EF Swag Store 2013 Ford Explorer Forums Elite Membership Chat Room My Posts Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Projects - Hobbies and Additional Topics > Exploring every thing under the sun!! > General Topic Polls
Notices
General Topic Polls All sorts of general topic polls for you to participate in. Want to start your own poll? This is the place!
quick intake question
Reply
Thread Tools
Old 07-16-2003, 05:56 PM   #1
sean4385
Hopewell NJ
'97 Sport
Vehicle Specs
(Original Poster)
When installing my new KKM i accidently over tightened one of the four bolts and stripped the threads in the bracket. So now one of the corners isnt very tight and i think its sucking in extra air. Sometimes there is a very loud humming noise coming from under the hood which i assume is from this. But i was wondering if this can have any negative effect on my truck.
It probably would be sealed tight with only 3 bolts working if it wasnt for that wire net peice that goes between the KKM bracket and the bracket on the MAF. This makes a gap and would only be completely sealed with the pressure of all four bolts squeezing the brackets together. I was wondering if maybe i put that wire net in the wrong spot....
If not then does anyone know an easy way to fix this? Like some sort of sealing stuff?
.....Its not really possible to use a bolt and a nut because the hole goes right up against the plastic tube that holds the filter.
Thanks,
Sean
sean4385 is offline   Reply With Quote
Old 07-16-2003, 06:13 PM   #2
aldive
Elite In Memoriam
aldive's Avatar
1999 XLT
Vehicle Specs
Why not simply get a new bolt?
__________________
Al Franklin
My truck
My Quest for 30
RIP Al Franklin! 1947-2010. Gone but not forgotten! :(
aldive is offline   Reply With Quote
Old 07-16-2003, 07:22 PM   #3
AlaskanJack
Elite Cabin-Fever Captain
Centralia, Washington
AlaskanJack's Avatar
91 , 93 & 01 Sports
Vehicle Specs
you can get a little silicon caulk and put around the area.
__________________
91 Explorer Sport - 5.5" Superlift, Super Runner Steering, Extended RA's, 4.10 Gears, 15x10 AR Rims, 35x12.5 Tires
93 Explorer Sport 2" Skyjacker Susp lift, w/AAL & Warrior Shackles, 32x11.50 Mud Kings, 2" BL
01 Explorer Sport - Wife's baby.
- MY MODS PAGE - MY TEMP IN ALASKA
AlaskanJack is offline   Reply With Quote
Old 07-16-2003, 07:23 PM   #4
AlaskanJack
91 , 93 & 01 Sports
Vehicle Specs
Ah even better pull the bolt and wrap it with teflon tape it will tighten back up if you don't crank it too hard. When I built boats we would use a wire tie in the hole and tighten the bolt, then trim off the wire tie. the wire tie form around the bolt to tighten it in the hole.
__________________
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
