EF Swag Store 2013 Ford Explorer Forums Elite Membership Chat Room My Posts Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Projects - Hobbies and Additional Topics > Projects - Hobbies - DIY > Ham Radio - CB - Trail Communications
Notices
Ham Radio - CB - Trail Communications I have found that fourwheeling and ham radio go hand in hand. Post any questions or comments about the great hobby of amateur radio here. Of course CB'ers are welcome also. Ray, AE6H and Joe, N1LVN both moderate this forum.
Most desired location for antenna...any pics??
Reply
Thread Tools
Old 08-27-2002, 06:30 AM   #1
Jake's Dad
Brighton, Michigan
'97 XLT, AWD 5.0 302
Vehicle Specs
(Original Poster)
Hey gang:
Im thinking of adding my old CB into the mix, but I am wondering where everyone is mounting antennas these days. I wonder what new technologies are out there to avoid having a 12 foot antenna off the top of my roof and all. That it what turned me off from having my CB installed. Is there any hope?? Also - Im curious if anybody has pics to share of their antenna setup so I can get some ideas.
Thanks everyone-
JD
__________________
My first Explorers: 1996 AWD 5.0. Second, 1997 AWD 5.0. Monroe Sensa Trac Shocks, SenDel rims, BFG All Terrain KO's, KKM, Motorcraft Plugs, Carquest Wires, Flowmaster Series 40 Exhaust, Dark Lapis Blue, Limited Slip Differential rated at # capacity 3200, 113" wheel base, 4 wheel disc brakes w/ ABS, all at 5,580 Lbs. What I drive now: 2013 XLT
www.wholesalesynthetics.com
Jake's Dad is offline   Reply With Quote
Old 08-27-2002, 09:20 AM   #2
Fischer
Denver, Colorado
Fischer's Avatar
95 Explorer XLT 4x4
Vehicle Specs
A 1/4 Wave 3 foot antenna should be fine. You can mount it anywhere you would like but they do need a "platform" to bounce the waves off of. So with that in mind you will get the best transmission in both clairity and distance if you mount it on the center of the roof.
They say if you are going to mount it on the side to do it on the drivers side rear. This prevents too much interfereance from roadside trees and buildings.
Also the amount of cable does NOT matter. There are mixed bags on this but with the quality of todays coax it really won't affect the quality of x-mit if you have to spool a bit of extra cable. 20" seems to work pretty well for the Ex.
You will also need a SWR meeter. This will tell you if your antenna is too long or short, as well as how much distortion you have while transmitting.
Good Luck..
__________________
"Don't Piss Down My Back and Tell Me It's Rainin'." The Outlaw Josey Wales
Fischer is offline   Reply With Quote
Old 08-30-2002, 05:26 AM   #3
Sandy
Boston Area
2003 Ranger Edge
Vehicle Specs
Talking
The best location for an antenna is the middle of the vehicle as high as possible.
Most CB antennas are electrically setup for 1/2 wave but are not 12 feet tall, maybe 18 feet, not really, most CB antenna are around the three feet level and work well in most applications. You can get almost any height you want. If you want an 18 or 21 foot antenna, someone will make it.
Don't go overboard unless you need to. A small CB/antenna in most cases works just as well as the larger ones and take up less space.
My past applications seem to always go to a roof mounted three foot Wilson magnet antenna. They work well and are easily removable.
Good Luck on your choises,
__________________
SandyB,
N1MAU/W1IO
NnF000@gmail.com
Do It Right The First Time !
Sandy is offline   Reply With Quote
Old 08-30-2002, 10:22 PM   #4
becker69
Centennial, CO
01 Sport Trac
Vehicle Specs
Mark another that is content w/ the mag Wilson
I just installed the 'Lil Wil' magnetic Wilson antenna and base, and I am really impressed with it. The magnet is solid and sturdy, and the antenna and cable seem first rate. At a cost of $32 plus a 90 degree fitting for the cable connection into the CB, it looks good and recieves well. Good luck with your choice. Oh and it doesn't say it anywhere but the RG cable that comes with the lil wil is aprox 20 ft long.
__________________
Douglas.
TT/Warriors, 4.10's w/ LS, 32" Grabber AT2---stuff and other things---and--SLIDERS- -Armor to help the LONG wheelbase-
POW/MIA YOU ARE NOT FORGOTTEN
becker69 is offline   Reply With Quote
Old 08-30-2002, 10:25 PM   #5
Jason_25
ECX Member
New Bern, NC
Jason_25's Avatar
'95 Explorer "Expedition"
Vehicle Specs
Becker, did you have to order it, or did you find it locally somewhere?
