| Explorer4x4 | Sportrucks | EF Arcade | Forums | Elite Membership | Product Reviews | Explorer Photo Gallery |
| Ford Explorer - Ranger Tires & Wheels Want to know what size tire or wheel combo will work with your Ford Explorer or Ranger based vehicle? Interested in Beadlocks or Dubs? Learn all about them here. |
Thread Tools |
#1 |
Elite Dakota
Colorado Springs, CO
Lift and tire size info for explorers
Lifts and max tire and wheel sizes for explorers
This is a quick reference guide I have put together based on information gathered from the Explorer Forum. Remember this is just a guide. You may have to do some fender trimming to fit these tires on your explorer. Others things can change what size tire you can run on your explorer. Like fiberglass fenders, rim width and rim backspacing.. I figured this would help some of you that were pondering what size lift to run what size tires.If anyone would like to add something go ahead and post it and I will add it to my list. If any of the moderators could make this a sticky that would be great. Hope this helps. 91-94 explorers. No lift- 31x10.50x15 on 15x8 inch or stock (15x7) rims 1-2 inch suspension lift- 31x10.50x15 - 32x11.50x15 on 15x8 rims/ may require some extensive fender trimming 2-3 inch suspension lift- 32x11.50x15 on 15x8 rims 3-4 inch suspension lift- 32x11.50x15 - 33x12.50x15 on 15x8 rims/ may require fender trimming 4-6 inch suspension lift- 33x12.50x15 - 35x12.50x15 on 15x8 rims/ may require fender trimming 2 inch body lift- 32x11.50x15 on 15x8 rims/ may require fender trimming 3 inch body lift- 33x12.50x15 on 15x8 rims/ may require fender trimming 2 inch body lift and 1-2 inch suspension lift- 32x11.50x15 - 33x12.50x15 on 15x8 rim/ may require fender trimming 2 inch body lift and 2-3 inch suspension lift- 33x12.50x15 on 15x8 inch rim 2 inch body lift and 4-6 inch suspension lift – 35x12.50x15 – 36x12.50x15 on 15x 8 rim/ may require fender trimming 3 inch body lift and 1-2 inch suspension lift – 32x11.50x15 – 33x12.50x15 on 15x8 rim/ may require fender trimming 3 inch body lift and 2-3 inch Suspension Lift – 33x12.50x15 – 35x12.50x15 on 15x8 rim 3 inch body lift and 4-6 inch Suspension lift – 35x12.50x15 – 36x12.50x15 on 15x8 inch rim 95-2001 (including 2dr 95 - present) No lift- 31x10.50x15 on 15x8 rim or stock (15x7) rim 1-2 inch suspension lift - 32x11.50x15 on 15x8 rim/ may require some extensive fender trimming 4 inch suspension – 33x12.50x15 on 15x8 rim 2 inch body lift – 32x11.50x15 on 15x8 rim 3 inch body lift – 33x12.50x15 on 15x8 rim/ may require fender trimming 2 inch body lift and 1-2 inch suspension lift – 32x11.50x15 – 33x12.50x15 on 15x8 rim/ may require fender trimming 2 inch body lift and 4 inch suspension lift - 33x12.50x15 – 35x12.50x15 on 15x8 rim/ may require fender trimming 3 inch body lift and 1-2 inch suspension lift – 33x12.50x15 on 15x8 rim/ may require fender trimming 3 inch body lift and 4 inch suspension lift – 33x12.50x15 – 35.12.50x15 on 15x8 rim/ may require fender trimming. You may be able to run 33x10.50x15s inplace of 32x11.50x15s 2002-2005 Ford Explorers Click here for lift option #1 Click here for lift option #2 No lift - 32x10.50 or equivelent in Metric Measurements on Stock Wheels (265/75/R16 or 265/70/R17) - no modification needed! Tire Size Calculator For An Updated Chart Please Visit Here: Chart Only Last edited by FROADER; 05-19-2009 at 09:30 PM. |
| Sponsored Links (Less Ads) |
#2 |
ECX Member Winston-Salem, NC
98 Cherokee
great chart!
__________________ 2006 F-250 CC |
#3 |
Elite Dakota
Thanks
#4 |
Mod Emeritus
Houston, Texas
2008 JK
I am gonna sticky it in this forum.
Some of the estimates are a little optimistic. Like most people need more than a little trimming to fit 32s with just a TT/War or spacer/War 1.5" suspension lift. Also, the chart doesn't list 33x10.50 tires that I can see. You can usually fit 33x10.50s if you can fit 32x11.50s. But great none-the-less! __________________ Alec "Dr. Candlepower" Rosenbaum Daily: 2008 JK Gone: EE "Splat", 2003 VW GTI VR6, 85 Bronco project |
#5 |
Elite Dakota
Thanks Alec for the info. I updated the list. Anyone else have anything I should change or add? I know it aint perfect but I thoughtI would try and help out and keep some of the recuring posts down.
