Ford Explorer Sport Trac Ford Ranger Mazda Navajo Mercury Mountaineer, Ford Aerostar Message Board®
Ford Explorer, Sport Trac, Mercury Mountaineer, Mazda Navajo, Ford Ranger, Ford Aerostar SUV Enthusiast Forums
Join the "Elite Explorers Today!"
Explorer4x4 Sportrucks 2011 Explorer Forums Elite Membership Product Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood
Notices
Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories.
Reply
Thread Tools
Old 07-27-2003, 09:46 PM   #1
karl_burns
Winston Salem, NC - Go Deacs!
karl_burns's Avatar
98 Sport OHV 5speed
Vehicle Specs
IAC valve cleaning thread (w/pics)
Have you ever noticed a loud hum and/or whine (whining) coming from your engine bay? Or more specifically your intake area? Or does your engine have a hard time holding the idle? Well, more often than not, this is due to a dirty IAC Valve. Since everyone is always asking about it, hopefully this will help.
My engine was making the loud hum / whine noise. AutoZone wanted $131.99 for a new part. and it's $50 deductible against my extended warranty, so I wanted to fix this myself. I purchased a can of Electrical Parts cleaner, the non-residue type, drove home and let the engine cool. Here's a pic of where the IAC Valve is located under the hood:
Two 10mm bolts to remove, and unclip the electricals:
Here's the dirty intake's connection with the IAC:
Turn the valve to notice two chambers. Inside one of them you will see a spring. Inside the other, you will probably see a bunch of dirt coating what should be an exposed sensor. Spray the Electrical parts cleaner liberally, directly into the opening, and watch until the liquid coming out of the valve is clear (white). Set the IAC on a towel or clean surface and allow any other liquid to drain and the sensor to fully dry. Here's a picture of a clean IAC valve (underside):
And don't forget to clean the sensor below the black snap off cap on the side of the IAC valve:
After allowing to dry, replace the IAC and start your truck. You should allow the engine to warm up for a few mintues and the computer will re-learn how much air to allow into the engine at idle.
I experienced a much LOUDER whine after doing this for the remainder of the day, but I only allwed the liquid to drain for about 2 minutes. The whine hasn't returned in two days since, so I'm guessing the liquid cleaner wasn't completely drained when I replaced the IAC Valve. Just a warning in case you are anxious like me.
Karl
CBOUG76.... can I be on the Useful Threads list?
__________________
Karl Burns
2000 Explorer Sport: KKM, BBK 66mm TB, Granatelli 70mm MAF, 3" Intake, 31" BFG AT/KOs
1998 Explorer Sport: Spindle Lift, SOA, Rancho 9000s, powered by Apten, PIAA 1500s and 520s
Eclipse, McIntosh, Focal and JL sound system
karl_burns is offline   Reply With Quote
Sponsored Links (Less Ads)
Old 07-28-2003, 08:23 AM   #2
Opera House
Cincinnati, OH
97 Explorer XLT
Vehicle Specs
What!!!!! You didn't take off the plastic cap
The outside black plastic cap that easily spins will pop off and snap back on without damage. Inside there is a felt filter pellet. Cleaning just the valve without removing this often cloggs this filter up worse. This source of back air flow balances the valve and provides clean air to prevent buildup on valve. Often just cleaning this will get rd of the moose calls. Add pictures of this and you have something.
__________________
Rule #7: Believing and seeing are often both wrong. (FOW)
02, 97, 92 Explorer XLT 4X4 4.0L
Opera House is offline   Reply With Quote
Old 07-28-2003, 09:18 AM   #3
drmoore71
houston, texas
drmoore71's Avatar
2006 Z-71 suburban
Vehicle Specs
karlito, i am so proud of you! you got your hands ditry! now i need a moment to wipe the tear from my eye. you do know, however that not allowing the cleaner to drain completely could have led to an incendiary situation, though.
__________________
doug moore houston, tx
06 z-71 suburban(mine) & 03 trailblazer lt 2wd(hers)
66 mustang convertible
66 mustang hardtop (for sale)
dougs truck
drmoore71@att.net
drmoore71 is offline   Reply With Quote
Old 07-28-2003, 09:41 AM   #4
aldive
Elite In Memoriam
aldive's Avatar
1999 XLT
Vehicle Specs
Nice pics, thanks.