__________________
1995 Explorer "Expedition" 4.0 4x4
1987 Bronco II XLT 2.9 4x4
1988 Bronco II XLT 2.9 4x2
1997 Explorer XLT 5.0 4x2
My Truck
Jason_25 is offline   Reply With Quote
Old 08-31-2002, 12:36 AM   #6
becker69
Centennial, CO
01 Sport Trac
Vehicle Specs
Jason, By shear luck, the last place I checked (a local truck stop) actually had it in stock. I checked several "Flying J" truck stops and called 4 or 5 'communications' shops and none of them had CB antennas or magmounts besides Radio Shack. I was set to order on-line from;
http://www.wearecb.com/wilson.htm#Little%20Wil
or,
http://www.palcoelectronics.com/pe110.htm
Both sites have it for about $24. But both of those you have to phone in an order or fill out a form and MAIL it in. Shipping would have been about $8.50 so I pretty much broke even.
The links above are to the Antenna or Wilson specific part of those specific sites. Hope this helps.
__________________
Douglas.
Old 08-31-2002, 09:44 AM   #7
Soundguy01tx
Katy, TX
Soundguy01tx's Avatar
1991 XLT
Vehicle Specs
This is where I mounted my cb in my explorer, and where I mounted the antenna... Hope it helps.
--bryan
__________________
--Bryan
Katy, Tx
My Mug
My '03 Sport - SOLD
My '91 Explorer
Soundguy01tx is offline   Reply With Quote
Old 08-31-2002, 04:28 PM   #8
Crankcase
Moderator Emeritus
Vancouver B.C, Canada
Crankcase's Avatar
1992 XL Ex-Police
Vehicle Specs
CAN
Every police Explorer I have ever seen has it mounted on the drivers side fender, including mine. It seems to work fine for them...
__________________
*Explorer Family*
1992 XL Mine 1992 XL Sisters
1992 XL Dads 1994 XL Moms
Ex-Moderator: Modified Explorations Drivelines
New Member Forum
***Guest star poster....
Crankcase is offline   Reply With Quote
Old 09-02-2002, 12:27 AM   #9
Ray Hutchinson
Moderator Emeritus
Dana Point, CA
Ray Hutchinson's Avatar
'93 XLT
Vehicle Specs
Cowl Mount CB Antenna
Crankcase, and all:
Yes, a cowl mount location will work for a CB antenna, but make sure you have a really good ground strap electrically connecting the hood to the car chassis. Othrewise you run the risk of picking up ignition noise on the CB. The police radios are most likely on VHF or UHF frequencies and definitely FM mode. CB is on HF (much lower) frequencies, and is AM or SSB mode. This makes CB much more prone to picking up static that will mask the desirable signals, than the PD radios.
This is why we advocate the roof top, center. It puts the max. distance, and a well grounded panel (the roof) that helps shield the antenna from in vehicle static sources such as the fuel pump or ignition system. Radio performance wise, the rooftop is simply the best location. Any other location is really a compromise.
__________________
Ray, & Debby Hutchinson, AE6H
AKA: Pack Rat
'93 White XLT, Modified, lotsa radios
'06 F250 SD Dsl (Big Red 'Plorer Puller)
'01 Lincoln LS-V8
'66 'Stang CA Sprint
Ray Hutchinson is offline   Reply With Quote
Old 10-10-2002, 12:07 AM   #10
Big Bear Bob
Big Bear area of Southern Ca. near "Rim of the World drive", & Sugarloaf Mountain
98 XLT /01 Dodge 1500 4X4
Vehicle Specs
So do most people drill a hole or use mag mounts when mounting on top. Right now I have a 4' firestick II mounted on the top using a firestick mag mount. It works pretty well, but I have a 2' that I can't get the SWR anywhere under 3.5. The guys at the "Firestick online help" suggested drilling a hole, and permanently mount the antenna. That's why I wanted to know if anyone had drilled a hole to mount their antenna.
__________________
From "The Rim of the World Drive"
Keep the right side up.
98 XLT 4.0 SOHC 5 speed Automatic. With a 2" TT and Warrior shackle Lift, Limited slip rear differential with 31X10.50 15 BFG AT/KO's. With a Cobra 148 GTL C.B. and a 2 Meter ham radio.
My off road site
http://home.earthlink.net/~xlt4x4/Go..._mountain.html
Big Bear Bob is offline   Reply With Quote
Old 10-10-2002, 12:49 AM   #11
coolchris
Vehicle Specs
jsut get a 2 ft firestik and put it on the roof. thats what i did, i still need to take pics though.
coolchris is offline   Reply With Quote
Old 10-12-2002, 03:01 PM   #12
Big Bear Bob
Vehicle Specs
Is it best to place it dead center on the roof, somewhere inside the roof rack area, or in front of the roof rack area? and will it effect the SWR?
Thanks for your response ahead of time
Bob
__________________
My off road site
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
