Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > General Explorations!!
Notices
General Explorations!! Closed to new posts. Place new posts in our new model year appropriate forum
Resetting computer with ignition switch
Thread Tools
Old 08-26-2002, 11:47 PM   #1
93greenex
Yakima Valley, WA
'93 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
So I've been trying to diagnose the flashing 4x4 lights on my girlfriend's '96...
The question: is turning the ignition key on and off 5 times the same for resetting the computer as disconnecting the battery for awhile?
When I did that the door locks all made a kerchunk noise at the same time, so I assume something happened.
This did not solve the 4x4 problem, and I am going to get the speed sensors checked, but I am curious about the reset procedure.
93greenex is offline
( Join the Elite Explorers )
Old 08-26-2002, 11:50 PM   #2
rydinhigh
Boost Junky
East Hartford, CT
rydinhigh's Avatar
1999 EB 5.0L V8
Vehicle Specs
Quoted: 0 Post(s)
dude take the - side off the battery. turn the lights on just to make sure theres no more juice left in the system, then wait about 10 min. Put the battery cable back on and call it a day.
__________________
Supercharged 1999 Ford Explorer EB 5.0L v8
Supercharger is for sale check out
http://www.explorerforum.com/forums/showthread.php?p=1039257#post1039257
rydinhigh is offline
Old 08-26-2002, 11:51 PM   #3
Crankcase
Moderator Emeritus
Vancouver B.C, Canada
Crankcase's Avatar
1992 XL Ex-Police
Vehicle Specs
Quoted: 0 Post(s)
CAN
The 4X4 lights flash in a certain pattern, to coincide with the certain fault in the system. There is threads here on what they mean while flashing.
The only surefire way to reset the computer is to disconnect the batttery, and open the doors for a while.
__________________
*Explorer Family*
1992 XL Mine 1992 XL Sisters
1992 XL Dads 1994 XL Moms
Ex-Moderator: Modified Explorations Drivelines
New Member Forum
***Guest star poster....
Crankcase is offline
Old 08-27-2002, 01:20 AM   #4
toad
Blue Point, Ontario, CANADA
toad's Avatar
2007 Sport Trac
Vehicle Specs
Quoted: 0 Post(s)
Ive heard of the key thing, I think some Chevy reset with 3 times on and off, not sure if we can do it or not, but the battery cable works for sure. Good luck
__________________
Todd D.
2007 Sport Trac LTD V8, truxxx lift, general grabber at 265/70/18
2001 Sport Trac, (TT & homemade shackles,gone) 3" body lift, 285 BFG ATs- SOLD
92 XLT, Warrior Shackles & Coil spacers, 2"PA body lift,31"BFG ATs,Milemarker manual hubs.- SOLD
84 MUSTANG CONV. 289 C.I., 08 SUZUKI DR650, Adventure ready!
toad is offline
Old 08-27-2002, 09:00 AM   #5
BradE.
Cincinnati, OH
1997 XLT 4x4
Vehicle Specs
Quoted: 0 Post(s)
Chances are the flashing lights are a bad sensor somewhere. Last time my 97' X did that it was the Tranny range sensor. No biggie, nice easy fix.
You can reset the computer by unhooking the battery, but then the PCM must relearn all the operating specs of the engine. Or, you can use a code reader/scanner to clear the codes. The code reader/scanner method is preferred. If you don't have a code reader go to AutoZone and ask them to pull the codes for you and then after the problem is fixed have them clear them.
Good Luck!
BradE. is offline
Old 08-27-2002, 10:11 AM   #6
daniel cauchon
Terrebonne,Province of Quebec
1995 Explorer Limited
Vehicle Specs
Quoted: 0 Post(s)
Greenex , the kurchung like you say it`s because you entered the programming mode ...in other word to programm a remote control for your alarm system...
__________________
www.webshots.com/user/danielcauchon
daniel cauchon is offline
Old 08-27-2002, 10:42 AM   #7
jjue
sXc Member
Brandon, MS
jjue's Avatar
'07 Nissan Titan CC LE
Vehicle Specs
Quoted: 0 Post(s)
Yeah, I was just about to say that the ignition 5 times thing is for remote programming, not for resetting the computer.
__________________
Jeffrey L. Jue
2007 Nissan Titan LE CC 4x4
Previous vehicles: '05 F-150 XLT Supercrew 4x4, '97 Mountaineer V8, '94 Explorer XLT, and '91 Explorer XLT.
jjue is offline
Old 08-27-2002, 01:57 PM   #8
Robert
Mesa, AZ
'97 4x4 Sport
Vehicle Specs
Quoted: 0 Post(s)
And, you will probably find that your girlfriend's remotes no longer work. If they don't, turn the key on and off 5 times again leaving the key on the 5th time. Press a button on all of her remotes then turn the key off. I'm not certain if merely going into the programming mode will deactivate the remotes, but I do know that once you've reprogrammed one, you need to do them all since they will loose their programming.
__________________
4.56 Powertrax No-Slip, SOHC V6, SuperChip, K&N FIPK (#57-2513-1), Borla cat-back (#14748), 2" torsion lift, 3" PA body lift (#853), Monroe Reflex shocks, 285 75R16 BF Goodrich T/A ko, 2WD mod
Earnhardt Ford, Berge Ford, U-Haul
My Explorer
Robert is offline
Old 08-27-2002, 08:25 PM   #9
93greenex
Yakima Valley, WA
'93 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
You're right about the remote. There's a post somewhere in here that I read that claims that the 5 key turns resets the computer. So much for that.
Thanks for the advice on resetting the remote. It was going to be difficult to explain to her how I "fixed" her Ex.
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
