VBVA
Go Dukes!
- April 12, 2002
- Northern Virginia
- '93 XL
My front end has been wobbly and clunky for about 4 months now and I finally got around to replacing those pesky radius arm bushings. Thanks to everyone who has given me pointers along the way. Here is a simplified task list of how we did it:
- Purchased two radius arm bushing kits ($11.88 at Advanced Auto - Ford wanted to charge me $45 for each kit!)
- Purchased Grade 8 Hardware at Pep Boys for less than $4 - 4 bolts 7/16'' dia 14 threads 1 inch long, 8 washers, 4 nuts
- Place truck on jackstands and have a floor jack handy for later - We put the jackstands near the front wheels to support the suspension
- Unbolted all the necessary bolts - 4 holding the two brackets together, 2 holding the fuel filter in place, 2 on each bracket pointing down holding the brackets to the frame, large nut holding the bushings between the bracket and the radius arm
- Moved the fuel filter and parking brake cable out the way for grinding
- Got a good rotary grinder with a strong metal/concrete disk and tackled the 4 rivets holding the RA brackets to the frame (this took the longest)
- Dropped the brackets down and off the radius arms and took off the bushings - These things were toast as you can see in the picture.
- Remember how you took the bushing kits apart and put them back on just the opposite
- Get the brackets with bushings back in place and reattach all bolts placing the 4 new bolts in place of the rivets - these may be a little strenuous to get in, but you'll figure it out
- Clean up and take for a test drive!
I can already tell a difference in the ride. The front suspension is much smoother and there is no more wobbly or clanginess from the front end. Start to finish it took us just under 4 hours and cost less than $40. A shop would have charged me over $400 swap out bad RA bushings!
