#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > General Explorations!!
Notices
General Explorations!! Closed to new posts. Place new posts in our new model year appropriate forum
Transmission fluid leaking between motor and trans
Thread Tools
Old 12-16-2002, 05:20 PM   #1
giant32oz
sikeston,missouri
91 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I had just came from Walmart this past summer when my transmission wasnt shifting at all. I stopped and checked the fluid and it was almost dry. So i made an emergency stop at autozone and I ended up dumping 3 quarts of trans fluid in and it all spilled out through the gap between the engine and the transmission, I mean it was just gushing out like a water hose. I took it to the shop and the guy said that Fords just to that when hot and didnt do anything but add fluid! it ran fine with only a slight leak afterwards and it hasnt done that since. I just took it to a local tranny shop to get it inspected and they said it was some kind of modulator that needs to be replaced, and a sender or sensor, I couldnt really understand. They said it would be around $200 to fix. Has anyone else experienced this? How can transmission fluid running out of the bottom of my truck be normal?!
__________________
Dueyrock
'91 XLT
hypertech, flowmaster,kkm
giant32oz is offline
( Join the Elite Explorers )
Old 12-16-2002, 06:19 PM   #2
Jason_25
ECX Member
New Bern, NC
Jason_25's Avatar
'95 Explorer "Expedition"
Vehicle Specs
Quoted: 0 Post(s)
Re: Transmission fluid leaking between motor and trans
Quote:
Sorry I can't help with your question, but you should never go back to that shop again. I have never heard such a stupid, generalized diagnosis in all my life.
__________________
1995 Explorer "Expedition" 4.0 4x4
1987 Bronco II XLT 2.9 4x4
1988 Bronco II XLT 2.9 4x2
1997 Explorer XLT 5.0 4x2
My Truck
Jason_25 is offline
Old 12-17-2002, 08:29 AM   #3
Opera House
Cincinnati, OH
97 Explorer XLT
Vehicle Specs
Quoted: 1 Post(s)
So why is it getting hot?
The only likely seal at the front of the transmision is the pump seal between the torque converter and the transmission. It is true on some occasions they will reseal and vacuum modulators do leak internally. Have you noticed your oil level going up or you haven't had to add any recently? I suggest that you pull off the vacuum hose that looks like it goes to the transmission and check for the presence of fluid. This vacuum tree is on the drivers side of the manifold close to the firewall. The vacuum modulator is about $12 and some have posted here that it is easiest to get to from a plate under the carpet. Do a search. Believe you have some leak that caused the level to drop prior to the front seal leak. Low fluid pressure probaly caused excess slipping and overheating. Has the filter ever been changed? This might be a good time to do it and get more of that burnt fluid out. If the seal finally fails, the transmission will have to come out.
__________________
Rule #7: Believing and seeing are often both wrong. (FOW)
02, 97, 92 Explorer XLT 4X4 4.0L
Opera House is offline
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
