| Explorer - Ranger Shocks, Suspensions, Lift Kits Ford Explorer and Ranger chassis related posts. Get help choosing the right shock absorber and aftermarket suspension for your Explorer or Ranger based vehicle. |
Thread Tools |
#1 |
Wannabe Elite Explorer
Thomasville, NC
96 Limited
Air Ride Control on a Limited
My 96 Limited has the Air ride control system. These shocks are only available from Ford. Has anyone sucessfully replaced these shocks with standard type shocks? Must springs be replaced? What does it do to the computer? What do you do with the control wires that go into the shocks?
#2 |
Corinth,Maine
92XLT/96 limited
I take it you don't care for the oem air unit. What in particular don't you like?
#3 |
Elite Moderator
Houston, Texas
2008 JK
I think you can just turn off the system (there should be a switch in the jack compartment) and replace the shocks with standard ones.
__________________ Alec "Dr. Candlepower" Rosenbaum Daily: 2008 JK Gone: EE "Splat", 2003 VW GTI VR6, 85 Bronco project |
#4 |
Houston, TX (home) Ripon, WI (school)
5.0 AWD 97 Limited
just make sure you dont drive with it turned off, or else you are in for a WORLD of trouble.. if you do decide to take them off, id take the air shocks off your hands
__________________ 97 5.0 Black Limited w/ Manik Grille Guard, 4 ProComp 55w Clear Corners, SilverStars, 35/20/20 Tint Thule 4 Snowboard Rack Premier DEH-860MP/CDT Components Front-Audiobahn 600Q Components Rear/Pair Infinity Kappa Perfect Subs/Memphis 440W Amp-components/Audiobahn 600 Class D sub Amp |
#5 |
Thomasville, NC
96 Limited
I want to replace them because they are worn out with 95,000 miles on them. To completely replace all 4 shocks is in the neighborhood of $1000.oo. I could buy a great set of high performance shocks and a set of tires for that. I am hoping to find someone who has done this before I screw something up.
Yes the automatic leveling works OK but the other features are not especially noticable to me. |
#6 |
5.0 AWD 97 Limited
well, im considering this too, ill keep an eye on this thread, tell me if you do anything, i know its been done before
#7 |
East Greenwich, RI
2002 Explorer XLT
I would also like some info on this. I just bought a 97 limited with the air ride and I think the shocks might need to be replaced soon. Any help would be appreciated.
Thanks, Ev |
#8 |
Vickery, Ohio
1998 Eddie Bauer
Limited air ride system
JJ,
My wife's truck is a 95 limited with air ride. At around 80,000 miles, BOTH of the stock rear air shocks froze up. I got sticker shock from the Ford price on these shocks so I went to Advanced Auto Parts (any auto store can get them) and bought a pair of standard air shocks for the rear. I put them in, ran the air lines to the air nozzle which I mounted on the bottom of the rear bumper and turned off the air ride switch. Unfortunately this disables the front stock air shocks by turning off the pump (due to turning off the air ride switch). I said the heck with it and pulled the front air shocks and replaced them with stock shocks. I had to crank up the torsion bars a little for ride height (since the stock air shocks also provide lift) and drove like that. You HAVE to have air shocks on the rear of the Limited to provide lift because the Limited does not have as many leafs in the rear leaf spring pack as a regular Explorer. The stock front shocks I put in were a little shorter than the factory air shocks so I fabbed in a spacer under the front aftermarket shocks. Drives just fine now. The information computer in the center console of the Limited says "Air ride switch off", but it beats having it say "Check air ride" all the time with a leaking factory air ride system. As for the factory electrical connectors on the factory air shocks, after I unhooked them I zip tied them (and the factory air lines) to the frame. Having the electrical connectors unhooked won't affect the computer as long as the air ride switch is left in the off position. If you turn on the air ride switch, it will say "check air ride" I was unable to find anyplace that makes air shocks which will fit the front of the limited. If you hear of anyplace let me know. I am not suggesting you do what I did, only if you want to. I just wanted to let you know I had the same problem and this is what I decided to do. Let me know how it turns out for you and good luck! __________________ Brian "Swamprat" Ward Vickery, Ohio 1998 Eddie Bauer Explorer 4x4 4.0L SOHC 1995 Limited 4X4 4.0L "And I, I took the road less traveled. And that has made all the difference!" |
#9 |
Thomasville, NC
96 Limited
Brian, That is the information I have been looking for. I assume you are pleased with the results of your modification and that the ride is improved with the new standard type shocks. I am even thinking about putting in high performance shocks as a replacement. My biggest concern is or was with the springs and the computer. Your comments have helped me decide not to spend the big bucks to replace the factory shocks. Now if I could only figure out how to turn off the "Air Ride Switch Off" message...
#10 |
Vickery, Ohio
1998 Eddie Bauer
I plan to hook up my wife's Limited to the scan tool where I work next week sometime. If I find anything out I will let you know. It would be nice if there is a way to take out that message. Keep me posted on your progress.
| Thread Tools | |