__________________
Al Franklin
My truck
My Quest for 30
RIP Al Franklin! 1947-2010. Gone but not forgotten! :(
aldive is offline   Reply With Quote
Old 07-28-2003, 01:24 PM   #5
karl_burns
karl_burns's Avatar
98 Sport OHV 5speed
Vehicle Specs
Ooooooohhhhh
Now that I know it spins off, I'll check that tonight. Mine wasn't coming off easily, so I didn't press my luck.
I'll append my post with pics of that.
Thanks Opera House,
Karl
__________________
Karl Burns
Old 07-28-2003, 01:29 PM   #6
Jason_25
ECX Member
New Bern, NC
Jason_25's Avatar
'95 Explorer "Expedition"
Vehicle Specs
It doesn't spin off, it just pops off when you pull it outward.
__________________
1995 Explorer "Expedition" 4.0 4x4
1987 Bronco II XLT 2.9 4x4
1988 Bronco II XLT 2.9 4x2
1997 Explorer XLT 5.0 4x2
My Truck
Jason_25 is offline   Reply With Quote
Old 07-28-2003, 02:08 PM   #7
williecume
Arlington, TX
97 xlt & 98 mounti
Vehicle Specs
i think i'll try this saturday, i'm getting tired of the whining also.
__________________
97 Explorer XLT 4-dr
4.0 OHV 5-speed manual
custom dual exhaust from flowmaster 40 non-delta
2" autozone shackle lift
200+k miles now!
williecume is offline   Reply With Quote
Old 07-28-2003, 07:03 PM   #8
karl_burns
karl_burns's Avatar
98 Sport OHV 5speed
Vehicle Specs
I updated to include the black cap
Didn't look like much in there, but went ahead and sprayed cleaner on it as well. Allowed to dry for almost an hour, so hopefully I don't get that same 100 db whine I got when it was still wet Saturday!
At least it went away, and I didn't have a date that night.....
<Don't even think about flaming me Doug>
Karl
__________________
Karl Burns
Old 07-28-2003, 11:11 PM   #9
drmoore71
houston, texas
drmoore71's Avatar
2006 Z-71 suburban
Vehicle Specs
NO DATE?!?!?!? are you losing your touch?
__________________
dougs truck
drmoore71@att.net
Old 07-29-2003, 10:12 AM   #10
Opera House
Cincinnati, OH
97 Explorer XLT
Vehicle Specs
Arrrrgh This is a tough crowd to please
But, that plastic item is two piece. The outside plastic cap snaps off the inner plastic piece which stays on the IAC. Between these two pieces is the felt filter pellet. Interesting how much sand makes its way up there.
__________________
Old 08-23-2003, 09:07 PM   #11
MaverickDaKid
Poway, San Diego, CA (Born in Miami!)
93 XL and 96 XLT
Vehicle Specs
Sorry I'm not that smart when it comes to mechanics but... what is that thing under the IAC called. It has 2 tubes leading down somewhere in the engine and has an electrical socket aswell?
__________________
1996 Explorer XLT OHV 4x4
1993 Explorer XL OHV 4x4
MaverickDaKid is offline   Reply With Quote
Old 08-23-2003, 09:31 PM   #12
X~FACTOR
Name is Ray
Valley Stream, Long Island
X~FACTOR's Avatar
'97 XLT 4-dr SOHC
Vehicle Specs
I noticed you have a '98, karl. I have a '97 with 60k miles and have not experience this problem at all [knock on wood]. What mileage does this normally occur?
Very good write up btw.
__________________
My Mods
X~FACTOR is offline   Reply With Quote
Old 08-23-2003, 10:09 PM   #13
frickea86
"Is that the Turbo?"
SpringChurch, PA
frickea86's Avatar
'97 XLT SOHC
Vehicle Specs
i have a question...i've done all this and the wineing noise still hasn't gone away. my rough idle has some but it comes back off and on. i'm just wondering if its not functioning as well as it should be. how do u know when it needs replaced?...thanks...
adam
__________________
Adam
4.0 SOHC Modified w/ Magnaflow Exhaust...
frickea86 is offline   Reply With Quote
Old 08-24-2003, 01:54 AM   #14
karl_burns
karl_burns's Avatar
98 Sport OHV 5speed
Vehicle Specs
I really think most IACs have to be replaced
The other day, while this thing was wining a whole lot during idle and driving, I decided to pull over, popped the hood, and yanked/removed the black plastic cap from the side of the IAC. NO more whining. NO loss in milage. NO change in idle.
