#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > General Explorations!!
Notices
General Explorations!! Closed to new posts. Place new posts in our new model year appropriate forum
heater doesn't always blow hot air
Thread Tools
Old 12-22-2002, 02:49 PM   #1
dondiesel444
Upstate New York
2005 4.0L 4x4 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Unhappy heater doesn't always blow hot air
OK here's a new problem for me to try and fix on the wife's X. At first I thought it was her imagination, but I have experienced it. The heater doesn't always blow hot air. Sometimes she can drive to work, about 20 miles, leave it on full blast, and it won't get hot, a little warm thats all. But sometimes it will blow hot like it should and burn my hand. I have checked the anti-freeze, the resivior tank is full. I don't see any leaks, the only thing I can think of is maybe there is a restriction somwhere?? Any ideas of what I should check, is this a common X problem, hopefully with an easy fix?? Thanks in advance guys.
__________________
2005 Ford Explorer 4.0L 4x4
2001 F-250 4x4 Powerstroke Diesel
dondiesel444 is offline
( Join the Elite Explorers )
Old 12-22-2002, 02:54 PM   #2
Robb
Vehicle Specs
Quoted: 0 Post(s)
Sounds to me like your heater control valve may be sticking sometimes. It is the valve that contols how much water flows through your heater core.
Where exactly it is or how to locate it exactly on an X, I am unsure of. Never had to look at one. I am sure someone else here can easily tell you.
Robb
Robb is offline
Old 12-22-2002, 05:53 PM   #3
VOATMJ1
Southwest, Iowa
'00 Sport 4X4
Vehicle Specs
Quoted: 0 Post(s)
Your thermostat could be malfunctioning as well. Check the temp gage the next time it blows luke warm and then check it when it is burning your hand. If it reads the same temp each time, then you can rule out the stat.
__________________
Retired Military
VOATMJ1 is offline
Old 12-22-2002, 06:07 PM   #4
dondiesel444
Upstate New York
2005 4.0L 4x4 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
thanks guys, I will keep an eye on the thermostat, we are going out tonight so I will check it then.
can anyone else tell me how to check my heater control valve??
Old 12-22-2002, 06:38 PM   #5
Opera House
Cincinnati, OH
97 Explorer XLT
Vehicle Specs
Quoted: 1 Post(s)
Maybe blend door
Mine acted funny for about six months. I thought I was imagining things too. I have strong doubts about those other possible problems. Search blend door. I posted "Blend door, so you're cold, cheap and lazy." Cutting a hole is the only way to know if you have the problem. Mine still moves sometimes on its own power even though it is cracked at the actuator.
__________________
Rule #7: Believing and seeing are often both wrong. (FOW)
02, 97, 92 Explorer XLT 4X4 4.0L
Opera House is offline
Old 12-22-2002, 07:09 PM   #6
Ky-Judge
Belfry, KY
'94 Explorer EB
Vehicle Specs
Quoted: 0 Post(s)
My '94 EB has a water control valve that is malfunctioning. It is in the line where the heater lines go thru rhe firewall and it has a vacuum line attached to it, what i did was unhook the vacuum line and plug it off in the winter and in the spring i hook it back up so that no hot water flows into the heater core. Try this and see if it works for you before buying a new water control valve.
__________________
Out of the land of the Hatfields and McCoys
Ky-Judge is offline
Old 12-23-2002, 04:02 PM   #7
RTStork
Grand Bay, AL
99 Explorer XLT 5.0L 2WD
Vehicle Specs
Quoted: 0 Post(s)
Are you losing any coolant? A bad heater core can cause your "no heat" problem. A bad head gasket can also.
__________________
Pics of my Explorer
Pics of my other vehicles
99 Explorer 5.0
K&N, Cut Air-Box, Flowmaster 40 Series Dual Exhaust, Eagle 201 rims
RTStork is offline
Old 12-23-2002, 04:11 PM   #8
dondiesel444
Upstate New York
2005 4.0L 4x4 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I think I fixed THIS problem, I hope. I took of the vaccum line to heater control valve, then pushed it on, it was loose. Either that or the valve is sticking. The heat worked good all day I had the X, my wife took my truck to work so I could wrok on the mysterious self-unlocking door problem. I am not loosing coolant, I think it was a slight vaccum leak or the valve is sticking a bit. Thanks for the help guys!!
__________________
Old 12-23-2002, 04:19 PM   #9
daniel cauchon
Terrebonne,Province of Quebec
1995 Explorer Limited
Vehicle Specs
Quoted: 0 Post(s)
you might as well change the heater control valve cause they are not very good ! all plastic and leak is the favourite passtime !! it takes 10 minutes to do and very easy and cheap too...over here in Canada it`s 40$ . I just change mine and it`s great since then.
daniel cauchon is offline
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
