| Modified 1995-2001 Explorers Questions related to modified 1995-2001 Explorer, Mountaineer, Ranger and 2002+ Sports (2dr). Aftermarket accessories and modifications. Bullbar, running boards, floor mats, cargo mat, DVD headrest, wheels, tires, stereo upgrade, headlights, mud flaps, torsion twist, lift kits, engine swap, transmission swap. |
Thread Tools |
#81 |
Wannabe Elite Explorer
Tulsa, OK
2001 Eddie Bauer AWD 5.0
Would it possible to have two fans? one on the inside, one on the outside of the radiator?
#82 | |
Elite In Memoriam
1999 XLT
Quote:
__________________ Al Franklin My truck My Quest for 30 RIP Al Franklin! 1947-2010. Gone but not forgotten! :( |
#83 |
2003 Limited V8 AWD
'91XLT '92EB4x '96V8 2wd
I think also it is good to keep in mind that a good clean cooling system helps a good amount along with the correct antifreeze and water mixture... I have a V-6 with dual fans and use the smaller pusher as a a/c only fan....
__________________ DD is '05 Screw F150 - '03 AWD V8 Limited Explorer '79 Ford Bronco on 36" TSL's My '66 Stang... SOLD - My '91 and others... SOLD - My 96... V8 2wd, lowered SOLD - Lifted '92 EB...4x4, Warn,KKM,32's |
#84 |
Let Them Eat Cake
Cape Girardeau, MO
94 Sport 4x4
I was looking at the new 180 Flex-a-Lite fan (http://www.flex-a-lite.com/auto/html...c_x-treme.html) and I wonder if this fan shroud that it comes with would be as efficient as the stock fan shroud.
I have found the OEM fan shroud to be very effective. If that is the case, then I could use a Syclone S-blade fan (which does not come with a shroud) and keep the OEM shroud. I *WILL NOT* mount a fan "in-core". I will always use brackets. __________________ 94 Sport 4x4; EA cone filter; Granitelli MAF; BBK 66mm TB; Jacobs wires; Magnaflow w/2.5" pipe; Rancho RS9000; EE sways; Apten dual-program chip; Visteon Super-Cool radiator; BFG 30 x 9.50's; AMSOIL throughout; etc. etc. |
#85 |
B
San Jose, Calif
2003 sport trac
Would think it depends on how coverage you get over the core with the 180 shroud.
On mine I have zero core exposed top and bottom,one inch on the sides exposed |
#86 |
CA
1997 Explorer Sport 4X4
It would be easier to install an electric fan from a crown victoria as the radiator dementions are the same as the explorer. The CV fan also flows 4800 cfm compared to the black magics 2800 cfm. Both draw 10 amps.
__________________ 1997 Ford Explorer Sport: Over 500,000 miles and still going See my CarDomian for details on my Explorer http://www.cardomain.com/ride/666173 2007 Ford GT40: 2007 Lincoln MKX |
#87 |
Rah no Hans Bwix
WA
1994 XLT 4x4
What size is the shroud though? Not sure if it's the same fan as in the Mark VIII, but I had a Mark fan and there wasn't enough clearance.
__________________ 1994 Explorer XLT My registry entry: here Diamond Everything w/ HID Bi-Xenon Projectors I'm no doctor, but I am a self-proclaimed genius. There's no reason not to trust me. What kind of dessert causes women to gain the most weight? Wedding cake |
#88 |
Knoxville, TN
98 Mountaineer A4WD
Interesting, because the Crown Vics have both an electric fan, and a mechanical fan. I wonder if the CV fan will fit a 99 Explorer?
__________________ Don 91 Lincoln LSC/SE, 99/93 Explorer Limited 4WD, 98 AWD Mounty with 255/55/18's, big sway bars, and 12.75" x 1.25" rotors. Soon a BW4406, built trans, stereo and interior. The best thing that could help us all, is the Fair Tax Plan. Be American, Buy American (Manufacturer)
#89 |
CA
This is the electic fan and I have it installed in my X. Almost one year and no problems so far. It is a direct bolt on.
#90 |
Dallas,Tx
'04 Aviator 32v V8
have any pics rick?
what year crown vic? did you just buy one from a junk yard? how hard was the wiring and setting up the temp sensor? |
#91 |
Chestnut Ridge NY
1995 Limited
RickOTR, do you have a fan from a Crown Vic installed? What additional parts did you need?
I have been searching for a fan from a 96-98 Crown Vic or Grand Marquis but as yet have not come across one that was not severely damaged. __________________ Black , street stock, 1995 Ford Explorer Limited, 4.0L-OHV V6 with AirHog filter, iridium spark plugs w/Taylor wires, 4dr, auto w/tow package and 3.73 Traction-Lok rear, 4WD, 4 wheel disk brakes with ABS, with tan leather, sunroof and engine block heater, made in Canada. Rear leaf springs from a '78 Bronco 3" wide spring pack added to the stock 2.5" wide main spring, 1.2" lift.
#92 |
CA
The fan I have is from a 1996 CV police intercepter that I found in a junk yard. You may have to look really good, that is what I had to do. Lincoln and Crown Victoria have different radiator supports so it will not work. Also check out E-Bay a I have seen a few on there site. Sorry no pics.
#93 |
Chestnut Ridge NY
1995 Limited
Shouldn't the equipment be the same on the Mercury Grand Marquis?
#94 |
Knoxville, TN
98 Mountaineer A4WD
Yes, but check, the police car may have a better fan than all others. How thick are those CV fans? Where did the ten ampere draw figure come from? Most decent aftermarket fans pull at least fifteen amps.
#95 |
White Bear Lake, MN
'04 Eddie Bauer 4.6
Anybody put an electric fan on their 3rd gen with a 4.6? Just wondering what is out there and what is working for people.
#96 |
Elite In Memoriam
1999 XLT
My Black Magic Fan once again proved that it can indeed cut the mustard a few days ago.
On a trip yo Atlanta, I got stuck in traffic about 20 miles S of the airport on I75. It was bumper to bumper for 15 miles at virtually 0 MPH. I was in this mess for 1 1/2 hours. The ambient temperature ( counting road heat, etc ) was 124 F. The tranny fluid temp rose to a max of 201 F. The temperature gauger on the truck never moved. The AC never ceased to cool. My Black Magic 150 fan again proved it was up to the task. __________________ Al Franklin My truck My Quest for 30 RIP Al Franklin! 1947-2010. Gone but not forgotten! :( |
#97 |
B
San Jose, Calif
2003 sport trac
150 do's indeed work, is just so friggen noisy compared to the 180
#98 |
Chestnut Ridge NY
1995 Limited
Excellent update, Aldive. That pretty much proves its worth.
#99 |
Rah no Hans Bwix
WA
1994 XLT 4x4
Is the 150 the same fan Rick used? It makes no sense how it works great in 123 degree weather w/ A/C on, but it didn't work on a few other X's that tried it.
#100 | |
Elite In Memoriam
1999 XLT
| Thread Tools | |
