Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood
Notices
Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories.
Exhaust recirculation mod???
Reply
Thread Tools
Old 07-18-2002, 07:19 PM   #1
psychotic
Olathe, KS
psychotic's Avatar
RIP: '02 V8 Limited 4WD
Vehicle Specs
(Original Poster)
I saw this on ebay for about 10 dollars... will this work, or is it something i could do by myself and i'm really just paying for the instructions???
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1844305935
EXHAUST RECIRCULATION MOD!! Free shipping !!!!!!! You are bidding on a kit that reroutes your exhaust gases away from your intake manifold and puts them straight into your exhaust. This is beneficial because hot exhaust in your intake manifold increases the air temp going into your engine, which causes horsepower loss, By routing your exhaust away from you manifold you keep your manifold MUCH cooler and everyone knows the cooler the air going into your engine the More horsepower you make, the same concept is used in nitrous but just on a larger scale. I have seen this modification add up to 20 hp, and drop 3 tenths in the quarter mile. This modification will NOT harm your vehicle in anyway and is emissions legal in every state except California. THIS WILL NOT MAKE YOUR CHECK ENGINE LIGHT COME ON. I only accept paypal . Please Send paypal to Stickerman50@aol.com Thank you for looking at my auction and happy bidding. Betty gives you the horsepower you need.
psychotic is offline   Reply With Quote
Old 07-18-2002, 07:23 PM   #2
psychotic
Olathe, KS
psychotic's Avatar
Vehicle Specs
(Original Poster)
I just found another claim on ebay that says it will add 15 hp, what do you guys think about this one???
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1844306672
YOU ARE BIDDING ON A ELECTRICAL DEVICE TO REPROGRAM YOUR OXYGEN SENSOR TO GET THE "PERFECT MIXTURE OF FUEL AND OXYGEN SO YOUR CAR WILL RUN AT IT'S PEAK LEVEL. HERE IS WHAT IT WILL DO. Every new car, and most cars produced after 1980, have an oxygen sensor. The sensor is part of the emission control system and feeds data to the Engine management computer. The goal of the sensor is to help the engine to run as efficiently as possible and also to produce as few emissions as possible. A gasoline engine burns gasoline in the presence of oxygen .It turns out that there is a particular ratio of air and gasoline that is "perfect", and that ratio is 14.7:1 A stock cars ratio is 16.7:1 This device will make your car have the "perfect" ratio therefore it will maximize and boost the performance of your car. If there is less air than this perfect ratio, then there will be fuel left over after combustion. This is called a rich mixture. Rich mixtures are bad because the unburned fuel creates pollution and it will slow your car down. If there is more air, then there is excess oxygen. This is called a lean mixture. A lean mixture tends to produce more nitrogen oxide pollutants, and in some cases it can cause poor performance and even engine damage. The oxygen sensor is positioned in the exhaust pipe and can detect rich and lean mixtures. You are bidding on a device that plugs in to the wires on your o2 and reprograms it for the perfect mixture. The mechanism in most sensors involves a chemical reaction that generates a voltage. The engine's computer looks at the voltage to determine if the mixture is rich or lean, and adjusts the amount of fuel entering the engine accordingly. The reason why the engine needs the oxygen sensor is because the amount of oxygen that the engine can pull in depends on all sorts of things like the altitude, the temperature of the air, the temperature of the engine, the barometric pressure, the load on the engine, etc. When the oxygen sensor fails, the computer can no longer sense the air/fuel ratio, so it ends up guessing. Your car performs poorly and uses more fuel than it needs to. Shipping and Handling is free! I only accept paypal, Please send all paypal payments to Stickerman50@aol.com. Thank you and have a great day.
Old 07-18-2002, 07:33 PM   #3
mrboyle
I Drive By Brail
Fruita, CO
mrboyle's Avatar
'96 XLT '80 Toy
Vehicle Specs
If you think those are worth buying I have a set of chrome muffler bearings and a pint of blinker fluid I will sell you to go with them.
__________________
Mike Boyle
ASE Certified Master Tech.
