods
"We need to allow Darwinism take it's course and let the idiots weed themselves out of existance." ~ Rick Horwitz
We must believe in free will we have no choice.
~ Isaac Bashevis Singer
I'm not smart, just a resourceful idiot. ~ Me
gijoecam is offline
Old 08-07-2002, 02:48 PM   #7
yob_yeknom
Moderator Emeritus
Glade Hill, Virginia
yob_yeknom's Avatar
'97 XLT & '06 Limited
Vehicle Specs
Quoted: 0 Post(s)
Quote:
Your light is a fuel reset light, not a check fuel cap light. It lights up after a collision if the fuel pump cutoff was triggered so you will know to reset it.
__________________
~ My Mugshot
1997 XLT and 2006 Limited
Try not. Do. Or do not. There is no try. ~ Jedi Master Yoda
yob_yeknom is offline
Old 08-07-2002, 08:11 PM   #8
VOATMJ1
Southwest, Iowa
'00 Sport 4X4
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
That may be the case on your '97 model, but my 2000 model has the words "Check Fuel Cap" which lights up when the fuel cap is not correctly placed according to my owners manuel.
Apparantly after 3-4 cycles of the key on and off while driving, if the fuel cap is not correctly on, this warning light will illuminate. I purposly left my fuel cap completly off, and after the 3 third time that day of starting, the light came on.
__________________
Retired Military
VOATMJ1 is offline
Old 08-08-2002, 12:51 AM   #9
yob_yeknom
Moderator Emeritus
yob_yeknom's Avatar
Vehicle Specs
Quoted: 0 Post(s)
I was referring to a '95, as stated in the quote in my post. And yes, the '95 is the same as my '97.
__________________
~ My Mugshot
Old 08-08-2002, 01:33 PM   #10
VOATMJ1
Southwest, Iowa
'00 Sport 4X4
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Your right. OOPS!!
__________________
Retired Military
VOATMJ1 is offline
Old 08-08-2002, 03:23 PM   #11
yob_yeknom
Moderator Emeritus
yob_yeknom's Avatar
Vehicle Specs
Quoted: 0 Post(s)
__________________
~ My Mugshot
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
