Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer Audio & Navigation
Notices
Explorer Audio & Navigation Audio and navigation systems. CD, DVD, MP3, GPS, Video, Mobile Computer, Speakers, Amplifiers.
button combination to reset your radio
Reply
Thread Tools
Old 03-10-2003, 05:20 PM   #1
TUFins21
Philadelphia, PA
97 Sport
Vehicle Specs
(Original Poster)
orange button combination to reset your radio
Does anyone know how to reset the radio using a combination of buttons. I have a 97 Explorer Sport, and it has a 6 cd changer. If you know, let me know. Thank you.
TUFins21 is offline   Reply With Quote
Old 03-10-2003, 05:29 PM   #2
Heath
Elite Moderator Intoxicator
Rigby, ID
Heath's Avatar
'01 XLT Slightly Modded
Vehicle Specs
I would think pulling the battery off for 20 min or so to reset the whole electrical system would work... But I'm not positive...
__________________
Rigby, ID
2001 Explorer V8 XLT with a mod or two
"Never fight an ugly guy, he has nothing to lose"
Mugshot Updated 8/6/10
To support the site and upgrade to an elite membership, Click Me!
Heath is offline   Reply With Quote
Old 03-12-2003, 06:31 PM   #3
Iowa Hick
Bloomfield, IA
1995 Eddie Bauer
Vehicle Specs
I am having the same problem so let me know if that works
Iowa Hick is offline   Reply With Quote
Old 03-12-2003, 06:38 PM   #4
TUFins21
Philadelphia, PA
97 Sport
Vehicle Specs
(Original Poster)
Jake, I can't do it because I dont have the right tools. If you want to try it, go ahead and let me know. Are you really having the same problem, with the whole headphone thing. let me know.
Old 03-12-2003, 08:40 PM   #5
WoodysX
Ashburn Virginia
91 EB & Q
Vehicle Specs
Ok boys, why dont we try it together now...1....2....3!
All you do is loosen the terminals with your hand or a wrench, or yank it off...
__________________
My New Ride
http://www.cardomain.com/id/93blackq45
My Old Ride/System
www.cardomain.com/id/woodmister
AIM- Woodmyster703
WoodysX is offline   Reply With Quote
Old 03-12-2003, 08:45 PM   #6
'96explorereddiebauer
Explorer Emeritus
Clemmons, NC
'06 Honda Accord EX-L
Vehicle Specs
Wait...do you have the JBL system?? If so, you can't really reset the system, even taking the battery terminals off. The amp has backup power to it so whatever station presets were programmed would stay. The only thing you have to set is the clock.
__________________
Billy
'00 Acura Integra GS
'98 Honda Accord EX-V6
'05 Honda Odyssey EX-L
'96explorereddiebauer is offline   Reply With Quote
Old 03-13-2003, 07:54 PM   #7
cobrajeff
White Lake, MI
2000 Mountaineer
Vehicle Specs
There are no "reset" buttons
There are no buttons to push on the factory radio to "reset" it. I think you are looking for the Rear Seat Control enable, which I posted under your other question about your rear speakers and headphones.
Disconnecting the battery on your Explorer may cause your radio stations to reset, depending upon the model year and the radio model. Older model radios will default to a set of factory preset radio stations, that were often stations local to the assembly plant building the vehicle. Newer models, with Premium level or Audiophile level radios, as 96EEB said, will maintain the last "user-set" radio presets, regardless of how long the battery power is interrupted.
I hope my explanations have been helpful.
regards,
cobrajeff
cobrajeff is offline   Reply With Quote
Old 03-15-2003, 12:30 AM   #8
Iowa Hick
Bloomfield, IA
1995 Eddie Bauer
Vehicle Specs
Ok, my problem might not be the same after all, my radio acts like it isn't getting any power, they clock won't work or anything, i tried unhooking the battery, but it didn't work. I do know that all the grounds going into the radio are good and so are the voltages, i have tried several different radios with the same result, if anyone has any ideas about what might be wrong let me know
Old 03-15-2003, 12:32 AM   #9
Iowa Hick
Bloomfield, IA
1995 Eddie Bauer
Vehicle Specs
I forgot to mention it but i have a 95 Explorer with a cd changer and i think i might have the JBL system
Old 03-15-2003, 01:13 AM   #10
Explorer Emeritus
Clemmons, NC
Vehicle Specs
Jake, have ya tried to see if it's a connection problem?? Since you said it's not getting power, check all wires are plugged in tight. Check the ones in the rear quarter panel because that's where your amp and sub amp are. It's a big job but it's worth check it out.