#6 |
Wannabe Elite Explorer
malmoe, southern sweden
96 Explorer
sweeeeeeet!
__________________ tt & home made shackles 3"BL and 31"s on black steelies best mod - removed pinstripe! |
#7 |
Moderator
Elite Explorer Chat Op Vancouver B.C, Canada
1992 XL Ex-Police
That's a good reference....now the test will be if newbies read it first...
__________________ *Explorer Family* 1992 XL Mine 1992 XL Sisters 1992 XL Dads 1994 XL Moms Ex-Moderator: Modified Explorations Drivelines New Member Forum ***Guest star poster.... |
#8 |
Elite Ranger
Nor*Cal
98 XLT Supercab 4x2
its a sticky...so hopefully... but i doubt it... as long as we refer them to this post...
#9 |
Elite Dakota
We can all hope. I made it to try and keep some of the recuring posts down. So hopefully it will help
#10 |
Charleston, SC
Good Move. I had been thinking about doing the same, but you beat me to it. This should come in quite handy.
__________________ 1994 Explorer Sport, Black on Grey, 15"x8" Series 97 Black RockCrawlers, 31"x10.5" BFG AT/KO's, 2" Lift Springs w/ Warrior 153's |
#11 |
Wyomissing, PA
'95 XLT
I am getting ready to buy new tires and I definitely am going bigger. Are all 95 XLT's equipped with 8" wide rims? And just to clarify, I can put a 11.5" wide tire on an 8" wide rim? I thought I read somewhere before that 10.5" is the widest you should go on an 8"wide rim.
Also, when you say fender trimming, are we talking the outer metal of the fender or the indide portion of the fender? Thanks all!! __________________ Dave's Truck My Truck Enjoying the Beach!! Explorers don't kill people...people kill Explorers!!! Can't sleep....clowns will eat me!! |
#12 |
Mod Emeritus
Houston, Texas
2008 JK
Your stock rims are probably 15x7 with 4.5" of backspacing. 32x11.50s will work, larger and I'd go with wider rims.
Trimming can include just inner plastic/metal, or outer metal. Depends on how much you need to do! __________________ Alec "Dr. Candlepower" Rosenbaum Daily: 2008 JK Gone: EE "Splat", 2003 VW GTI VR6, 85 Bronco project |
#13 |
ECX Member Chappaqua, NY
'97 XLT 4X4 SOHC
I'm doing a 2" suspension lift (TT with add-a-leafs and shackles). I'm looking into BFG 32x11.5x15 tires. How much trimming will be nessecary? What, exactly will need to be trimmed? I assume it's not too hard to do??
__________________ 2" rearched leaf springs, 2" tt, 2" body lift, 32x11.50r15 AT tires, Rancho RS5000s, KKM, Gibson exhaust, Mobil 1. ...skid plate in the works Shep's '97 XLT 4x4 |
#14 |
Mod Emeritus
Houston, Texas
2008 JK
Depends on the individual truck. Most people trying to fit 32s with only 2" of lift have to do a considerable amount of trimming. The rear shouldn't need any, but the front....
Let's see, the inner fender liner, the rear corner of the front fender, the front bumper, and you still might hit the top of the fender upon compression. Or....they could fit easily. It all depends on the truck! My suggestion is to find someone with 31 or 32s and testfit them after doing the lift, then decide. __________________ Alec "Dr. Candlepower" Rosenbaum Daily: 2008 JK Gone: EE "Splat", 2003 VW GTI VR6, 85 Bronco project |
#15 |
'97 XLT 4X4 SOHC
As far as 32s are concerned I like the 32x11.5x15 BF Goodrich All Terrain TA/KO. I haven't looked into 31s, what tires do you recomend comperable to the BFG's?
#16 |
Mod Emeritus
Houston, Texas
2008 JK
Procomp ATs or XTs are good.
#17 |
Chesapeake, VA
'00 Sport
What about a 31/12.50X15? Anyone know what you would need to fit them?
#18 |
Working
Chandler, AZ
'93 XLT
Wow so i can fit 35's on a 6in lift?? Without trimming?
__________________ Matt KKM Intake, Ravin Muffler, Silverstar Lights,Apten Dual Chip - BROKEN, Panasonic 3600 HU, Herculined Rockers, 5.5" SuperRunner SuperLift, SOA Rear , 33" Xterrians, and Black Rock Crawlers Broken Arrow and Sodier's Pass 4x4 Pics |
#19 |
Elite Dakota
more then likely you will need to trim your fenders a bit
| Tags |
| largest tires, lift size, maximum tire size, tire size |
| Thread Tools | |