Hmmmmm........
Karl
__________________
Karl Burns
Old 08-24-2003, 08:30 AM   #15
X~FACTOR
Name is Ray
X~FACTOR's Avatar
'97 XLT 4-dr SOHC
Vehicle Specs
karl_burns, wouldn't removing the black cap get the inside of it dirtier faster? It's gotta be there for a reason. If nothing else its there to cover the inside so dirt would not go in.
__________________
My Mods
Old 08-24-2003, 09:26 AM   #16
'96explorereddiebauer
Explorer Emeritus
Glen Allen (Richmond), VA
'96explorereddiebauer's Avatar
'06 Accord EX-L & Sebring
Vehicle Specs
Quote:
That's the DPFE. I had to replace that last week because of the CEL.
__________________
Billy
'06 Honda Accord EX-L
'06 Chrysler Sebring Touring Sedan (Company car)
'98 Honda Accord EX-V6
'05 Honda Odyssey EX-L
'96explorereddiebauer is offline   Reply With Quote
Old 09-28-2003, 03:17 PM   #17
nfixit
brooklyn/ny
97 Explorer XLT 5.0
Vehicle Specs
Idle
Hello all, I just brought a 97' xlt 5.0L, and I notice an idle problem also BUT IT HAPPENS AFTER THE TRUCK WARMS UP!, when I sitting at a traffic light it starts to vibrate a little then some times alot(like it wants to shut off). My question is do the IAC sensor have problems on v8 also?. and is it located in the same place as the v6
Thanks in advance, the dealer I brought the truck is a distance (2.5hrs), I want to have an idea what the problem is so I don't have to make more than one trip!
Nfixit
nfixit is offline   Reply With Quote
Old 09-29-2003, 01:31 PM   #18
V8BoatBuilder
Transplanted Bostonian
East Brunswick, NJ
V8BoatBuilder's Avatar
97 Mountaineer V8 4x4
Vehicle Specs
Just cleaned my IAC, it was SUPER dirty. I was having trouble starting, and a dip in RPMs (almost to the point of stalling) when coming to a stop. We'll see if the cleaning helps, I used denatured alcohol.
I wasn't able to clean the felt pads that well
__________________
-Aaron !!!!GO RED SOX!!!!
Off Road: 97' Mountaineer: V8, 4x4, 4.56s, 4" Superlift, SOA, TrXus 33x12.5 - Under The Knife
Work: 00' Ranger 4cyl 5spd
On Road: 2006 VW Jetta TDI/6spd DSG. Fill it with diesel, please.
Octopus Yachts, LLC Engineered Marine Electrical Systems
V8BoatBuilder is offline   Reply With Quote
Old 09-29-2003, 05:33 PM   #19
Foo
Ashland, KY
'03 XLT 4x4, 4.0L!
Vehicle Specs
I also cleaned mine out today it was DIRTY! coming from a paintball backround which involves a lot of valving I don't even see how it sealed properly lol
I used some Turner Labratories electronic parts cleaner w/quick dry tech. and it worked great... just waiting for them to dry off
Also do I need to take the negative battery cable off for about 10 minutes to clear the PCM?
Foo is offline   Reply With Quote
Old 09-29-2003, 07:15 PM   #20
karl_burns
karl_burns's Avatar
98 Sport OHV 5speed
Vehicle Specs
Just let it dry and you should be fine
I don't think I disconnected my batter either.
Actually, my IAC continued to whine, and I yanked off the black cap. Instantly, no whine. So I'm thinking the cap gets loose and air tries to get through there causing the whine? I also think that becasue of the video someone put up here about the IAC whining when his hand attpeted to partially seal off that hole the black cap covers.
Thi is so weird.........
Karl
__________________
Karl Burns
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
Copyright 2010 - 1996 Rick Horwitz Photography
Modifying the suspension on any vehicle will cause changes to it's handling characteristics.
