Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Offroad Tech Forums > Offroad Explorer - Ranger Projects
Notices
Offroad Explorer - Ranger Projects Big projects... Lifts, Swaps, etc... IMPORTANT As the subject use your name, or the name of your truck, and the name of the project. Such as Superlift 5.5" installation, Dana 44 conversion, etc.
Frustrated w/ D44...
Reply
Thread Tools
Old 02-08-2003, 10:14 AM   #1
FMExplorer
the original tramp
Fort Myers, FL
FMExplorer's Avatar
'99 Explorer EB
Vehicle Specs
(Original Poster)
Ok - I am really frustrated right now...
Bought rebuild kit from Randy's (along with gears) and a bunch of the shims and such are the wrong size. I call them up and using a die grinder to widen is no big deal - just more hassle than I wanted. Now - trying to install carrier seals at the axle tubes - these appear wrong too! Can't even get close to getting these things in. So - I go to the parts store, get 2 new ones - and they are totally differnt (they don't fit either).
Am I missing something here? Are these seals extra hard to put in? I'm getting cranky - think I'm going to grab a sandwich and settle down a bit
J
__________________
Jon McLeod
2002 Harley Davidson F150 #6792
visit Florida Explorer Club
FMExplorer is offline   Reply With Quote
Old 02-08-2003, 10:31 AM   #2
xploda01
Augusta, GA
'96 xlt
Vehicle Specs
not trying to be a smarta$$ but the 8.8 is a stronger axle, why did you go with the dana44 in the rear, correct me if i'm wrong
__________________
Matt H.
http://www.lazylifeseats.com
xploda01 is offline   Reply With Quote
Old 02-08-2003, 10:46 AM   #3
FMExplorer
the original tramp
Fort Myers, FL
FMExplorer's Avatar
'99 Explorer EB
Vehicle Specs
(Original Poster)
The D44 is going in the front (Solid axle swap)
Still have the 8.8 in the rear...
J
__________________
Jon McLeod
Old 02-08-2003, 05:42 PM   #4
Muskrat
Califon, NJ USA!!
Muskrat's Avatar
97 Ranger STX
Vehicle Specs
Man, don't know what to tell you, I'm not even worrying about the differential yet, but I just had a hell of a time getting my inner wheel bearings in, resorted to setting the hub, with bearing installed in front of the heater, then slid the assembly onto the spindle, it's gonna be fun getting it apart, but that is what a bernzo is for, I guess
__________________
I'm the evil little leprechan, according to Tuna
Muskrat is offline   Reply With Quote
Old 02-08-2003, 06:19 PM   #5
Hotweels
Calgary,AB
'92 EB
Vehicle Specs
Yes inner tube seals are a pita this article may help a bit http://www.off-road.com/ford/bigbroncos/tech/dana44/ i havent installed mine yet but i know they are a $%#@! to remove.
__________________
D44/9" open/spool
36" TSL SX's
Warn 8274
C5-B&M Megashifter
5.0 Speed Density swap done an running.
Hotweels is offline   Reply With Quote
Old 02-09-2003, 06:43 AM   #6
FMExplorer
the original tramp
Fort Myers, FL
FMExplorer's Avatar
'99 Explorer EB
Vehicle Specs
(Original Poster)
Hotwheels,
Thanks! Very helpful. I looked all over for something like that and wasn't able to find it. Thanks again!
Muskrat - good luck on everything! I need to find a center pin now. The one I have doesn't fit
J
__________________
Jon McLeod
Old 02-09-2003, 10:53 PM   #7
offroader_69_me
Trinidad, Crawlorado
offroader_69_me's Avatar
'91 XLT
Vehicle Specs
would you quit complaining I want to hear WOW this is so easy I know anyone could do it no problem, Offroader would have a walk in the park doing this, I am so glad this is SOOOOO easy!!
Well good luck anyway!
__________________
CLICK CLICK BOOM proud member Rollover Posse! full width d44 & 8.8 both locked 36"iroks
(93 Ranger 5" eibachs 33" BFG's-SOLD-) 02 sportster 883R 112 HP 96 ft. lbs *REMEMBER 9-11-01*
GOD BLESS OUR TROOPS
offroader_69_me is offline   Reply With Quote
Old 02-10-2003, 10:29 AM   #8
-=DaemoN=-
The Netherlands
-=DaemoN=-'s Avatar
Rigless!
Vehicle Specs
Not trying to hijack your post but how the hell does the spindle come off? TIA
-=DaemoN=- is offline   Reply With Quote
Old 02-10-2003, 07:06 PM   #9
Brian1
Albuquerque, NM
Brian1's Avatar
1991 XLT
Vehicle Specs
Quote:
Once you have the nuts off hit it with a big rubber hammer from side to side and up and down. Once there is a gap between the knuckle and back of the spindle put a little pry bar in it then either keep hitting the spindle up and down to work it loose or see if it will pry off. Just be careful and dont hit the spindle surface with anything that will scratch it.
And about the rebuild kit not fitting, there are several different models of a dana 44 and the kit you may have may be for a different dana 44. Not 100% sure though. When I bought oil seals for my 44 they didnt fit because it was for a different model 44. I took it to napa and they matched the part number to get me the right ones.
Brian1 is online now   Reply With Quote
Old 02-10-2003, 08:29 PM   #10
Muskrat
Califon, NJ USA!!
Muskrat's Avatar
97 Ranger STX
Vehicle Specs
try using a cold chisel between the spindle and the knuckle. if that doesn't work, I used a 3 jaw puller and put the lock nuts back on the spindle, attached the puller over the nuts, and pulled against the axle shaft, not the greates idea, but it worked as I was adding tension, I hit the spindle and the knuckle with the chisel as well
__________________
Old 02-11-2003, 07:54 AM   #11
-=DaemoN=-
The Netherlands
-=DaemoN=-'s Avatar
Rigless!
Vehicle Specs
That's what I thought. Maybe I just need a bigger hammer . THanks guys.
Old 02-16-2003, 06:30 AM   #12
FMExplorer
the original tramp
Fort Myers, FL
FMExplorer's Avatar
'99 Explorer EB
Vehicle Specs
(Original Poster)
Ok - thought I had the problem withthe seals solved. Got a 6" bottle jack (2 ton) and that fit well into the center section. I was able to use it as a press to push the seals in. However, the seals crushed. Back to the drawing board!
J
__________________
Jon McLeod
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