Since you have an Eddie Bauer, I'm sure you have a JBL system. If you have a subwoofer in the back, then it's the JBL system. Good luck diagnosing your problem!!
EDIT: Boy do I feel like an idiot. I didn't fully read your post so ignore the top. If you're getting normal voltage and getting good grounds and tried switching to different radios, then I'm sure it's a bad amp. Try swapping it out with another amp for the JBL system.
__________________
Billy
Old 03-15-2003, 08:06 PM   #11
Iowa Hick
Bloomfield, IA
1995 Eddie Bauer
Vehicle Specs
Ok, i took off the plastic interior of the back passengers side quarter panel to check out the amp, when i did if noticed that where the antenna plugs in it was about to come apart and i was wondering if the antenna wasn't plugged in would it stop the radio from working
Old 03-15-2003, 08:21 PM   #12
ld50
Oh, the money you`ll blow
British Columbia
ld50's Avatar
93 4 dr 4x4 manual XL.
Vehicle Specs
what? who doesn`t have at least an adjustable wrench kicking around? do you just have screwdriver?
-giggle
That`s worse than my dad, but he has a tool box to put his tools in -BOTH OF THEM!
__________________
Jim from BC - My Mugshot
All My Mods And How I did Them
ld50 is offline   Reply With Quote
Old 03-19-2003, 06:27 PM   #13
Iowa Hick
Bloomfield, IA
1995 Eddie Bauer
Vehicle Specs
I changed my amp and it still won't power on, anyone have any more ideas
Old 04-01-2003, 04:34 PM   #14
Iowa Hick
Bloomfield, IA
1995 Eddie Bauer
Vehicle Specs
Ok, i still can't get my radio to work, i changed the amp and that didn't fix it, i did figure out that when the key is off if you push the DSP button then push the clock button it will display the time as long as you hold the button down, and also when the key is off the button to eject a cassette works, other than that nothing works, is it possible i have a bad speaker
Old 04-02-2003, 01:17 AM   #15
trouble_shooter
Lacey, WA
2001 Limited
Vehicle Specs
Greetings, cool site !
I am a factory Ford/Visteon trained electronics repair technician. I've been immersed in blue oval audio for 8 years and my partner in crime has spent 22 years at the bench fixing Ford audio.
Any JBL-LUX(front head unit, rear amp which is actually the radio) with DSP is basically a computer. The front and rear talk to each other on a continual basis even when the radio is off. These unit convert analog to digital and back to analog(ADA), all with software.
Any lock-up or funky audio freaky control problems are software issues and both units(front and rear) need to be reprogrammed. They are a matched pair so swapping front or rear will not solve problems. Sometimes a hard reset, removing battery with ground left connected, over night will help for a while.
If the front control panel doesn't have DSP then they are not a matched set and reprograming is not an issue.
Hope this helps.
trouble_shooter is offline   Reply With Quote
Old 04-07-2003, 11:34 AM   #16
Iowa Hick
Bloomfield, IA
1995 Eddie Bauer
Vehicle Specs
Tried leaving the battery unhooked overnight, still won't work, even tried it with the original amp, i also checked and all the speakers in my doors are good, do you have any more advice on what i could try or who i could take it to that wouldn't charge me an arm and a leg
Old 04-07-2003, 01:32 PM   #17
trouble_shooter
Lacey, WA
2001 Limited
Vehicle Specs
No help on the arm and a leg part. All the service centers have fixed rates for reprograming. An actually only one can do it, Royal Radio in Michigan 800-367-3393---800-482-0821 in Michigan. They will need model # of both units. I dont know what they charge, but they ar the direct source for this type of service.
Old 04-07-2003, 04:26 PM   #18
Iowa Hick
Bloomfield, IA
1995 Eddie Bauer
Vehicle Specs
Well thanks, i will have to try them
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