'92 XLT(RIP) 1980 Toyota PU
Quote:
Originally Posted by DiffWackDaddy
Some people go looking for God, others get broadsided by them
mrboyle is offline   Reply With Quote
Old 07-18-2002, 07:39 PM   #4
psychotic
Olathe, KS
psychotic's Avatar
Vehicle Specs
(Original Poster)
yeah but will they add 10-20 horse power like the other thing says it will
Old 07-20-2002, 01:54 AM   #5
psychotic
Olathe, KS
psychotic's Avatar
Vehicle Specs
(Original Poster)
anyone else?
Old 07-21-2002, 03:10 PM   #6
ld50
Oh, the money you`ll blow
British Columbia
ld50's Avatar
93 4 dr 4x4 manual XL.
Vehicle Specs
He he, I just saw the exhaust recirc. mod on Ebay, and was going to post it and ask WTF? Notice he says he won`t give you a picture?
I never thoght exhaust was rerouted into your intake. As far as I know it goes strait out the pipe! There is a temp. controlled way to draw hot air from around the exhaust manifold when starting cold, but the idea of exhaust gasses going directly in is wierd. Crankcase gasses yes, but com`on.
LOL, I got this crazy picture in my head of exhaust manifolds hooked directly to intake manifolds. We could save the environment! I gotta get a patent!
I`ll take those chrome muffler bearings tho` if ya still got`em Mrboyle
Is it true you get a gain of .3 hp?
__________________
Jim from BC - My Mugshot
All My Mods And How I did Them
ld50 is offline   Reply With Quote
Old 07-21-2002, 07:07 PM   #7
mrboyle
I Drive By Brail
Fruita, CO
mrboyle's Avatar
'96 XLT '80 Toy
Vehicle Specs
They actually have the potential of .5 hp if installed using a metric cressent wrench!
Exhaust is actually rerouted into the intake, through the EGR (Exhaust Gas Recuirculation) system, but this only occurs above a cretain speed under a constant throttle. It has no effect on the engine performance under acceleration. The thing about the O2 sensor is a load as well, since the vehicle is designed to opperate at the "perfect" 14.7 to 1 ratio, not 16.7 to 1 like the idiot says. Also the only thing the thing he is selling does is bypass the O2 sensor signal and put the car in to open loop, which causes the vehicle to do the oppisite of what the person is claiming, and he is assuming that the people that buy his product don't know that if their O2 sensor fails all they need to do is replace it. He makes it sound like it is part of the exhaust system and can't be serviced.
__________________
Mike Boyle
Old 07-21-2002, 09:00 PM   #8
ld50
British Columbia
ld50's Avatar
Vehicle Specs
I`m out then, all I got is imperial crescents.
I actually remember about that egr valve now, but never gave it more research. Is it just a pollution control thing? And how much is sent back into the engine? I tend to avoid learning about all that pollution stuff.
That fuel ratio IS a standard thing though, that all engines are designed to achieve, so I gotta go with mrboyle on that too.
lets all join ebay and buy up all his stuff and then put off paying until he gets mad that he is being "burned" while trying to make an honest living duping us Explorer fans..
__________________
Old 07-21-2002, 09:08 PM   #9
jonny 5
Seekonk, MA 02771 (home), N. Dartmouth, MA (college)
'98 XLT SOHC
Vehicle Specs
I don't see how burnt up, hot air can be recirculated into the intake AND increase power. It's a bunch of bull!
__________________
Westin Safari Bar, Bugdeflector II, Lund Windjammer, KKM, Edelbrock ISA shocks, custom painted vinyl.
jonny 5 is offline   Reply With Quote
Old 07-22-2002, 09:19 PM   #10
mrboyle
I Drive By Brail
Fruita, CO
mrboyle's Avatar
'96 XLT '80 Toy
Vehicle Specs
Quote:
He is saying that it is creating LOSS of power, and by eliminating it you will GAIN power!
__________________
Mike Boyle
Old 07-23-2002, 12:00 AM   #11
magnetic1
Silver Spring, MD
1997 Eddie Bauer AWD
Vehicle Specs
EGR also occurs on startup... as well as reducing knock. You can think of it like an octane booster...
This guy is full of crap.
__________________
Eric Wong
2001 Magnetic Red Corvette
97 Black Eddie Bauer V8 (MAG1PLR)
Our Autocross Team
magnetic1 is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
