Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Offroad Tech Forums > Offroad Explorer - Ranger Projects > Explorer - Ranger Shocks, Suspensions, Lift Kits
Notices
Explorer - Ranger Shocks, Suspensions, Lift Kits Ford Explorer and Ranger chassis related posts. Get help choosing the right shock absorber and aftermarket suspension for your Explorer or Ranger based vehicle.
Leaf Spring Anti-Friction Pads - Help!
Reply
Thread Tools
Old 07-02-2003, 03:01 PM   #1
akcrogers
Fairbanks, Alaska
'92 Explorer 4WD 4DR XL
Vehicle Specs
(Original Poster)
Anyone know a part number or manufacturer name for leaf spring anti-friction pads?
I tore apart my leafs while doing working on my SOA because the pads looked pretty thin, a couple of them are worn all the way through. However, I can't find them in town, or even online. Seems like it should be a pretty universal application. One of the Schucks in town thinks they used to carry them but don't anymore and is looking into ordering them for me! Even Ford can't find a p/n for them. The closest place that definitely does carry them is in Anchorage, 350 miles away...
WTF! How is it always these little parts that hold up projects? Seems like the kind of thing you ought to be able to pick up anywhere...
__________________
Chris
92 XL, 5.5" Superlift, 3" BL, 33 BFG ATs, Gibson Exhaust, PIAA Illumination; 35s, Taller Gears, and a 302 next
My Explorer Forum Registry Page
akcrogers is offline   Reply With Quote
Old 07-02-2003, 05:58 PM   #2
Dre
Chicago
Dre's Avatar
94 Limited
Vehicle Specs
I was going to answer on your other post regarding the SOA but figured I'll do it here. You should be able to get these anti-friction pads at any of your local auto parts stores... AutoZOne, PepBoys... whatever... if there are any in the area..... or pretty much any auto shops... truck shops... they should carry these... these are regular 2.5"pads. I have also gone on without these as well and had no problems...... but you might want to do it all perfect. Center bolts... now these can be a bit tricky... I wuldn't buy anything else but factory.... cheap anyway but good quality. I have used once the ones supplied by Skyjacker and snapped both of them. In order to get these out (get leafpacks apart) you'll need an angle grinder... yeap! get this baby out and go after the bolts.... but first use something (vise or something) to hold leafs together.... otherwise you might get injured when leafs seperate.
As far as SOA??? ask away - I just finished mine yesterday... Hurray!!!
__________________
4x4 Werks by Dre
My Gallery
Dre is offline   Reply With Quote
Old 07-02-2003, 06:01 PM   #3
Hokie
Hokius Maximus
Denver, CO
Hokie's Avatar
'04 Jeep Grand Cherokee
Vehicle Specs
Quote:
Hehe... yeah, I forgot the C Clamps when doing my AAL... luckily it really only scared the crap outta me when the leaf pack sprung (flew) apart.
__________________
Brett
I get payed to sell and play with Cummins engines
My old '98 MTNR - 5.0 V8 4x4 My old '99 Sport
Hokie is offline   Reply With Quote
Old 07-03-2003, 11:05 AM   #4
akcrogers
Fairbanks, Alaska
Vehicle Specs
(Original Poster)
Well I tried all of the local autoparts stores, schucks, napa, autozone, then I started trying the dealers, ford, chevy, dodge, toyota, etc. Finally I tried service stations. No one in Fairbanks sells them. Schucks said they used to carry a universal kind but don't anymore. I couldn't even find the pads online. And the spring shop in Anchorage was kinda iffy. I know they aren't required, but I hate spring slap noise...
So I salvaged as many of the stock ones as I could, and then I cut up some hard rubber bathroom tile-wall joint liner that I had laying around. Its about perfect width once you cut the lip off, and is just about the same thickness as the stock pads. Little bit of liquid nails, and its now firml pressed in between the springs. Guess I'll see how long that holds up.
Thanks for the replies
__________________
Chris
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
