Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood
Notices
Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories.
Delayed hard shift
Reply
Thread Tools
Old 12-07-2002, 11:30 PM   #1
m-mjones
Billings, MT
'93 Eddie Bauer
Vehicle Specs
(Original Poster)
Unhappy Delayed hard shift
I have a 93 4x4 EB , and the trany was rebuilt about 2 weeks ago. I have since moved it across the country on a trailer, got it of the trailer and now it doesn't want to shift out of first until about 3500 rpm and is late on shifting out of second also. Along with this there has started a little clicking like sound that gets going only when the rpms get high. It does all of this when cold or hot. I have found that if I manually put it in first and shift it out it will do fine, but lags on shifting out of second and still has that little clicking sound. It also has started shifting very hard into reverse. Any ideas?
MJ
m-mjones is offline   Reply With Quote
Old 12-08-2002, 05:57 PM   #2
Opera House
Cincinnati, OH
97 Explorer XLT
Vehicle Specs
Check to see
if the vacuum line is connected all the way from the engine to the vacuum modulator on the side of the transmission. A leak would cause a late shift in 1 & 2. If second works, the only other compnent is the reverse band and servo piston and you say this was rebuilt. Is a hard shift high rpm then engagement or just a big clunk?
__________________
Rule #7: Believing and seeing are often both wrong. (FOW)
02, 97, 92 Explorer XLT 4X4 4.0L
Opera House is offline   Reply With Quote
Old 12-09-2002, 09:49 AM   #3
m-mjones
Billings, MT
'93 Eddie Bauer
Vehicle Specs
(Original Poster)
Thanks for the reply Opera House,
It does engage after it shifts and drives ok, (still has that little clicking sound though). When I make it shift manually it doesn't shift hard, just normally. I have also noticed that if I let it shift by itself it usually shifts out of first at 4000rpm and then will shift out of second normally. When I manually shift it out of first, then it lags shifting out of second, long delay. Also when I put my foot on the brake and put it in reverse, it almost slams it in reverse, (very hard).
Thanks again for you reply,
Mark
Old 12-09-2002, 10:25 AM   #4
DarkFox1
Augusta Georgia
'97 Mountaineer
Vehicle Specs
hrmm, I'd be interested in knowing what this is.. sounds kinda familiar.. not exactly.. but similar.
__________________
the 1st mountaineer owner on the forum (that I know of)
http://members.sounddomain.com/darkfox1 for my current pictures
DarkFox1 is offline   Reply With Quote
Old 12-11-2002, 09:37 AM   #5
m-mjones
Billings, MT
'93 Eddie Bauer
Vehicle Specs
(Original Poster)
Smile
Well the vacum hose had come lose. I put a new hose on and it is running great! The transmission place that rebuilt it didn't put a new hose on it and the old one had been on so long that it would slide off with ease. Thanks for your help Opera House! And a note to any one replaceing the vacum hose: It is located on the pasenger side of the trany and make sure you let your exhaust cool down, as you can't hardly get to it without touching the exhaust. Mine is a 93 and I am told that newer models don't have this vacume, but it is electronic.
MJ
Old 04-10-2010, 05:33 PM   #6
LesBoognish
Spokane area, WA
93 XL
Vehicle Specs
Nice
I just googled this problem an found this. It sounds like exactly what mines doing so Im gonna check it out. Thanks
LesBoognish is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
